unknown useage
Philip Burley | 08/06/2019 18:24:58 |
![]() 198 forum posts 1 photos |
Paul Kemp | 08/06/2019 18:46:18 |
712 forum posts 27 photos | Difficult to be sure with the size of the picture but it looks like it should be a captive blow down valve. Ball goes in the shroud at the end of the spindle which gets forced onto the seat in the body when the spindle is tightened. Back nut is to stop you screwing it all the way out! Paul. |
Philip Burley | 08/06/2019 19:01:35 |
![]() 198 forum posts 1 photos | hello , sounds about right , but where does the water / steam exit ? |
Paul Kemp | 08/06/2019 19:13:27 |
712 forum posts 27 photos | Through a hole and pipe extension off the side, not yet drilled and fitted! Looks like it was left once the turning was completed and never finished! Paul. |
Former Member | 08/06/2019 19:20:30 |
1329 forum posts | [This posting has been removed] |
Philip Burley | 08/06/2019 19:51:11 |
![]() 198 forum posts 1 photos | Oh , I see now !!!! Its not finished , No wonder it had me foxed Would this be a home made fitting then ? , Thanks everyone ( again !!) regards Phil |
Former Member | 08/06/2019 20:26:52 |
Former Member | 08/06/2019 20:33:26 |
Boiler Bri | 08/06/2019 21:23:53 |
![]() 842 forum posts 199 photos | i agree with 34046 Blow down valve. Ball missing from the seat.
B |
David Wasson | 08/06/2019 23:46:56 |
![]() 149 forum posts 43 photos | Here's the parts for a complete valve of this style: Here it is installed: If you add an O ring on the valve spindle just under the retaining nut, you will not get any steam blowing out around the spindle when you blow down. Just make sure you open the valve enough to squeeze the O ring. |
Peter Krogh | 09/06/2019 03:05:00 |
![]() 222 forum posts 20 photos | Don't drill for the exhaust until you've screwed it into place and marked which way it should point. No shimming to get the thing clocked. Pete
David Wasson | 09/06/2019 04:21:55 |
![]() 149 forum posts 43 photos | Good tip Pete! In fact, the same goes for all fittings that screw into something and must have a specific orientation. |
Philip Burley | 09/06/2019 13:49:35 |
David Wasson | 09/06/2019 13:58:38 |
![]() 149 forum posts 43 photos | Yes, the two fittings at the top of the photo are for a water gauge. The two fittings in the lower half of the photo, I am not sure what they are. If they are injectors, they are unlike any that I have seen. No doubt someone else will be able to identify these. |
Former Member | 09/06/2019 15:15:16 |
Philip Burley | 09/06/2019 17:04:43 |
Former Member | 09/06/2019 17:38:49 |
John Baguley | 09/06/2019 18:32:19 |
![]() 507 forum posts 56 photos | To me, they like as though they could the bottom fittings of more water gauges. The larger diameter threaded stub has a flat bottom recess which would take the bottom end of the gauge glass. The long threaded stub would thread into the boiler and have a locknut to secure in position once lined up. The tufnol? headed spindles could be shut off valves. They seem to be lefthand and righthand fittings of a matched pair. Could be totally wrong of course! Have you got a photo of the other side of the fittings? John |
Philip Burley | 09/06/2019 19:39:16 |
![]() 198 forum posts 1 photos | John , I am sure you are right , now I have lined them up a different way , they must me water gauge fittings . Missing the unions for the glass glands and missing the valve needle for he drain . They both have steam shut off valves . . They seem a bit complicated though . They might be OK for a small boiler thanks everyone Regards Phil |
