LBSC Britannia Design
Expansion link fowling lift arms
WorkshopPete06/07/2019 08:57:56
84 forum posts
Hi All
Several year ago I purchased a finished 3 1/2" LBSC Britannia chassis the craftsmanship is good but the painting and general state is poor requiring a full strip down cleaning and painting. The one thing I have noticed is that the leading end (The part with the short drop link attaching to the valve rod) fowls the top forward corner of the expansion links. My question, is this a known fault or is there something wrong with this build. Since I am going to totally strip the chassis down once i have built the boiler (which is now 50% finished) any modification should not be a problem. Thanks
Peter
Boiler Bri06/07/2019 10:25:05
839 forum posts
199 photos
Hello Peter.
I was was directed to the modelemgineering clearing house website ( http://modeleng.proboards.com) when I had specific model loco questions. There seem to be a bigger following for locomotives on that web site.
At the time the direction annoyed me as the LBSC locos were published in Model engineer. I hope I do not annoy you in the direction pointed.
WorkshopPete06/07/2019 11:08:20
84 forum posts
Thanks Brian
Have just posted on that site they seem to have a 3 1/2" Britannia specific Board excellent - wait and see.
Peter
Brian G06/07/2019 11:20:47
757 forum posts
34 photos
In an earlier thread **LINK** on the Britannia (my son has a part-built Evening Star which has a similar boiler) I found a link to smalllivesteamengines.fandom.com/wiki/Britannia_(3.5_gauge) "Some concerns have been raised with regards to the assembly of the expansion links and trunnions. Perhaps not surprising if LBSC's own loco really did have outside Stephenson's gear? modeleng.proboards.com/thread/5034
Brian (a different one)
WorkshopPete06/07/2019 12:32:31
84 forum posts
Thanks Brian
I have looked through a number sites and none seem to mention my problem which leads me to believe its a building rather than a design error. The boiler is a challenging build I have had a number of discussions with our boiler inspectors and have sorted to their satisfaction the barrel outer wrapper joint which is now complete.. I tried the boiler onto the chassis and when hard up against the smoke box the throught plate touches the rear coupled wheels my chassis came fitted with a spacer piece/ring between smoke box and the boiler barrel about 1/2" wide to correct this so no problem. It looks like this build is going to be a test.
Thanks again
Peter
JD Metals
