Treppaning a flywheel
Tool Profile?
Iain Downs03/07/2019 08:12:28
558 forum posts
444 photos
Hi, All.
I'm in the process of building a flywheel for my vertical engine (covered in more detail elsewhere).
I have a 25mm piece of 150mm cast iron bar. I've mounted it on the faceplate by drilling some counterbored holes and bolting it to the face plate with some washers as stand-offs (about 5/6mm depth).
I've faced off and skimmed the outside.
Now I want to dig out the bits in the middle.
I've made a trepanning tool. The outside edge is covered to go inside the other radius (at about 55mm radius of the bar). The inside edge is more or less vertical. The end relief is probably about 10 degrees and the top rake the same. End width is about 4-5 mm (sorry don't have the tool in the house to measure at the moment).
I'm trying to cut at about 55mm radius, which is just outside the counterbored holes. I would have liked the outer rim to be thicker, but I figured that treppaning with an interrupted cut was just asking for trouble.
lathe is a REal Bulk CJ18A (500W 7x14 ish)
What am I seeing?
1. the best 'cut' is producing a fine dust, not chips.
2. I have to feed VERY carefully or the tool jams.
3. When performing the cut, it makes quite a noise.
4. If I pull out and widen the slot, I actually get chips from the 2mm cut so the tool is reasonably sharp (I keep sharpening it with a stone as well as attempting to tune it on the grinder).
5. There is often a resonance that roughly matches the rotation of the lathe. I've seen this on a lot of cuts. I can take very fine cuts until the resonance flattens out but it comes back.
6. I've tried speeds from about 100 rpm up to about 300. Lower than 100rpm and the lathe doesn't have the power to do anything. Above 200 I don't seem to get more cutting, but if I get a jam it worries me more.
7. I've put some side relief on the tool and as far as I can tell it's not binding, however, it starts to complain at about 0.5mm depth.
8. It's not helping that the saddle lock ( on to the leadscrew) seems to release from time to time meaning that the saddle creeps back rather than the tool forward.
9. I have the feeling that if the lathe had more grunt and more rigidity then this would go MUCH more smoothly!
10. After about one and a half hours of tender tool pushing, I've excavated a channel 4 mm wide and 4mm deep. I need to take 15mm deep out, excavate from 16mm to 55mm then turn it over and take out 5mm on the other side.
11. I've tried using some cutting oil, but that just clogs the dust together and makes a jam more likely.
I don't know if I should try getting rid of the top rake to stop it digging in, or increase it to make the cut better.
I've wondered about making the tool thinner so there is less cutting area, but that will also make it more fragile.
Trepanning is not much mentioned in the books I've got - and not much on the web either (except for some toolmaker videos where it's terribly easy if you have the right (expensive) tools and a big lathe)..
I'm thinking that putting it on a rotary table and milling it out might make more sense, but mounting it would be an interesting challenge.
Any help (links I've missed, pointers, tool profile, commiseration) would be appreciated.
Iain
JasonB03/07/2019 08:20:51
17089 forum posts
1839 photos
Make the tool about half the width you have now, you would not try to take a 5mm deep cut with a normal tool at that diameter so why do it with this one. Move it sideways every so often to make sure the tool has good clearance.
The other question is why trepan out the middle? can you not just make it thinner and leave a hub then cut spoke shapes into the thinner area?
Hopper03/07/2019 09:12:07
3991 forum posts
85 photos
Pics sure would help. Having trouble visualizing what what you are trying to do, and like Jason, why.
Ian S C03/07/2019 10:58:28
7468 forum posts
230 photos
I agree with Jason and Hopper. I usually dig out as much as I can with an ordinary general purpose tool, then clean up with a boring bar, and using the same tool I do the hub by going past centre, and run the lathe in reverse (very carefully, I have a screw on chuck).
Ian S C
Mick B103/07/2019 11:17:36
1364 forum posts
75 photos
My first thought would be to reduce the top rake - I've generally used 0 degrees for CI and brass if the tool was made for that material. You can get away with a general-purpose tool with top rake on less demanding cuts, but trepanning's a bit different.
Secondly I'd agree with Jason about reducing the width, though I dunno if I'd halve it.
Is there a curve on the front cutting edge? I'm not sure if it's actually necessary, but I've always used one and trepanning *normally* works OK for me...
Iain Downs03/07/2019 18:14:35
558 forum posts
444 photos
Thanks to all...
I wonder if I'm using the wrong terminology.
This is the thing I'm trying to make.
A model of it anyway. There's also a recess on the back side, but 5 mm deep not 15 (though this is a manufacturing requirement rather than a design requirement. I think).
This is where I am.
I'm digging into the face with the trepanning tool and then was going to go sideways probably with a right hand knife tool.
MOst of the progress you see there was actually with a knife tool with at an angle digging in a bit and then to the right, followed by a knife tool the other way to the left.
Iain
JasonB03/07/2019 18:18:45
17089 forum posts
1839 photos
For something like that round the tool and work back and forth across the face while slowly putting on the cut.
martin perman03/07/2019 18:45:16
1738 forum posts
70 photos
I recently made four rollers, also similar to yours in size, I used a round insert tool set up similarly to yours I also had 45 deg set on the top slide because the outer edge needed a 45 deg on it, To give me a guide I blued up the face to see where the two edges were then plunged in up to 1mm with the traverse then used the crossslide to move to the boss in the centre and treversed out. This was done until I had gone in up tp 5mm deep, it took a while but worked well.
Martin P
Edited By martin perman on 03/07/2019 18:46:26
Michael Gilligan03/07/2019 18:52:36
14784 forum posts
635 photos
Posted by Iain Downs on 03/07/2019 18:14:35:
A toolpost-mounted milling spindle would do that nicely
... but it's another project, or another purchase [story of my life]
Edited By Michael Gilligan on 03/07/2019 18:53:42
ANDY CAWLEY03/07/2019 19:09:22
145 forum posts
42 photos
Trepanning is a operation that I carry out occasionally. f9644aa1-c052-49ef-afe4-aa0d6adcefcf.jpeg
I do this to a 3/4" pitch plate wheel which is then bolted to a carrier, the finished article is shown above.
I carry out the operation on a fairly heavy duty CVA lathe using the tool shown below.
(This picture is upside down.)
I cant remember how wide the cutting edge is but 4 mm would be about right, every time I do the job I consider reducing the width but never quite get round to it. I wouldn't dream of putting the tool to the job without a full flood of coolant.
Somehow or other this picture has got upside down!
I cut at fairly slow speed to start with speeding up as I get more confident. I hone the cutting edge and maintain it sharp.
The whole operation is conducted with tightly clenched cheeks and I'm glad when its finished. The material from which the platewheels are made is, I believe, En8.
Edited By ANDY CAWLEY on 03/07/2019 19:10:57
Stuart Bridger03/07/2019 19:39:23
387 forum posts
23 photos
+1 on a round insert tool. Had to grind a bit of extra relief so the bottom of the holder didn't foul.
Andrew Johnston03/07/2019 20:01:40
5115 forum posts
594 photos
I'd agree that it would have been better to trepan first and drill holes later. For the trepanning I'd use a multi tool approach.
First I'd grind a short "parting" tool from square HSS with the necessary clearance on the outside, say a 6mm deep blade and 3mm wide. Then I'd plunge in 5mm near the outer diameter, move across 3mm and plange again and so on until the inner diameter is reached. Then repeat twice to get near the 15mm depth. Of course you won't be able to get right into the inner diameter on the second and third cuts.
Finally I'd clean up the inner and outer diameters and the bottom of the groove using L& R knife tools, or L&R boring bars in my case as I don't have matching knife tools.
For cast iron I'd add a little top rake to the tool, a few degrees.
JasonB03/07/2019 20:13:20
17089 forum posts
1839 photos
If you can run your lathe in reverse you don't even need to bother with left and right hand tools. Just do most of the recess and outer edge with the lathe running forwards and then finish the hub with the tool behind it and running in reverse., did this 4" CI one that way with the tool set at a slight angle so it easily reached into both the corners which saves having to grind excess clearance
SillyOldDuffer03/07/2019 20:21:38
5141 forum posts
1074 photos
Posted by Stuart Bridger on 03/07/2019 19:39:23:
...Had to grind a bit of extra relief so the bottom of the holder didn't foul.
Relief is important when trepanning because there's a good chance the tool will foul the work and it gets worse the deeper you go.
An ordinary parting-off tool collides rather quickly:
For this kind of job I would hack out the centre with a point-first square insert leaving a 45° chamfer on both sides. Then square the chamfers off with right and left hand knives.
Iain Downs03/07/2019 20:22:42
558 forum posts
444 photos
So, I will thin the tool and reduce the top rake and see how that goes.
Whilst my lathe runs in reverse, the cross slide doesn't go past the centre, though that would be a nice thought.
The holes were only drilled because I could think of no other way of holding the piece. Neither of my chucks come close.
Ah, damn. It's just occurred to me that i could have glued it to a base of some kind. That would have made much more sense.
Great advice as usual, but a bit too late to action tonight...
Iain
martin perman03/07/2019 20:58:50
1738 forum posts
70 photos
Silly me, I forgot to mention about the tool relief underneath.
Martin P
Stuart Bridger03/07/2019 21:57:19
387 forum posts
23 photos
Glanze Circular insert toolholder with extra relief (roughly) ground. Shown with unfinished flywheel for barstock Elmers Mill Engine. Big advantage of the round insert is that you can turn both the inside of  the rim and the internal boss with the same tool.
Edited By Stuart Bridger on 03/07/2019 22:10:27
Neil Wyatt03/07/2019 22:22:34
17097 forum posts
690 photos
76 articles
I have done this job as Jason suggests - working a round tipped tool side to side. Works even better if the end of the tool is notched slightly.
If necessary leave the outer radius tapering (that is don't go to the full radius, with each cut do a slightly smaller diameter). Tidy up with a boring bar at the end. Sort of how I did this from a laser cut blank, but used a large radius tool to do the internal corners.
Iain Downs06/07/2019 11:11:17
558 forum posts
444 photos
As usual great advice.
The key was to take off the top rake. It's now 0 degrees - well, it might be one degree as per Andrew's suggestion, my hand grinding's not that precise. But it's no longer 10.
I reckon the rake was making the tool dig in and catch which was the heart of the problems.
Still requires a good deal of delicacy.
I could only get in about 1mm without it starting to jam, even though I'm convinced the relief was adaquate (and I kept tuning it), but in this case I didn't need a narrow slot so just plunged in next to it.
I also had a bit of a go at the point technique once the trough was done to start taking the bulk of the metal off.
As you can see it's starting to come together!
Iain
ANDY CAWLEY07/07/2019 10:59:14
145 forum posts
42 photos
Were you absolute fastidious about making sure the tool was plunging into the work piece at bang on 90 degrees. If you got it only very slightly out it starts to bind and that’s that‼️ Don’t ask me how I know🙄.
Edited By ANDY CAWLEY on 07/07/2019 11:00:01
