Forum sponsored by Allendale Oct 22nd
DTI identification
Steve King 520/06/2019 19:35:34
55 forum posts
76 photos
Hi all
I have the DTI but it doesn't say if its metric or imperial nor does it say what each increment is. Its very heavy and feels smooth so I'm hoping it's a good quality one.
Can anyone help.
Steve
JasonB20/06/2019 19:40:37
16270 forum posts
1721 photos
1 articles
Why not mount it on your lathe or mill and move a handwheel by a known amount and see if the dial reads that amount in metric or imperial
Michael Gilligan20/06/2019 19:52:30
14015 forum posts
608 photos
Catalogue of the more modern ones, is available:
Search for Rambold precision dial gauges and accessories
... I don't know Rambold, but they look promising.
XD 35120/06/2019 19:56:10
1326 forum posts
112 photos
I will have a guess and say a tenths indicator with a total travel of .020 inch but the only way to be certain is to do what Jason said and compare it with the movement of a graduated dial like a lathe cross slide or you could set it up in an indicator stand on a flat surface so the nib is vertical and touching said flat surface and slip a feeler gauge between the nib and the flat surface .
Have a look on the long island indicator website as they may have some info on that make of indicator .
Andrew Johnston20/06/2019 20:07:02
4855 forum posts
544 photos
I'd be inclined to say metric +/- 10mm with each small division being 0.01mm. However, look at how much the nib is sticking out; which will equate to the total travel, that'll tell you if it's +/- 0.01" or +/- 10mm.
Is it an indicator or a test indicator? The former have a shaft that moves in the vertical direction, the latter normally have a moveable lever that can move in any position it is set.
old mart20/06/2019 22:00:38
580 forum posts
54 photos
Metric ones are commonly yellow.
Steve King 521/06/2019 08:11:07
55 forum posts
76 photos
Think its metric as it does not line up when mounted to my lathe as suggested by JasonB.
If any one wants to swop it for a imperial equivalent drop me a message.
Steve
JasonB21/06/2019 08:25:37
16270 forum posts
1721 photos
1 articles
There should not be much thinking about it.
If your lathe is imperial put on 0.050" feed and if the dial goes round 5 times it is imperial. If the dial goes round once plus 27 divisions it is metric as 50thou equals 1.27mm
If it is more sensative and does not have that range of movement try 0.005" feed
Steve King 521/06/2019 08:37:32
55 forum posts
76 photos
Thanks JasonB
Its metric 0.050 equal the one full rotation plus 27 divisions.
Thanks for helping out the novice its much appreciated .
Steve
John Haine21/06/2019 10:14:41
2609 forum posts
133 photos
99% of the time one uses a DTI as an indicator, e.g. of runout or misalignment of a vice with a mill axis, and the measurement uints are irrelevant as you only want to get zero movement.
Steve King 521/06/2019 10:34:38
55 forum posts
76 photos
I plan on using the DTI like this
Nicholas Farr21/06/2019 10:36:16
1976 forum posts
936 photos
Hi, it is quite possible that it was for use in a quality control as a comparator. Either it may have been to match parts in pairs or set amounts, or to check on production runs, either way the operator would not need to know any measurement as such, but would set the test machine to a master and compare the tolerances for production runs, hence the zero being in the middle of the stroke.
Just my thought the reason that it doesn't indicate mm or inches and the fact the little 10-0-10 dial would suggest it being used horizontally..
Regards Nick.
John Haine21/06/2019 11:43:04
2609 forum posts
133 photos
I think DTIs are intended for use as comparators, not accurate or indeed precise measurement. Their calibration is ultimately dependent on a rack-and-pinion, not a precision thread or transducer. They do have high resolution, for example indicating 0.01 mm/division, but one division will not necessarily be 0.01 mm if you see what I mean. Though it would probably do the job in the application you show, for best accuracy you would be better using for example a DRO.
In the language of this a DTI has high resolution but is not very accurate or precise.
Steve King 521/06/2019 12:03:25
55 forum posts
76 photos
I'd love a DRO but even the cheapest Chinese one are hundreds and I only have tens hahaha. Maybe one day.
Steve
old mart21/06/2019 16:47:55
580 forum posts
54 photos
If I'm not mistaken, that lathe you have is a S & B model A.
Steve King 521/06/2019 16:52:48
55 forum posts
76 photos
That's correct a mk2 I believe
TRANSWAVE Converters
Meridenne Boat 2019
Ausee.com.au
cowbells
