lfoggy | 29/06/2019 11:32:11 |
![]() 179 forum posts 17 photos | I've recently purchased two slitting saws from different well known UK model engineering vendors. Both were 4 inch in diameter with a 1 inch bore and widths were 2.5mm and 3/32. Both saws were significantly out of true when rotating, one by 0.9mm and the other by 0.5 mm. My arbor has a negligible degree of runout so the problem is the bore of the saw is not concentric with the periphery. That degree of eccentricity means that they only cut on a small proportion of the teeth. Useless really. How can this degree of inaccuracy even happen in the manufacturing process? I would have thought the blade is mounted by the central bore for the final grinding of the teeth... Anyway, they were inexpensive saws at less than £10 each so maybe this is a case of 'you pays your money and you takes your choice'. All the other saws in my collection come from old UK made stock and run perfectly true. Industrial suppliers charge 3 to 5 times more for new sliiting saws but maybe thats what you have to pay?
Nick Hulme | 29/06/2019 11:35:53 |
750 forum posts 37 photos | Buy cheap, buy twice (or more) |
Andrew Johnston | 29/06/2019 11:50:29 |
![]() 6574 forum posts 701 photos | Why bother investing in expensive grinding machines when the saws can be "finished" by hand and still sell? I don't know which vendors were used, but I'm very selective about which ME vendors I use. Most of my cutting tools are bought from industrial suppliers. An exception would be premium items from Arc. Andrew |
Ron Laden | 29/06/2019 12:01:21 |
![]() 2297 forum posts 452 photos | I have two slitting saws a 1.00mm and a 1.5mm and they are probably in the price range you paid, possibly the same supplier. Both of them have a 0.5mm run out which is obviously not ideal but I have to be honest both of them work fine, I have had no issues at all cutting with them. Ron |
not done it yet | 29/06/2019 12:43:25 |
6716 forum posts 20 photos | Ahh, so not cutting a wider slot than design. Eccentric rather than wobbly. That’s OK, - well par for the course - as many cheap slitting saws only cut (to the maximum depth) on part of the circumference. Look on it as paying the same as a better quality item which uses (and wears) rather more of its teeth than yours. On yours, some teeth will be cutting and possibly some only rubbing (which blunts them quite prematurely). So likely good enough for a single job but not so much longevity, if used regularly and/or often, than a higher quality one. The wobble saw I used cut a slot from blade kerf to about 10mm wide, depending on how it was set. Likely need an eccentric arbor, with appropriate run out, so the saw can be turned to accommodate the eccentricity. Don’t think I would bother. |
Michael Gilligan | 29/06/2019 14:18:43 |
![]() 20052 forum posts 1040 photos | This very recent thread might be of interest: **LINK** https://www.model-engineer.co.uk/forums/postings.asp?th=142966 'though, inevitably, there was no definitive conclusion. MichaelG.
lfoggy | 29/06/2019 14:50:16 |
![]() 179 forum posts 17 photos | Thanks for the comments. I couldn't be bothered to return them so I used a carbide tipped boring bar to relocate and enlarge the bore to 26.5mm. Made another arbor out of an R8 blank I had and they now run very true and cut ok. I suspect my 26.5mm arbor will come in useful again sometime. |
Michael Gilligan | 29/06/2019 15:46:13 |
![]() 20052 forum posts 1040 photos | Nice one MichaelG. |
Watford | 29/06/2019 22:11:17 |
![]() 141 forum posts 11 photos | On the subject of slitting saws I am having difficulty sourcing a very small example. I need a 1/2" dia. x 1/16"wide saw to produce a key-way in the crankshaft of a Channel Island Special 10cc. I require to get up very close to the crank web without marking it. Can any kind soul point me in the right direction, please?
Mike |
Emgee | 29/06/2019 23:18:14 |
2404 forum posts 285 photos | Mike You could make a cutter from Silver Steel and harden it before use, for a 1 off or a few shafts it should be OK. Emgee |
pgk pgk | 29/06/2019 23:41:12 |
2549 forum posts 293 photos | Posted by Watford on 29/06/2019 22:11:17:
Mike That's a tiny diameter. Have you considered some sort of dental bur presented at an angle? The problem is the obvous one of controlling the thing but if you have a compressor the high-speed handpieces and burs aren't that expensive but creating a fixture to hold it would be entertaining.
pgk |
speelwerk | 30/06/2019 00:17:16 |
439 forum posts 2 photos | Posted by Watford on 29/06/2019 22:11:17:
On the subject of slitting saws I am having difficulty sourcing a very small example. I need a 1/2" dia. x 1/16"wide saw to produce a key-way in the crankshaft of a Channel Island Special 10cc. I require to get up very close to the crank web without marking it. Can any kind soul point me in the right direction, please? Mike Fraises & Outils SELECTION SA, Zwitserland, https://guye-outils.ch/presentation.php?lang=en nr. 500.0121705 has a diameter of 12 mm but thickness of 1.70 mm. They probably will alter the thickness for you if you ask but will be costly. Alternatively you can clamp a thickness of 1.00 and 0.55 mm together, it will create a wobble but not much because of the small diameter, probably around 0.02 mm. But you have to try first to determen if it is OK. Niko. Edited By speelwerk on 30/06/2019 00:19:45 Edited By speelwerk on 30/06/2019 00:20:30 |
Chris Trice | 30/06/2019 01:12:13 |
![]() 1375 forum posts 10 photos | I'll probably get vilified for sounding like a broken record but I've found the cheap import ones are the worst offenders by far. I usually end up making a wide arbor to grip the cutters nearer to their periphery but of course you lose cutting depth.
JasonB | 30/06/2019 07:00:55 |
![]() Moderator 22555 forum posts 2634 photos 1 articles | Watford, can you not use a 1/16" x 1/2" woodruff cutter, I've used this type of cutter to put keyways into IC engine crankshafts. You want a No204 Edited By JasonB on 30/06/2019 07:01:54 |
Watford | 30/06/2019 10:44:04 |
![]() 141 forum posts 11 photos | Thanks Jason, you are indeed a star. I was missing some lateral thinking - not unusual for me. Working on an original Jensen kit, purchased in 1949 by a now deceased friend. Rescued from the top shelf of his workshop, and which had had very little work completed.
