Metal Bandsaw - Chester H80 or Warco CY90
Lainchy18/06/2019 08:34:44
270 forum posts
103 photos
I'm looking at saws... Trying to kit out a new noobs workshop, and it's become very apparent that I'm going to need a saw, or get lots of exercise with the hacksaw!
I am looking at either the Chester or Warco metal cutting bandsaws as no one seems to do powered hacksaws now - that I can find anyway.
Anyone got the small Chester or Warco Bandsaws? How do you get on with them?
Many thanks
Ian
Trevorh18/06/2019 08:51:33
303 forum posts
87 photos
Morning Ian, I have the Warco CY 90 and not had any issues after I re aligned the main drive wheels for the saw band and adjusted the the blade guides to cut vertical
I have cut quite large dia bar both ally and BMS with no problems
Had the saw now for a good many years
cheers
Trevor
Plasma18/06/2019 09:10:06
443 forum posts
Depends on proposed use I guess.
Many favour a bandsaw but I love my donkey hacksaw.
I have a six inch and a four inch just for good measure.
There are plenty od used ones out there with more than enough life in them.
Mick
John Hinkley18/06/2019 09:24:06
1188 forum posts
392 photos
What Trevor said. Don't expect it to cut true straight out of the box. Most, if not all, will reuire a little tweakery to cut square and vertical. I would also recommend fitting a bi-metallic blade. They are, in my opinion, superior to the factory-fitted one. Tuffsaws supplied mine and I've had no trouble over the last eight years of ownership.
Fowlers Fury18/06/2019 09:25:13
387 forum posts
88 photos
" no one seems to do powered hacksaws now - that I can find anyway. "
Perhaps not strictly true?
Like "Plasma", I favour a powered hacksaw.
Blackgates offer a machined kit but you will need a motor & a few other bits. I've had mine for years and since it takes standard hacksaw blades, it's quick & easy to change them over when cutting different materials. The capacity isn't huge but it'll cut through 1.5" bar stock if pressed.
not done it yet18/06/2019 09:40:08
6350 forum posts
20 photos
Ian,
Whether you actually need one or not may depend on how big the starting pieces might be and how many you need to cut. Other factors, such as physical ability, may also require consideration.
Smaller diameter (up to 40 mm) cuts were discussed in a fairly recent thread. Alternatives abound.
I would guess that most get on OK with either, but a considerable minority would have found it necessary to ‘tweak’ them or make repairs fairly early in the life of the machine.
The ratio of replies on a forum may not be too indicative of the real situation as many do not cut so much - and those with failures tend to be more vocal than the quietly satisfied group.
Alternatives should certainly be included in the original request, if at all green on the topic.
Frances IoM18/06/2019 09:51:00
1164 forum posts
28 photos
I have a H80 - works well enough - there are many small improvements online or in MEW re improved holding of the metal to allow smaller pieces to be cut etc - the supplied stand is pretty useless but can be improved - use bimetallic blades and spend some time setting it up then you will get very acceptable results up to its recommended limits 80mm pushable in one dimension to about 100mm.
Lainchy18/06/2019 09:56:02
270 forum posts
103 photos
Superb as usual guys. I guess I just missed the mentioned thread, so many thanks for that. Food for thought indeed!
larry phelan 118/06/2019 10:27:15
1095 forum posts
14 photos
I bought a saw from Chester many moons ago and don't recall having any real problems with it. I have cut everything from 6mm round up to 4" round,6"x3" RSJ and everything inbetween including angle ,tee and channel and whatever comes along. If you are cutting mitre cuts ,don't depend on the scale on the machine, since none of those scales are very accurate even on table saws. Better to use a protractor, this will give better results.
All in all, for the price of these machine, they give good results [with a good blade ] and I don't think you will be too disappointed with either make [chances are, they both come from the same maker anyway ]
Good luck with your choice.
Lainchy18/06/2019 10:48:43
270 forum posts
103 photos
Thanks Larry. Good point RE the mitre angles... had similar with a circular chop saw!
SillyOldDuffer18/06/2019 10:49:26
7574 forum posts
1681 photos
Posted by Frances IoM on 18/06/2019 09:51:00:
Exactly as Frances said except mine came from Warco.
Appearances are discouraging. Roughly made and put together, mine came fitted with a too-cheap blade that didn't last long. But it works! Bimetallic blades recommended by me too.
Alan Waddington 218/06/2019 11:15:07
523 forum posts
87 photos
Have had a few bandsaws over the years including a large industrial Startrite,
All of the hobby ones ive owned, Clarke, Axminster and one i cant remember, have been to put it politely, ‘Somewhat Frustrating and inconsistent’ in operation, with plenty of fettling to be done from new.
Recently bought a Femi, and can’t recommend highly enough, A quality piece of kit, just does what it should, straight out of the box, work perfectly every time, with no faff whatsoever.
rapid Direct
JD Metals
walker midge
