Electronic Indexers - How Is Cumulative Error Avoided?
William Chitham30/05/2019 12:22:08
22 forum posts
I am planning to build an electronic indexer, initially to make a 127-135 tooth compound gear for my Boxford. Am I right in thinking that the normal way for the programming to work is for the controller to divide 360 by the number of teeth, round the result to whatever number of discrete steps the stepper/drive ratio can manage and apply that repeatedly to the work on the assumption that the error will be insignificantly small? My concern is that the error is cumulative from tooth to tooth and therefore all delivered together on the last tooth. Furthermore the error is proportional to the diameter of the blank. Since I want to cut gears with lots of teeth, a comparitively large diameter and a prime number of teeth to boot the error is going to be enough to make the gear useless. For instance if the error per tooth is .01% then by the time I get to 135 teeth it will be 1.35%. The diameter is around 190mm, circumference approx 597mm so the cumulative error is going to be 8mm. I know many people have successfully built and used these things so I suppose there must be something wrong in my understanding of the principles, can anyone enlighten me?
Thanks, William.
duncan webster30/05/2019 12:54:43
2293 forum posts
33 photos
There was a thread on here before about this, in brief it's done by a bit of nifty integer arithmetic which keeps track of the error, and makes a move one step bigger or smaller now and again to compensate. Far and away the easiest is to use Silly Old Duffer's software and an Arduino. I can supply stripboard layout if you want to use a Nano cheaper than UNO and has soldered connections, more reliable than plug in)
see my post of 15/04/2019 14:01, I can send more photos if you wish
Bazyle30/05/2019 13:13:07
4856 forum posts
195 photos
The solution is to do each calculation individually ie calculate for 1/127, then 2/127, then 3/127.
If the aim is just to make the gear then there are 100 simpler ways.
If the fun is in making an electro-mechanical gizmo then go for it.
If you don't like electronics then go for an old school differential indexing device.
Mike Crossfield30/05/2019 13:43:58
194 forum posts
17 photos
I built Steve Ward’s excellent design of controller a few years ago. Very well documented and simple to build using a programmed PIC and pcb available from Steve at very low cost (Full kits also available). Regarding William’s original question, Steve answered this with respect to his own design in response to someone else’s question a few years ago. I quote:
“So basically internally it multiplies the number of divisions by the actual division its on then divides the result by the number of steps for a full circle - this gives it the nearest number of steps it needs to get to that division (doing the multiply first prevents loss of resolution although it means it needs 32 bit maths which is why the max steps per rev is 16 bit).
Internally it knows exactly how many steps it's currently taken so simply adds (or subtracts) that from the answer above to get the number of steps to take.
This means there isn't a constant number of steps since it may need to take an extra step (or lose one to be accurate).
In practice the accuracy of the maths is half the single step resolution, so a 400 step driver on a 90:1 worm gives you 0.01 degrees per step so the accuracy is 0.005 degrees. (Mechanical accuracy not withstanding)”
HTH
John Haine30/05/2019 13:49:16
2783 forum posts
140 photos
Even easier is to buy the indexer kit from "World of Ward". Processor comes ready programmed. Several posts elsewhere on this site about it. Photos of mine in my "Digital Dividing head" album.
Andrew Johnston30/05/2019 14:24:17
5075 forum posts
585 photos
I wrote up a similar method to that elucidated by Mike, and then lost it before posting due to finger trouble. If I were doing something similar to the OP I wouldn't muck about with integer arithmetic. I'd choose a processor with a floating point unit; makes life so much easier.
SillyOldDuffer30/05/2019 15:59:07
5013 forum posts
1062 photos
As I recall in the earlier discussion (can't find it!), I started by arguing that the error was insignificant, but was soon persuaded it was worth correcting. (Accumulating error might become significant particularly if a coarse stepping motor drives a rotary table with a low ratio worm.)
Bressingham was suggested, but I settled for a simple averaging process that distributes the error around the circumference rather than letting it accumulate so that one tooth in a gear is malformed. The maths came from Duncan (many thanks!) and the code is:
nextSteps = ( (long)(divisionStepCount+1) * motorSteps + (long)rstatus.divisionSteps/2 ) / (long)rstatus.divisionSteps;
motorSteps is the number of micosteps needed to turn the rotary table through one revolution. It takes the table's worm ratio into account and the motor's base step (usually 200), and the motor controllers microstep setting.
rstatus.divisionSteps is the user request (ie the number of gear teeth wanted), and divisionStepcount is how far the turn has got so far.
nextSteps is the number of microsteps the motor will be sent to step the rotary table to the next position; thanks to the maths the number of microsteps jitters very slightly around the correct position on each division as necessary to share any error equally throughout the turn. No error, no correction applied. Bottom line: if there is an error it will be small, it is shared out to minimise the effect, and it does not accumulate.
Because stepper motors are themselves integer devices there's not much advantage in using floating point arithmetic which uses more memory and is relatively slow. However although all the numbers needed to control the motor are stored as 16 bit integers, Duncan's calculation is done at 32 bit precision to avoid overflow.
William Chitham30/05/2019 16:07:36
22 forum posts
Thanks all, thought there must be more to it. I'd arrived at both the solutions described by muddling around with a spreadsheet but I don't have enough understanding of code to see the sums in the various versions that I've looked at.
William.
SillyOldDuffer30/05/2019 16:24:56
5013 forum posts
1062 photos
Posted by William Chitham on 30/05/2019 12:22:08:
Am I right in thinking that the normal way for the programming to work is for the controller to divide 360 by the number of teeth, round the result to whatever number of discrete steps the stepper/drive ratio can manage and apply that repeatedly to the work on the assumption that the error will be insignificantly small? ...
Not quite. You're on the right track except the motor and controller don't work in degrees. A typical stepper motor does 200 'natural' steps of per rotation or 1.8° per step. However the fiendishly clever motor controller can subdivide each natural step, at the extreme up to 250000 steps per revolution or about 0.0014° per step.
There's a trade off between speed and accuracy. It takes forever to spin a motor at 0.0014° per step. In practice I run my controller at 0.1125° per microstep (200x16), and that's fed into a 90:1 worm on the rotary table, giving 0.00125° per step at the job.
The software does the maths necessary to translate user needs in degrees or divisions at the table into microsteps at the motor controller.
Andrew Johnston30/05/2019 16:50:04
5075 forum posts
585 photos
Posted by SillyOldDuffer on 30/05/2019 15:59:07:
......there's not much advantage in using floating point arithmetic which uses more memory and is relatively slow.
Oh dear Dave, you're a bit behind, although at least in the 20th rather than the 19th. smile
By chance I'm looking at a processor for a design update on a CO2 gas sensor board at the moment. The preferred processor has an ARM Cortex M4 core with a full implementation of the IEEE754 single precision floating point specification. Floating point addition, subtraction and multiplication are all single cycle operations. At the maximum clock rate of 72MHz that's about 14ns. One off price of the processor from Farnell is under £4. What's not to like?
Neil Wyatt30/05/2019 16:54:44
16955 forum posts
690 photos
76 articles
The other way is to use a variation on the Bressingham Line Algorithm, treating one rotation and the number of holes as analogous to X and Y displacement along a line. Much easier and works by minimising the absolute error at each step
Andrew Johnston30/05/2019 17:13:41
5075 forum posts
585 photos
Posted by Neil Wyatt on 30/05/2019 16:54:44:
The other way is to use a variation on the Bressingham Line Algorithm............
Must have steam on the brain - it's actually the Bresenham line algorithm.
Robert Atkinson 230/05/2019 17:47:24
463 forum posts
21 photos
While microstepping improves torque ripple and position overshoot, it does not necessarily provide improved positional accuracy. This is particuarly true ff the load (torque) is variable. Performance depends on the motor, controller and load. It's easy to get caught up in the numbers but the whole system must be considered or you may be wasting effort for no real improvement.
Robert G8RPI.
SillyOldDuffer30/05/2019 17:51:49
5013 forum posts
1062 photos
Posted by Andrew Johnston on 30/05/2019 17:13:41:
Must be catching - I spelt Bresenham wrong too!
M4 Cortex for £4! Even though I'm totally loyal to all things Arduino that's got to be worth a look!
Bazyle30/05/2019 18:10:34
4856 forum posts
195 photos
In practice the problem has quite a low boundary. You are only ever going to cut gears up to 200 (plus whatever the JW large wheel skeleton uses) so the number of variables is quite small. For each of those 200 you need a maximum of 200 entries, average 100, in a table telling you how many steps to take. So the memory requirement is only 200x100 off 16bit numbers. You can do the calculations in excel and blow them into an eprom (except nobody does that anymore) have a few switches on the high address lines to select the tooth count and a couple of counters take the values and do the steps. No processors needed !
Alan Vos30/05/2019 18:10:53
141 forum posts
7 photos
Posted by Bazyle on 30/05/2019 13:13:07:
That.
The one time I did stepper motor control the basic logic was:
* Define 'zero' or some other reference
* Keep track of how many steps you are away from that reference
* Calculate steps from that reference to the new position
* Move the difference.
* If required for backlash, overshoot and return
For fast movement, consider acceleration and deceleration rather than going straight to full speed followed by a hard stop. That allows a smaller motors to deliver higher speed without missed steps.
Joseph Noci 130/05/2019 18:51:00
555 forum posts
843 photos
Precisely what I did with my ELS implementation and Electronic gear hobber - both sort of described in my various posts on MEW ( How I link to them is anyone's guess, or maybe Neil's...)
Bresenham takes care of it all with the smallest errors possible, and I used the Nucleo range of STM processor modules - Arduino lookalike/workalike, only MUCH faster , 140MHz, floating point, and US$15.00 for a board, with its programmer module..As Andrew said, whats not to like???
Mips/floating point, etc, are all VERY inexpensive today and while it's great to obfiscuricate software skills in retro-capability processors, why bother...
Bresenhams works very well in ALL these applications.
But, this is all intellectual masturbation if the OP just simply wants a system that he can apply and get to work, especially if he is not that able in the software space. In which case, I would suggest obtaining one of the mentioned systems that already work, and are more a diy assembly project than an adventure...
Joe
Massimo Dalmonte31/05/2019 07:31:45
20 forum posts
12 photos
Ten years ago, though I didn't have a specific need, I liked very much the idea of the J.A.Radford headstock indexing attachment and thought of putting a stepper motor on its worm shaft to spin it.
The stepper would be driven using an old laptop via the parallel port () and I made a small Visual Basic program, using a DLL (IOPort.dll, I think to recall) to output the signals ( these had to be "strengthened" in some way before sending them to the motor, naturally).
Here is an example of how it worked: the three input data are:
- motor steps per revolution: 200
- bullwheel teeth: 65 (I own an ML10)
- holes to be drilled\teeth to be cut (9 in this case)
Dividing 13000 steps by 9, gives 1444.4 period, so each position will be 1444 steps apart from the previous one, and we will have to spread 4 "orphan" steps on the whole revolution (this is done 3 times, on holes\teeth 3,5 and 7, the 4th step is not added, though now I see that it could be added to the first or the last step...).
Hitting the button started the sequence, the 8 outputs to the Data pins of the port were monitored in the Out frame, the DLL provided a choice of the kind of sequence used to drive the motor and it was possible to change the interval between one sequence and the next, to adapt it to the stepper.
As with a lot of my projects, I didn't proceed further with the hardware part, due to lack of time, but who knows... (today I think the motor command part is even simpler)
Massimo
Edited By Massimo Dalmonte on 31/05/2019 07:35:33
Martin Connelly31/05/2019 14:14:31
909 forum posts
112 photos
I made a 127 tooth gear using the calculate each position method as 360 x X/127 and a stepper motor with a close coupled harmonic gearbox. It required 88.8888 steps per degree, just under 252 steps per tooth. I decided that was going to be accurate enough for my needs.
Martin C
Brian Oldford01/06/2019 09:11:30
596 forum posts
4 photos
Posted by Bazyle on 30/05/2019 18:10:34:
Whilst seemingly a very elegant solution for its simplicity , For "awkward" divisions won't that encounter the problem of cumulative error mentioned upthread?
mid gard rail Jan 2020
