Dro scale positioning
ronan walsh13/06/2019 17:22:11
541 forum posts
32 photos
Just splurged out on a 3 axis dro kit for the Tom Senior. It seems that the way to mount the x-axis scale is to mount it on the rear of the table. This is going to reduce my meagre y-axis travel by an inch or so, which i don't really want to do. I was thinking of mounting it on the front of the table, but this would interfere with the limit switches for the x-axis power feed.
Anyone any novel ideas for mounting this scale without losing y-axis travel ?
Bazyle13/06/2019 17:32:17
5214 forum posts
201 photos
How about a bellcrank to allow the scale to be mounted in the y direction.
Hollowpoint13/06/2019 17:47:21
329 forum posts
31 photos
Could you use some L shaped brackets to mount it under or above the table?
Edited By Hollowpoint on 13/06/2019 17:51:25
JasonB13/06/2019 17:52:40
18098 forum posts
1993 photos
I suppose it depends on what kit you bought, a magnetic one need only loose you a few mm, even less if you mill out a slot for it in the back of the table with head to one side. Different case if its a standard size glass scale.
Edited By JasonB on 13/06/2019 17:55:05
Edited By JasonB on 13/06/2019 17:55:25
Pete Rimmer13/06/2019 18:43:31
711 forum posts
49 photos
Posted by ronan walsh on 13/06/2019 17:22:11:
I have mine hung on a 2" x 2" aluminium angle off the left end of the table. It took some fiddling with jack screws to get the scale straight and true but it's been performing well enough for the past few years. However, I am considering removing it now that I have heard about the stick-on magnetic scale as used on some ML7 cross-slides. I'm going to investigate if I can adapt this to the 300mm travel of my x-axis.
JasonB13/06/2019 18:53:29
18098 forum posts
1993 photos
As the limit switches don't need to be that rigid to work a micro switch what about putting the scale in an upturned aluminium channel fixed to the edge of the table and then fit the stops to that
John Hinkley13/06/2019 19:22:52
872 forum posts
291 photos
At the risk of repeating what I've put in similar other posts, I overcame this problem by extending a milled bar beyond the scale on my VMC:
x-axis scale 1
And:
x-axis scale 2
The travel stops are retained, too. More pictures in my album.
ronan walsh13/06/2019 22:17:04
541 forum posts
32 photos
Yes John, that looks like a solution, something i will consider when i get the dro kit delivered, I have enough movement in the x and z axis, but always found the y a bit limited and don't want to lose anymore if at all possible.
Gary Wooding14/06/2019 07:53:43
696 forum posts
183 photos
I did something similar to John's solution on a friend's VMC mill.
Mike Poole14/06/2019 09:32:04
2572 forum posts
60 photos
I looked at fitting a glass scale on the front of my VMC and found the crank handle fouls the scale when the table is fully forward. I have decided to use a magnetic scale on the rear of the table with a thin cover so only 2mm of movement should be lost. Machining a groove in the back of the table could be done and no movement lost.
Gary Wooding14/06/2019 10:08:06
696 forum posts
183 photos
The conversion in my photo uses glass scales and no interference with handles has been encountered.
ChrisB14/06/2019 22:03:19
493 forum posts
190 photos
Posted by JasonB on 13/06/2019 17:52:40:
Did you slot the table and insert the tape in the slot Jason? I 'm about to mount mine (which is similar) but I'm a bit concerned - the magnetic tape has double sided tape, so I was going to stick it directly to the table, but I don't know how long will it stay there when oil gets to it.
ronan walsh16/06/2019 22:01:17
541 forum posts
32 photos
Got the dro kit delivered yesterday. Popped out to the shed today and had a quick look, i don't see any way to mount the scale on the front of the table. Looks like i will have to mount it on the rear and lose a bit of movement in the y-axis. There is simply too much going on, on the front of the machine, with the powerfeed limit switch, oiler, and the nut that clamps the table in place (its a universal).
JasonB17/06/2019 07:35:14
18098 forum posts
1993 photos
Chris, that's how they are coming out of the Sieg factory with the scale already fitted into the slot. Don't know if they use anything different to stick them or just DS tape. As you say if using something like paraffin or WD40 on ali then that may soften the tape adhesive over time if not protected.
Mike Poole17/06/2019 08:59:42
2572 forum posts
60 photos
Posted by Gary Wooding on 14/06/2019 10:08:06:
That’s interesting Gary, my Warco VMC definitely fouls the knee raise crank handle with the table wound fully out and a glass scale fitted, they do make small changes over the years so maybe they changed some aspect of the knee raise crank handle or it’s position. Oh well problem solved with the magnetic sensor.
Stuart Bridger17/06/2019 09:28:06
434 forum posts
25 photos
On my 2009 VMC, the knee crank handle will clout the edge of the table, when fully wound out, even without a scale fitted. My DRO has on optical scale fitted the rear of the table which was a Warco fit.
Edited By Stuart Bridger on 17/06/2019 09:28:28
Vic17/06/2019 10:06:24
2500 forum posts
14 photos
From what I’ve seen traditionally VMC’s have the scale fitted at the back, even Warco do this if you order one with a DRO fitted. If you fit a compact scale you needn’t lose too much travel. On my particular VMC I lose about 20mm due to the vice overhanging the table anyway. This loss of travel hasn’t been an issue for me over the past ten years or so that I’ve had the machine.
Clive Foster17/06/2019 10:07:22
2204 forum posts
73 photos
The main problem with mounting the scale, particularly glass scales, on the front of the table is clearance for the Y-Axis feed handle.
When I fitted the scale to the front of the table on my old Chester Lux / Rong Fu style square column bench mill I was able to find a suitable handle with a long centre spigot giving sufficient clearance for the scale. This was a disk wheel with folding handle style which actually stuck out less than the originals when the handle was folded in giving more room to move past without being tagged!
Alternatively you could simply replace the standard dials with a suitable hollow spigot having an extended end to take the handle thus moving it further back. With a functioning DRO system there seems little point in retaining the dials. If it does break you can always go back to standard.
I mounted my scale on standoffs leaving a slot to get at the stops behind the scale. It worked adequately but, in retrospect, Johns system with a bar in front would have been well worth the extra effort to make.
ChrisB17/06/2019 17:26:26
493 forum posts
190 photos
Posted by JasonB on 17/06/2019 07:35:14:
Ah, it came from the factory like that! Very nice of them, the most compact setup I've ever seen. I guess I will just take the chance and stick it with the double sided tape the scale comes with, and if it comes off in the future I'll stick it with some more permanent adhesive. Thanks Jason
