Solid carbide end mills
John Rutzen24/06/2019 09:23:59
189 forum posts
2 photos
Has anyone used miniature [1/8] solid carbide end mills for cutting ports? I have some ports to do and thought about buying one of these. My FC3 cutters are a bit blunt. I may have a go at sharpening them on my Quorn but it's getting a bit small to see what I am doing.
Baz24/06/2019 09:29:38
360 forum posts
I have used 2mm and 3mm solid carbide cutters with great success for cutting ports, I obtained my cutters from Arc Eurotrade and was pleased with both the quality and speed of delivery, no connection to company just a very satisfied customer.
David George 124/06/2019 09:45:41
1197 forum posts
409 photos
I use them all the time especially on hard steel and castings which may have hard spots etc just run them at a slight faster speed it helps.
David
HOWARDT24/06/2019 09:53:07
539 forum posts
15 photos
I decided to make my own loco wheels from solid rather than using cast so have milled eighteen spoked wheels. Used 3 mm carbide initially for finishing but found the speed on the SX2P limiting and bought HSS in packs of ten from Amazon, worked well enough to convince me that HSS was my better option. I did break a number but at the price I wasn’t bothered and most broke due to the rough cut out causing too big a cut and poor swarf clearing in the setup.
Ron Laden24/06/2019 10:33:21
1880 forum posts
347 photos
Not 3mm but I was using a 4mm solid carbide on steel yesterday, it was a 2 flute really intended for aluminium but it was the only 4mm I had. Ran it at 2500 rpm and 20 thou cuts with no problems at all.
John Rutzen24/06/2019 13:36:46
189 forum posts
2 photos
Hi, thanks that's good feedback. I was worried about breaking one in the port because they are very brittle.
Nick Hulme24/06/2019 18:22:55
743 forum posts
37 photos
Check manufacturer's recommended speeds, if you can't achieve them you will just abrade your endmill.
I've used 0.6mm carbide endmills but at 30000rpm and could probably have used a bit more speed.
John Rutzen24/06/2019 21:23:41
189 forum posts
2 photos
my Amat 25 mill does 3000 rpm on high speed and 1500 on low speed. I don't know what the recommended speed for a 1/8th cutter on gunmetal would be. It would be 3200 rpm with HSS on mild steel. Tubal Cain says feeds must be kept up with mills or they just rub. On this basis most of us shouldn't mill ports at all!
old mart25/06/2019 19:40:13
1553 forum posts
136 photos
FC3 cutters are throwaway cutters.
With small cutters, you use the best speed the machine is capable of. The mill I use only makes 2100 rpm, but it doesn't stop me using 3mm solid carbides occasionally.
Neil Lickfold25/06/2019 20:23:09
594 forum posts
102 photos
What ruins small carbide cutters is sudden jerky movements , like from backlash in the table, or just not winding the table at a uniform rate. Small cutters is small feed rates. They still cut even at 1200 rpm. The other important aspect is removing the very small swarf . So having the shopvac close to the cutting area to vacuum up the stuff and a valve from an airline hooked up to be blowing a small amount of air onto the cutter is also very effective in removing the swarf from small cutters. This will extend the life of the cutter considerably. I find air to be better than using loads of coolant on small cutters.
John Rutzen26/06/2019 08:22:07
189 forum posts
2 photos
Can you still get FC3 cutters? I couldn't find any. Thanks for the advice to blow away the swarf, I'll try to rig that up. I have always used a paint brush to brush it away but that would be a better idea. I've ordered a carbide cutter and will try it on a bit of scrap first.
JasonB26/06/2019 08:28:02
17874 forum posts
1954 photos
1 articles
Plent of FC-3 type cutters about. MSC Direct usually have them on offer for about £5 a piece, similar from Cutwell.
Edited By JasonB on 26/06/2019 08:32:07
Andrew Johnston26/06/2019 08:55:41
5422 forum posts
629 photos
It's rare day when I use small HSS milling cutters. Here's a 4mm carbide cutter machining a cast iron bevel gear:
After Final Cut
There will be no problem using a carbide cutter to form ports. They have a high Young's modulus so don't tend to bend but will snap if mistreated.
The term solid carbide is incorrect. The tools are formed by sintering tungsten carbide in the form of a fine powder in a matrix of cobalt.
Michael Gilligan26/06/2019 09:37:41
15493 forum posts
670 photos
Posted by Andrew Johnston on 26/06/2019 08:55:41:
... or perhaps just 'open to interpretation'
I believe that the term came into widespread use to distinguish these cutters from those with steel shanks and brazed-on tips.
John Rutzen26/06/2019 13:36:59
189 forum posts
2 photos
I got my carbide end mill in the post today so will try it out .
