Injector help
Brian Abbott30/06/2019 23:07:09
453 forum posts
88 photos
Hello all.
Need some help if possible.
Are the union nuts and nipples used for normal fitting the same as you would use to connect an injector?
Also.
are both horizontal and vertical injectors the same in terms of performance?
Thanks,
Edited By Brian Abbott on 30/06/2019 23:27:48
David George 102/07/2019 20:22:04
1303 forum posts
447 photos
Bump
David
Brian Abbott02/07/2019 22:49:40
453 forum posts
88 photos
Since found out the following, not sure if its correct but..
Steam inlet and outlet are normally the flat type, water feed can be coned or flat, depends on the injector..
Regards the performance of the injector i don't think it makes any differance.
Thanks.
Paul Lousick03/07/2019 07:51:01
1496 forum posts
570 photos
On LSM injectors all ports have a flat type adaptor fitting where the tube is soldered to the fitting. Photo of injector with 5/16" tube fittings shown below.
Note: They are advertised as used with 5/16" pipe which is technically incorrect because pipe is specified by a nominal bore and not its outside diameter. Tube is specified by its OD and these injector adaptors have a 5/16" bore. (Sorry about the rave)
Paul
Brian Abbott03/07/2019 23:15:30
453 forum posts
88 photos
Hello Paul.
What size injector is that one ?
Paul Lousick04/07/2019 03:44:42
1496 forum posts
570 photos
Injector is a LSM No 7 injector rated at 5 pints/minute.
Paul
EngineDIY
