Forum sponsored by Allendale Until July 27th
How to machine Acetal
AdrianR14/06/2019 17:31:59
226 forum posts
19 photos
Hi
I am trying to turn down the diameter of a 12mm Acetal rod to 8mm. I have tried a CCMT insert which does not seem to want to cut it. Sort of half cuts and deforms it.
Does it want to run fast or slow?
If I used HSS what is the best shape of tool to use?.
Should I use lubrication?
Any other hints?
Adrian
Andrew Johnston14/06/2019 17:35:43
4692 forum posts
527 photos
Try a CCGT insert, cut dry and the secret to machining plastic is slowish speed and high feedrates. In theory you can whizz through plastic, but the big problem is it melts - equals a right mess.
Roger Woollett14/06/2019 17:50:20
102 forum posts
I have machined Acetal from time to time. I use a HSS - keep it sharp with plenty of rake. I usually use quite high speeds - the same as I would use for brass. This gives a nice finish.
ega14/06/2019 18:09:17
1179 forum posts
97 photos
See advice at:
https://www.directplastics.co.uk/about_plastics/post/all-about-delrin-as-an-engineering-plastic
Boiler Bri14/06/2019 18:54:45
787 forum posts
277 photos
We use tips made for cutting aluminium. High speed and high feed rate with air cooling.
Bri
Howard Lewis14/06/2019 19:35:14
2035 forum posts
Adrian,
I would be inclined to use a HSS knife tool, or one with a small nose radius.
Carbide tips are not really sharp, or intended for plastics.
The nose radius will prevent the stress raiser of a sharp corner.
Guessing at what you are making, may I suggest turning down the minimum length, for the spigot, and leaving the rest at the maximum required size? No point in making extra swarf for the sake of it!
Douglas Johnston14/06/2019 20:00:11
577 forum posts
32 photos
The sharp polished carbide tips as sold for aluminium are what I use and they work a treat giving a very nice finish. They don't seem fussy about speed or feed rates. In fact I now use these inserts for most of my cutting from plastic to aluminium to mild steel and stainless steel, they are just superb tips especially on smaller lightweight lathes.
Doug
Samsaranda14/06/2019 20:05:20
723 forum posts
5 photos
I have had variable results with carbide on plastic, I now use HSS but make sure it’s sharp, I always cut at a reasonably slow speed, too much speed generates heat which you don’t want.
Dave W
Nick Hulme14/06/2019 20:10:57
687 forum posts
37 photos
I use polished the TC tooling specified for Aluminium when machining plastic, it works very well.
Martin Whittle14/06/2019 20:57:30
76 forum posts
5 photos
The CCGT (which is ground to a polished sharp edge) should work very well indeed on delrin, which is also a joy to machine (if the tool is sharp)..
The CCMT does not have a sharp edge at all! It is suitable for taking a deep cut on steel at high cutting rates, where the material at the cutting edge is raised to temperatures where it becomes soft (even close to red heat at the cutting edge). It is totally unsuited to shallow cuts on steel, or on plastics
Hope this helps - I have been through this; some CCMT may be good for shallow cuts on steel, some is not, but I recommend CCGT for plastic.
Martin
Martin Whittle14/06/2019 21:06:59
76 forum posts
5 photos
PS
I do use CCMT on steels for heavier use, but use CCGT for more gentle uses on all materials. The sharp tips on CCGT are more easily broken by the shocks from intermittent cutting loads on non-round work . I have generally been very pleased by cheap tooling from China
Martin
John Reese14/06/2019 21:34:39
745 forum posts
I use HSS. Lots of rake and polished top and face.
Mick B114/06/2019 22:25:21
1069 forum posts
59 photos
Posted by John Reese on 14/06/2019 21:34:39:
+1, though a moderate rake as for mild steel works fine too, sharp and stoned fine. So long as you're slicing away the material rather than deforming it you can get a nice silky finish. Speed as for brass, but it's not especially critical.
Gary Wooding14/06/2019 22:52:47
544 forum posts
127 photos
I use a sharp tangential tool, medium to high speed. But the long swarf creates a birds nest if you're not careful. For the roughing cuts I move the saddle in bursts to let the swarf escape during each pause. The final, fine, cut is done in one movement so as to get a nice, even, finish.
Sam Stones15/06/2019 01:24:38
625 forum posts
210 photos
Adrian, I sent you a PM.
Sam smiley
AdrianR15/06/2019 07:52:41
226 forum posts
19 photos
Thanks for all the replies, I will give the HSS a try. I am trying to replace the broken oil pump/lift in my mill. Which in the parts list is called a Muddler. Which a dictionary tells me is a drink stirring stick.
not done it yet15/06/2019 08:43:52
3009 forum posts
11 photos
Probably the easiest material I have turned.
A sharp tool, I use HSS for this. Reasonably slow speed and watch out for heat - it can burst into flames apparently, except they are invisible!
I have never tried to cut that length in small diameter. It likely needs small cuts and a following steady as it will easily deform, particularly with heavy cuts and when warmed up. Definitely keep the pressure axially, not radially.
AdrianR16/06/2019 10:18:40
226 forum posts
19 photos
Well it turned out OK in the end, I made a couple of mistakes which ruined the finish in places, but I am happy with it.
I rounded the part that broke and the camera angle makes it look a lot longer,
Mick B116/06/2019 10:59:03
1069 forum posts
59 photos
How did you cut the helix? Looks very coarse for a ME type lathe.
AdrianR16/06/2019 11:57:30
226 forum posts
19 photos
Yes it is coarse, it is 19mm pitch. I cut it on my ML2, I luckily had enough change gears to give me a 1:6 ratio i.e. lead screw 6 times faster than spindle, which gave me a pitch of 3/4". As I was overdriving the lead screw, I drove it from the lead screw by hand cranking the hand wheel.
I used a narrow parting tool with a lot of rake, and made multiple passes with the left right offset supplied by the cross slide. The swarf was not completely cut free on by the tool, so I had to use a Stanley knife resting against the parting tool to occasionally gut the swarf away.
Unfortunately my flexible drive is still in my old workshop down south, If I had that I would have tried using a router/milling cutter with the drive mounted on the cross slide.
TRANSWAVE Converters
