Making High Speed Steel Injector D Bits
Stewart Hart15/06/2019 09:53:52
642 forum posts
350 photos
Its usual to make Injector D bits from silver steel by machining the taper on the lathe then sectioning with a file or mill then to heat treat, whilst this method can produce a perfectly functional D bit there are a number of draw backs:- you need a razor sharp turning tool to machine the taper to avoid distortion like wise when it comes to sectioning and heat treating can be a bit hit and miss.
This got me to wondering if it was possible to make some D bits from High Speed Tool Steel in a home workshop.
The starting point was to buy some 5mm Dia HSS tool blanks these were 4" long so I cut them in half then using the hand drill I roughed them out on the bench grinder.
I have a "home Brew" cutter grinder that I put together using commercially avaiable parts:- Grinder, an X,Y Table and a Myford vertical Milling attachment
The first job was to dress the wheel up square to the table, using a diamond.
I have a home made grinding attachment that uses a Er32 collet and an index plate for sharpening end mills by taking the pin out of the index plate I could rotate it by hand. The attachment was set over at the required angle
And the D bit ground to the required angle
To section the bits I first roughed them out on the bench grinder then with a grinding point in the mill set a max speed the Bits were sectioned off to size
I've just used them to make some injector cones and they cut far better than the silver steel bits and it looks like they are keeping their edge well.
Stew
Edited By Stewart Hart on 15/06/2019 10:04:07
Harry Wilkes15/06/2019 10:58:02
924 forum posts
61 photos
Interesting rig you have there yes
H
Simon Collier16/06/2019 02:22:31
353 forum posts
56 photos
I tried something similar a couple of months back69752a73-45e7-4dd1-890c-7a3c0b3b6fac.jpeg
David Wasson16/06/2019 04:25:36
142 forum posts
42 photos
Excellent idea! Injector D bits from solid HSS.
Stewart Hart16/06/2019 08:06:10
642 forum posts
350 photos
Posted by Harry Wilkes on 15/06/2019 10:58:02:
H
Thanks for your interest Harry
Here are some more pictures of the set up.
The grinder it self was quite easy to put together Its just a Myford vertical slide with an ordinary bench grinder mounted on it you have to remove the base of the grinder and do a little rewiring to mount it securely and a X,Y table mine came from axminster but there are plenty of other suppliers of these tables out there. and it all mounted on a bit of ally plate but a friend made one and mounted his on a kitchen work top off cut.
As well as the end mill grinding jig I've also made jig for sharpening slitling saw and lathe tools.
Its far easier to put together than a Quorn cutter grinder or one of the other home built cutter grinders designs around.
Stew
Boiler Bri16/06/2019 08:09:01
835 forum posts
197 photos
Thats great. I am just in the process of drawing up LBSC injectors to have a bash at making some. I was going to ask how to make the reamers.
They will be slightly hollow grinding them on the face of the wheel. They look like they will be sharp.
Cheers
Stewart Hart16/06/2019 08:33:21
642 forum posts
350 photos
Posted by Boiler Bri on 16/06/2019 08:09:01:
Cheers
If your going to try and make an LBSC injector "good luck", I've no doubts that his worked but many have tried and many failed the trouble is that LBSC doesn't tell you exactly how to make them he has had many rants at people who couldn't make them:- all he said if you make them EXACTLY to the drawing and they will work but he doesn't say how to achieve this. Also he published quite a few different design that suggests that he was doing quite a bit of development work.
Can I suggest that you get a copy of Dag Browns Book "Miniature Injectors Inside and Out" its very comprehensive and is a good starting point for any one wanting to make there own injectors, but I find some of Dags, methods long winded and the bodies of his injectors are far to complicated there are other simpler designs around.
These are mine
and a vertical one
Stew
Boiler Bri16/06/2019 17:04:29
835 forum posts
197 photos
Did i rattle your cage or something? I thought i had complimented you?
The drawings in his book, shop shed and road look pretty comprehensive to me, or maybe i have missed something?
Bri
Stewart Hart16/06/2019 19:01:22
642 forum posts
350 photos
Sorry if I gave the wrong impression. But I had a few frustrating days trying to get a lbsc injector working it was only when a friend pointed me in the right direction and gave me some coaching on the subtleties involved did I have some success, there are a number of not obvious features that are critical to function and the only place I’ve seen them dealt with is in Dags book
Stew
Clive Brown 116/06/2019 19:23:52
444 forum posts
14 photos
Laurie Lawence, in his fairly comprehensive series of articles in ME of 1986, suggested that making an LBSC injector that worked was mainly a matter of luck. He saw the design proportions as being satisfactory, but the simplified manufacturing description did not allow consistency.
The DAG Brown book builds on the Laurie Lawrence methods.
Nigel Graham 216/06/2019 19:43:03
667 forum posts
15 photos
I do like that tool-grinder set-up.
Ideal for making D-bits and engraving-cutters, too.
Looks as if would not take much to adapt, by suitable interchangeable brackets etc, to a simple surface- and cylindrical- grinder.
One suggestion I'd make is using thin rubber sheet to make covers for the slide-ways. Garden pond liner off-cuts perhaps: having given my resident frogs a nice comfy home I used some of the surplus butyl liner for a cover to replace that missing from my (2nd-hand) Myford milling-machine.
If I understand his book aright, DAG Brown suggests fitting a miniature loco with two injectors: the usual fairly large one for rapid filling, and a smaller one in place of the axle-pump.
Stewart Hart17/06/2019 08:04:29
642 forum posts
350 photos
I'm pleased you like my grinder set up Nigel.
I have covered the slide ways some time back, I used the lorry curtain side material its ideal for the job.
I've only ever used it for cutter grinding but yes it would be possible to adapt it for surface/cylindrical grinding but just how accurate it would be would be the ?.
The injectors I make have quite a large delivery rate about 24oz. I run my simplex with one of them along with the axle pump the axle pump does the job of a small injector. I'm planning on using two injectors on the Crab I'm building along the lines of Dags suggestion one large one small. I've tried making a 12oz delivery injector using the sizes from Dags book but failed miserably.
I think I failed on a number of accounts, I was far from happy with the reduced size turned D bits, and I used the body and basic cone sizes as for the 24oz injectors and just changed the hole sizes. At some point in the future I will have another go with ground D bits with a smaller body and cones.
Cheers
Stew
Nigel Graham 217/06/2019 08:53:12
667 forum posts
15 photos
The accuracy of your grinder for surface and cylindrical grinding would depend a lot on the rigidity and alignments of the mounting-arrangements, but with the wheel dressed I'd have thought it would be possible to grind to one or two tenths of a thou., and enough for bearing and press fits.
Accuracy in cylindrical grinding might be easier than in surface grinding, but the work would have to be supported and rotated between centres. An area for experimenting anyway.
Regarding scaling down the injectors, I am not a hydrodynamicist but I wonder if the problem is not the body size, just the cone sizes and the cross-sectional areas of the water-ways. I'd look at the dimensions of the ball-valve carefully too, for lift as well as annular area.
Also, does the surface finish within the cones matter? Would the smaller cutters need a lapped rather that simply ground finish?
Andrew Johnston17/06/2019 09:30:28
5549 forum posts
650 photos
Posted by Nigel Graham 2 on 17/06/2019 08:53:12:
Like this:
It's interesting to note that the tables on my grinders are not constrained, just resting on the ways. So in that sense they're not particularly rigid. Grinding forces are low and accuracy comes from the geometry and linearity of the ways and the runout of the spindle bearings.
I don't think the surface finish on the cones is critical. For the convergent part of the steam cone the shape is unimportant anyway. For the combining cones some turbulence would be good to help mixing. The delivery cone finish isn't too critical as the flow is slowing down.
Back when I was working on racing cars the engine manufacturers spent hours smoothing and polishing the inlet manifolds with die grinders. Then it was discovered that a slightly dimpled surface, that caused some turbulence, was better.
John Hinkley17/06/2019 10:21:01
895 forum posts
297 photos
As an aside:
Posted by Andrew Johnston on 17/06/2019 09:30:28:
Isn't this why golfer's balls have dimples? Makes them go further and faster, I think. I would have though it might be interesting to experiment with dimpled upper surfaces of aircraft wings to speed airflow and therefore increase lift. And the reverse for racing car wings. But then, I failed aerodynamics at college - maybe that's why!
Nigel Bennett17/06/2019 11:38:15
346 forum posts
11 photos
Hardening D-bit reamers usually resulted in banana-shaped curiosities for me. So having been inspired by an article about injectors by Basil Palmer, I ground some HSS injector reamers using his idea of triangular section. (Would be likely to give more even results in silver steel as the section is more uniform and symmetrical, so less prone to distort.)
I mounted a Quorn head on my Boxford 280 to grind some HSS and it worked out quite well. Note that if you want a 9 degree included angle, you DON'T grind the faces with the top slide at 4.5 degrees but at about 2.2 degrees - it depends on the diameter of the grinding wheel.
I made the mistake of grinding some Chinese-sourced HSS 6mm dia, only to find out when I tried to use one for reaming an injector cone that the stuff wasn't hardened. After trying it, the pointy end of the reamer came out looking like an oliver off a Showman's engine! I then dug out an old HSS tap and ground that instead. I did get a working injector, but it needs more time and attention than I have at present to get the working pressure range I want.
Despite covering up all of the lathe I could with newspaper, it still took ages to clear up all the horrid mess after grinding - so take care!
Nigel Graham 217/06/2019 13:09:52
667 forum posts
15 photos
To clarify, by triangular section, an equilateral triangle so giving a 30º negative rake on each cutting edge? (Ignoring any effect given by hollow-grinding.)
This would have a scraping action in brass, of course. I'm not sure if it could cut other metals like bronze.
Making miniature injectors that do inject seems as much black art as science and engineering, with people reporting very varying results - and assuming equivalent standards of workmanship.
Mr. Brown's book gives several reason why injectors get all upset and sulk, but I wonder if there are sometimes more subtle influences at play which become proportionally more severe inversely to injector size .
Of the obvious factors, he mentions one that can affect any injector whether own-make or bought-in: tiny air-leaks that are by no means obvious. A common one is where a short flexible hose is simply pushed onto the copper pipe.
Another I can suggest, is slight misalignment of the suction-side connections on the injector itself. Commonly these use flat metal-to-metal flanges, but could a tiny angularity there be just enough to draw in air? This would be exacerbated by frequent removal of the injector to clean or descale it, as the copper pipes slowly work-harden and no longer adapt themselves to the injector. One solution there might be to use a connector in which the pipe extends slightly into a counter-bore, and is surrounded by a rubber washer or O-ring.
One I've found in practice, is the cumulative result of over-rich water-treatment in the tank that feeds the injector. Over time it coats the cone and ball-valve surfaces.
Are there though other things at play, where the poor little injector is blamed whether own-made or bought? What of steam pressure and dryness at inlet, for example? Can that be affected, hence affecting the injector, inversely to pipe sizes etc., despite the much shorter pipe from turret to injector on the miniature compared to full-size? One might expect the larger the pipe and turret-height above water, the less the carry-over, and the less atmospheric condenser effect (an area-ratio result), so the hotter and drier the steam stays.
Now, the injector wants the steam to condense almost entirely in the combining-cone, so it can convert as much of the heat as possible into mechanical energy. So does it want the inlet steam to match that in the boiler as far as possible? If half the steam entering the injector is already wet fluff significantly cooler and wetter than what entered the manifold; can we expect the injector to work properly?
What might remove too much energy from the steam, which is already saturated at the manifold? Chilling by the air around the pipe, obviously, but a big factor I expect again to be inverse, is the nature of the steam's route. Sharp bends such as elbows and in valves, are especially frictional.
One curious effect I have often seen, on a Ken Swan 7-1/4"g version of the Kerr-Stuart 'Wren', is that the commercial injector fitted usually demands the water throttled back almost to 'Off'. In action, the injector seems to want the water full on, steam on very rapidly to full flow, then the water valve ( a standard plumbing ball-valve on the driving-truck/tender) carefully notched back until the device picks up - then left at that setting, almost closed.
Analysing this in the light of the above, a new tender water-hose certainly improved it; but there is a significant difference between ours, and the prototype faithfully reproduced by Ken Swan's drawings. The injector steam-valve was on the dome, disproportionately higher above the water than in standard-gauge. For ground-level portable-track operation, we fitted a manifold in the cab, though that manifold is T-shaped with a column bringing the take-offs (takes-off?) near the dome level. So assuming similar dryness fractions at dome or manifold height, might the steam be "damaged" by the extra bends introducing more wire-drawing, and more metal exposed to the air?. The brake ejector is fed from the same manifold and works well, but perhaps an ejector is less fussy than an injector.
Can anyone suggest other reasons for this odd behaviour?
To sum up, assuming high-quality workmanship throughout, are injectors often blamed unfairly? They work in a very critical range of conditions, so are easily stopped by external influences of which some are fairly obvious and easily remedied, while others may be much more subtle and difficult to pin down.
Food for thought _ I may be wrong in some of my suggestions, I have not yet tried making an injector; but I have driven miniature locomotives for long enough to think injectors are too easily blamed for not injecting; but when not blamed the real problem is too easy to miss!
Andrew Johnston17/06/2019 15:03:28
5549 forum posts
650 photos
Posted by Nigel Graham 2 on 17/06/2019 13:09:52:
Errr, that's not how the combining cone works. The steam is condensed by the water and the latent heat of evaporation released as the steam condenses goes to heat the water, but it doesn't add to the kinetic energy. The key to understanding the operation of the combining cone is conservation of momentum.
The release of the heat in the steam determines the maximum inlet water temperature at which the injector will work, and is dependent upon the inlet steam pressure.
Nigel Graham 217/06/2019 16:07:17
667 forum posts
15 photos
Thank you for the correction, Andrew, but you still make the points that hint the "quality" of the steam is critical. If the steam has lost a lot of energy before it reaches the injector, it's not going to be very useful. The steam cone is convergent so will trade pressure for velocity, but the pressure at its inlet is already lower than the pressure-gauge reads, and if that drop is too great the velocity won't be up to the job.
The point about heat transfer may explain why injectors often seem to gulp steam faster that it's being generated. Even if feeding, the injector might not be heating the water very much at all because the quantity of heat available at the combining-cone is low. So it's not so much a matter of being greedy for steam, then pushing unduly cool water into the boiler. It will naturally have some cooling effect anyway, but I've seen an injector supposedly appropriate for the boiler, commonly drop the boiler pressure so rapidly that it becomes difficult to raise the water-level.
Though quite how you match the two is another matter. Mere physical size of boiler is only one of too many variables involved, and it may well be that with bought-in or owner-designed injectors, it will always be a compromise.
Steamer191517/06/2019 19:03:40
165 forum posts
41 photos
Andrew.
If you are grinding between centres, the centres should not rotate. This removes any inaccuracy created by the spindle bearings.
Steve.
EngineDIY
