Forum sponsored by Allendale Dec 6th
V-Twin 100cc Design & Build
Craig Booth 105/08/2019 21:24:52
79 forum posts
143 photos
on to another relatively simple item. The prop thrust.
Turned on lathe with counter bore. Reversed in lathe to add 0.5mm lip so only in contact with inner race of bearing.
onto the mill to blind drill for M5 tapping holes
moved onto side to drill thru for M6 grub screw tappings (both sides) which will marry with flats on the crankshaft.
Graham Williams 1205/08/2019 22:51:54
41 forum posts
Very nice parts Craig.....
Graham
Emgee06/08/2019 09:16:04
1265 forum posts
210 photos
Hi Craig, what is the purpose of the recess in the front face of the prop driver ? I would have thought you need as much driver to shaft contact as possible with the method of fixing the drive to the shaft, also increased mounting face area for the prop, IMO a key would offer more security in operation and if also on a taper ensure concentricity of the drive system.
Emgee
Craig Booth 106/08/2019 21:04:08
79 forum posts
143 photos
Posted by Emgee on 06/08/2019 09:16:04:
Emgee
Hi Emgee, the recess is for the retaining nut which holds the prop driver to the shaft, the grub screws stop the rotation. Your'e right, a key would be the correct method but at the moment that is outside my experience and skill. The key and retaining nut seems to be the way most manufactured RC plane engines of this capacity appear to be fixed. I can image that this may be a part I may need to remake later in the build. Thanks for the comments.
Craig Booth 110/08/2019 21:09:37
79 forum posts
143 photos
This weekend I worked on the crankcase. Started with a big block of aluminium 76x76x65 in the lathe off centred and bored the main crank axis hole. All the other work was carried out in the mill.
The edge chamfers I will do later once the cylinder bodies are located. Now I just have 49 M3 holes to tap sad
Craig Booth 114/08/2019 21:16:18
79 forum posts
143 photos
I didn't get any photos but when I had the stock in the lathe for the cylinders, I also parted off the 2 cylinder heads after cutting the fins. Being the same diameter it was easier to do while the stock was aligned.
Then moved to the mill to drill and counter bore the mounting holes (M4 bolts), and the 2 central holes which will be used to fix the rocker bracket. These are M3 threaded, but looking at them now I may increase to M4.
All the mounting holes are asymetric due to clearances needed on inlet and oulet holes.
Next I made a basic block to hold the head while the other operations, circlular on one side to match the head, and square on the reverse to hold it in the vice and small rotary table I have.
Fixed in the vice at 15degrees off vertical to drill the 7/32 hole for the sparkplug, tapped at 1/4-32, and counterbored to 12mm for plug wrench clearance.
Moved to vertical in the vice and used 2mm slitting saw to cut fins in the top
Then back to 15 degrees to chamfer the top edge to give plug lead clearance.
Emgee14/08/2019 22:17:06
1265 forum posts
210 photos
Nice looking fins Craig, all look very crisp.
Emgee
Craig Booth 117/08/2019 20:39:08
79 forum posts
143 photos
more work on the head today, but first needed to get the rocker support started as I wanted this in place when I drilled the holes in the cylinder head for the valve sleeves so I would get perfect alignment.
Once valve sleeve holes where drilled, fixed the head to the rotary table to mill the flats for the inlet/exhaust ports and to drill the ports.
These ports will need to be re-drilled once the colphos valves sleeves are in place, but the head will need to be anodised first and this cannot be done with any other types of metal present.
JasonB17/08/2019 20:44:26
16521 forum posts
1755 photos
1 articles
It's coming along nicely Craig and just goes to show you can hold milling cutters in a drill chuckdevil
Craig Booth 117/08/2019 20:47:27
79 forum posts
143 photos
Posted by JasonB on 17/08/2019 20:44:26:
Ignorance is bliss. I guess as a newbie I can get away with it..wink
I presume now that you've hinted that the milling bit should be held in a collet instead for better accurancy?
JasonB18/08/2019 06:53:34
16521 forum posts
1755 photos
1 articles
It is not just accuracy, the main reason is that a drill chuck does not hold the cutter very securely particularly when side load is applied and there is a risk of it moving. If you are lucky it will just ride up and not cut but due to the angle of the helix that the flutes follow the cutter is being pulled down when cutting, it would be a shame if this happened to a part that you had previously put a lot of work into.
I think we have all done it to start with or for the odd little cut where it's a faff to change from chuck to collet, (well at least I have) but would be worth investing in a collet chuck such as ER25 or 32 depending on what machine you have.
J
Craig Booth 118/08/2019 08:22:11
79 forum posts
143 photos
Posted by JasonB on 18/08/2019 06:53:34:
J
Thanks for the info Jason, that's something new i've learnt.
I do have a collet set that i use for the larger (16mm bit), but will look to use them for the smaller also.
Mark Gould 112/09/2019 09:39:07
138 forum posts
92 photos
Craig,
Loving this build thread immensely. As an alternative to holding your milling cutters in a collet you can also buy end mill holders from Arc which have fixed sizes. I have 2 ready to go with cutters in them 6mm and 10mm, being 2 sizes I use often.
Mark
Lainchy12/09/2019 09:54:11
153 forum posts
39 photos
Just spotted this thread, and it's superb! Nice work! I'm a noob myself (Far MORE of a noob than you! Far far behind lol)
I did try a milling cutter in my B16 chuck, and found that it pushed it off the B16 taper (maybe I just hadn't pushed it home enough)
Cracking work though!
Craig Booth 130/11/2019 20:02:01
79 forum posts
143 photos
Hi all, well its been a few months and I been concentrating on the plane rather than the engine, but now that winters here starting to get back into it.
Finished off one of the rocker supports.
and then started on the front crankcase housing.
lump of aluminium turned and bored to shape. Main bearing will be a press fit, front bearing a push fit.
on the vertical rotary table on the mill I cut clearance for the valve sleeve and octagonal face plate.
and drilled and tapped holes for the magnet sensor
drilled the holes for fixing
Craig Booth 130/11/2019 20:04:46
79 forum posts
143 photos
and I couldn't resist putting it together and seeing what it looked like on the plane laugh
cowbells
Ausee.com.au
TRANSWAVE Converters
Meridienne Dec 4th 2019
