Forum sponsored by Allendale Oct 22nd
Limitation of a milling machine with low spindle RPM.
Ian Thomson 217/06/2019 13:05:40
59 forum posts
16 photos
I am comparing the specifications of milling machines.
I notice that the gear head mills seem to have a limited top speed of spindle when compared with their electronically controlled equivalents.
For example the GH18 has a top spindle speed of 1420 rpm. The WM18 has a top speed of 2250 rpm.
Is this limitation regarded as a problem when using small cutters in aluminium and brass?
JasonB17/06/2019 13:16:10
16269 forum posts
1721 photos
Small cutters will still cut at the lower speed it just means you can't feed as fast as you would be able to if the cutter were running at it's optimum speed so jobs take longer. You may get a slight drop in surface finish together with a bit more tool wear.
You need to think about what you will be doing the most as the slower belt drive machine will have more grunt a low speeds when using larger diameter cutters, boring heads, saws etc.
Edited By JasonB on 17/06/2019 13:17:57
old mart17/06/2019 13:34:05
576 forum posts
54 photos
The higher speed would be an advantage especially if using small solid carbide cutters. Reducing the feed rate would make up for the lack of speed if need be.
I am facing the opposite problem, The Tom Senior light vertical which I am working on has only 4 speeds, the slowest of which is over 500rpm. A bit fast for larger drills and cutters in steel.
Andrew Johnston17/06/2019 14:43:32
4855 forum posts
544 photos
While in theory it is possible to use small cutters at low rpm by reducing feedrate experience says it leads to broken cutters. The problem with manually feeding at a low rate is keeping the feed constant. It's only too easy to go a bit slow or a bit fast over a fraction of a turn. Too slow isn't serious but too fast can easily exceed the chip load for the cutter. Equals ping and a broken cutter. Been there done that.
Michael Briggs17/06/2019 14:51:58
157 forum posts
9 photos
Re. Tom Senior speed, I have a Senior E that I believe is the same head as a light vertical. I changed the motor to three phase and a vfd, works very well and I seldom have to change the belt position.
Nick Hulme18/06/2019 08:58:51
703 forum posts
37 photos
Posted by Ian Thomson 2 on 17/06/2019 13:05:40:
That's still a low spindle speed, I have an Emco FB2 head which I run at up to 4000rpm and don't consider that as a particularly high speed.
not done it yet18/06/2019 09:53:50
3364 forum posts
11 photos
Posted by old mart on 17/06/2019 13:34:05:
Wow, I would not want to be using any decent sized slitting saw at 500rpm, for a start!
Ian Thomson 218/06/2019 12:42:33
59 forum posts
16 photos
Thanks for replies.
Meridienne oct 2019
TRANSWAVE Converters
cowbells
