Forum sponsored by Allendale Oct 22nd
Hardening a form tool made from Gauge Plate
Vic15/06/2019 11:43:43
2255 forum posts
11 photos
Posted by JasonB on 14/06/2019 18:20:27:
I would not bother to temper, just use it hard.
Yes I’ve done that with several things I’ve made from 01 and not had any problems.
Andrew Johnston15/06/2019 13:23:15
4855 forum posts
544 photos
I note that a few people don't temper after hardening. That might imply that tempering isn't necessary. But it could also mean that the hardening didn't work properly. In that case tempering will have little or no effect.
JasonB15/06/2019 13:32:59
16270 forum posts
1721 photos
1 articles
Not sure about tha, this one for expmple held up OK for making these brass fittings
And with a bit of regrinding (not to the cutting edge)went on to cut a batch of steel decorative nuts, still has a sharp edge
If it were not hard I would have expected the steel hex to blunt it. I know the likes of Ramon seldom tempers his homemade cutters and he used to do a lot of hardening for a living though he does have a tub of whale oil to hand.
I do feel that the section of the part being hardened can have an effect, if you have machined the cutting edges then they will be thinner and pointed and will quench faster than the bulk of the part so you can get a harder edge with a less brittle body so the tool may not shatter but the edge could chip.
Edited By JasonB on 15/06/2019 13:37:38
Vic15/06/2019 14:05:39
2255 forum posts
11 photos
Posted by Andrew Johnston on 15/06/2019 13:23:15:
And you think we wouldn’t notice?! In my case at least all the parts ended up glass hard as determined by a file just skidding over the surface. I’ve made trigger parts and scraper tips and they’ve all worked very well.
Vic15/06/2019 14:06:57
2255 forum posts
11 photos
Nice Nuts Jason! smiley
Neil Wyatt15/06/2019 18:17:05
16570 forum posts
687 photos
75 articles
Posted by JasonB on 15/06/2019 13:32:59:
If you do it properly and oil quench it's a gentler process as well and more likely to leave the core a bit softer.
Michael Gilligan15/06/2019 22:36:05
14015 forum posts
608 photos
A couple of useful notes here:
https://www.westyorkssteel.com/files/gauge-plate-ground-flat-stock.pdf
http://www.m-machine-metals.co.uk/info_heatreatment.html
JasonB16/06/2019 06:58:08
16270 forum posts
1721 photos
1 articles
Strange that the M-machine link says that bright rid is colder than cherry red, I would have said 500degC was cherry red and 8-900degC bright red.
Michael Gilligan16/06/2019 13:46:27
14015 forum posts
608 photos
Well spotted, Jason
... I wonder if it was a typo for 'black red' dont know
TRANSWAVE Converters
Meridenne Boat 2019
Ausee.com.au
cowbells
