Forum sponsored by Allendale Dec 6th
DA collets
Cornish Jack10/07/2019 11:23:12
971 forum posts
135 photos
I have some DA collets which were bought secondhand. Checking against the published dimensions I appear to have a partial saet of DA200s. The checked dimensions are CLOSE TO the published for that range, but not exact. What degree of tolerance should one expect for the D1, D2 and L values ? (I'm assuming the holding value will be to spec)
Any advice appreciated
rgds
Bill
Neil Wyatt10/07/2019 18:09:02
16927 forum posts
689 photos
76 articles
Hi Bill,
Is it possible they have been over stressed?
Googling the beasties it appears they have a tendency to crack at the nose if used to hold milling cutters, presumably because they aren't designed to collapse for their full length like ER collets. So be aware of this!
Cornish Jack10/07/2019 18:32:20
971 forum posts
135 photos
Thank you Neil - I appreciate what you say about possible fragility but my query is actually about identification. The D1 etc. values shown on the 'net are Imperial to 3 decimal places and the items I have differ by 2 or 3 third place values. They are not marked as to type so I'm wondering if I actually have DA200s or some other type? The closeness of approximation is such as to generate a doubt but I can't find acceptable tolerances for collets and holders. Hope that makes sense - (got to be a first time for everything!!sad)
rgds
Bill
JasonB10/07/2019 18:52:32
16870 forum posts
1815 photos
Depends on what published sizes you are looking at. a quick google for DA200 gives the larger dia as 0.531", 0.532" and 13.7mm ( 0.539" ) and lengths of 1.188", 0.19" and 30mm (1.811" )
Emgee10/07/2019 18:56:12
1319 forum posts
211 photos
Hi Bill
This may help, if your collets are close to these dimensions should be OK, also remember there is a max tightening torque.
Edited By Emgee on 10/07/2019 18:59:28
Cornish Jack10/07/2019 21:19:31
971 forum posts
135 photos
Thank you Jason and Emgee - " if your collets are close to these dimensions should be OK, " ,,, that's what I was after; Yet another raid on the piggy bank!
rgds
Bill
Phil P10/07/2019 22:03:59
574 forum posts
155 photos
Posted by Neil Wyatt on 10/07/2019 18:09:02:
Hi Bill,
These collets are actually designed to collapse over the full length, they have a double taper where they get pushed into the collet holder, and a single taper that the nut pushes against.
Probably not quite as effective gripping power as an ER but still pretty good, I have used them for years with no problems. If you make your own collet holders the two internal tapers have to be precisely located with respect to each other to ensure they share the load and collapse in a parallel manner. I have made special reamers with tapered depth stops to facilitate this.
It is the middle two at the bottom of the next photo, they are for DA200 and DA300 collets.
I also use DA180 for work holding.
Phil
Cornish Jack11/07/2019 16:20:23
971 forum posts
135 photos
Phil - very impressive. The sort of thing I would like to do but age and incompetence rule against!. My query was a roundabout way of finding out if a sale item would be suitable for an existing collet holder.
rgds
Bill
Cornish Jack12/07/2019 23:22:59
971 forum posts
135 photos
Just to tidy this one up - the DA200 published dimensions are NOT exact. The new and old sets are interchangeable as regards holders.
rgds
Bill
Tee London LMES 6th Dec
