Another "What is it?"
Apparently a Diesel pressure tool...?
Simon036210/06/2019 16:36:05
175 forum posts
63 photos
file7.jpegfile6.jpegfile4.jpegfile3.jpegHi All,
I have had this tool for some time on the basis that "it will come in useful sometime..."
I have now arrived at the point where its time to move this onto someone who a) knows exactly what it is and b) can use it...
I have advertised it on Homeworkshop in the hopes that someone would see it and decide they knew what it was but no takers.
If anyone can tell me what it is - or even take it off my hands I would be very happy.
I believe it is a pressure sensor for fluids where the lamp under the red cover lights up at pressure "X", whatever that might be. Beautifully made and heavily chromed and looks almost unused - but maybe unused for a good reason!
BR
Simon
Journeyman10/06/2019 16:46:13
780 forum posts
134 photos
Wilmonda seem to make specialist tools for the motor trade ( see ***HERE*** ). No idea what this one is for though?
Edited By Journeyman on 10/06/2019 16:47:49
not done it yet10/06/2019 18:28:49
4505 forum posts
16 photos
Several pics/vids on the net if you search on ‘goggle’. Must be some information there.
Former Member10/06/2019 18:42:38
Mike Poole10/06/2019 19:36:18
2545 forum posts
60 photos
The one on eBay seems to be on the same table as Simons.
Speedy Builder510/06/2019 19:39:52
1987 forum posts
139 photos
Hello,
it is a diesel injection pump timing tool (drop timing!) on "in-line" pumps
the banana plug connects to the end of the tool, the crocodile clip on a +bat. and the conical connector on an outlet of the pump
it is not "specific to PL
Ps, translation from the French Panhard club forum
Speedy Builder510/06/2019 19:45:02
1987 forum posts
139 photos
More info
Simon036210/06/2019 20:03:01
175 forum posts
63 photos
Posted by 34046 on 10/06/2019 18:42:38:
It’s an oil and fuel pressure tester. There is one on EBay for £25
Bill
Edited By 34046 on 10/06/2019 18:43:25
Yes, its mine.....
Simon036210/06/2019 20:04:44
175 forum posts
63 photos
Posted by Speedy Builder5 on 10/06/2019 19:39:52:
Hello,
Thanks, I found some things from the Panhard club too - but nothing suggesting it was either specific to something nor the 'proper' application fr it
Simon036210/06/2019 20:06:06
175 forum posts
63 photos
Posted by Speedy Builder5 on 10/06/2019 19:45:02:
More info
Sadly, all I get is a nice link to mine..... smile p
Former Member10/06/2019 20:18:22
Former Member10/06/2019 20:18:31
old mart11/06/2019 18:54:32
1540 forum posts
136 photos
Yes, Haggerleases, now you bring the title to my attention. I have all the programs on dvd.
Howard Lewis11/06/2019 21:12:03
3149 forum posts
The nipple is obviously one meant to connect to an Injection pipe connection. Most likely to be used as a timing tool connected to the High Pressure outlet of (usually ) No 1. As said, as the engine is rotated, the pressure build up will light the light, to indicate the start of injection. A cleaner way than spill timing. an In Line, but could also be used on a rotary such as the Roosa Master, CAV DPA,, DPS, Bosch EPVA, EPVE, or any of the Stanadyne pumps.
It looks unused, but the size of the nut makes it look like it is meant for 'A' size connections, so probably not for anything bigger than a pump with a 10mm plunger size, so relatively low powered engines, (Not much more than 30-40 bhp / cylinder even if turbocharged. ).
Simon036212/06/2019 23:18:19
175 forum posts
63 photos
Thanks for all of the input, especially Howard’s detailed description. It came from one of our local ‘vide grenier’ car boot sales in southern France so that may also tie in with the low power comments reflecting the popularity of diesel engines here for all forms of transport until recently.
I thought that it was unused until I took the photos and then saw some graunch marks on the knurled knob where someone has gently taken a pair of pliers or the like to it. Not serious but not perfect...
Maybe a tool to pass to my neighbour who has a fine collection of French classics
Simon
