What are these used for please?
Rockingdodge07/07/2019 12:21:01
210 forum posts
35 photos
Hi, these were amongst some items bought and I'm not sure of their purpose. Gentleman was an engineer and clock maker.
Item 1:
Left hans one has BA sizes on it.
Item 2:
Made in USA, Industro
Item 3:
I don't know if this is complete, about 3" is size, one part is hinged but certainly not a knurling tool for the lathe, but could be wrong smiley
Thanks
Roger
not done it yet07/07/2019 13:52:31
4629 forum posts
16 photos
If you had said a mechanics tool box, I might have suggested that the two on the right of the first pic were part of a tube flaring kit (as in brake pipes in common sizes).
Clive Hartland07/07/2019 13:58:44
2559 forum posts
40 photos
The first 3 items are for cutting short screws and then dressing the ends square and clean.
Rockingdodge07/07/2019 14:16:15
210 forum posts
35 photos
That did cross my mind and might be right for the 2 on the left but haven't seen pipework in as large sizes as that though
Rockingdodge07/07/2019 14:18:56
210 forum posts
35 photos
Posted by Clive Hartland on 07/07/2019 13:58:44:
Wouldn't they have have needed to have threads in them for that purpose though?
Swarf, Mostly!07/07/2019 14:30:44
528 forum posts
47 photos
In a ribbon microphone a metallic ribbon is suspended between the poles of a permanent magnet. To give the ribbon compliance in the appropriate axis, it is usually corrugated.
The gizmo with the two gear wheels hinged together could be used to form suitable corrugations.
I believe that there was also a ribbon loudspeaker offered on the hi-fi market at one time.
Best regards,
Swarf, Mostly!
peak407/07/2019 14:41:43
1093 forum posts
124 photos
I've no sense of scale for No.2, but it looks like a punching or embossing tool, for a series of dents or holes along the middle of a strip of something.
Holes in watch straps maybe??
Bill
Rockingdodge07/07/2019 14:52:46
210 forum posts
35 photos
Sorry, never thought blush
Roger
Michael Gilligan07/07/2019 15:01:45
15663 forum posts
682 photos
Indestro : **LINK**
https://www.madeinchicagomuseum.com/single-post/indestro-duro-metal
Rockingdodge07/07/2019 15:34:29
210 forum posts
35 photos
Haha Michael beat me to it laugh
Thanks everyone, 1 down, i possible, 1 to go.
Roger
Hopper08/07/2019 08:23:28
4513 forum posts
94 photos
First pic looks like typical apprentice projects: stud clamps for holding threaded or non-threaded studs while end is filed or by the look of the hacksaw marks, screwdriver slot is cut in the end of the stud. No thread is needed to hold threaded studs in the split type clamps on the right.
Clamp is held in the vice while stud is filed or cut. Can be used to hold studs or punches while the end is shaped etc for special jobs.
Edited By Hopper on 08/07/2019 08:25:02
Russell Eberhardt08/07/2019 09:59:53
2577 forum posts
85 photos
The second two items in pic 1 are clockmakers' split stakes. Commercial ones are usually made of brass. The first one is probably for slotting screw heads.
https://www.amazon.com/Clockmaker-Split-Stake-Watch-Wheel/dp/B000RB5KUC
Russell
Edited By Russell Eberhardt on 08/07/2019 10:03:55
KWIL08/07/2019 11:59:58
3231 forum posts
63 photos
I have a ribbon microphone but the corrugations are not as fine as Swarf, Mostly suggests.
Watford08/07/2019 14:34:23
128 forum posts
11 photos
Are the two on the right possibly for drawing down wires?
M
Russell Eberhardt08/07/2019 15:51:29
2577 forum posts
85 photos
Posted by Watford on 08/07/2019 14:34:23:
M
They are used for supporting clock parts while working on them. For example while staking new trundles into a lantern pinion.
Russell
jason udall09/07/2019 08:05:45
2024 forum posts
41 photos
Item three.... knurling tool of some scale
Neil Wyatt09/07/2019 16:43:35
17868 forum posts
704 photos
77 articles
Not necessarily specific to clock making, they are just a way of holding thin rods in a vice without damaging them.
Russell Eberhardt09/07/2019 20:50:07
2577 forum posts
85 photos
Posted by Neil Wyatt on 09/07/2019 16:43:35:
True, I've found lots of other uses for mine when working on small parts.
Russell
