Hostaform, Nylon or Steel For Mini Mill Gear?
William Chitham28/05/2019 18:32:53
28 forum posts
7 photos
Had a happy day yesterday making my first ever foray into milling with my new to me but rather second hand Axminster mini mill. I had nearly finished making some t nuts when a things suddenly stopped turning. I soon diagnosed the problem as stripped teeth on the plastic spur gear between the motor and gearbox. I phoned Axminster this morning and am waiting to hear from them but don't have much hope they will have the spare so I've been looking elsewhere and seems there are plenty of cheap alternatives out there but which material to go for? Tempting to stick in a steel one but I imagine this gear is a designed weakpoint to protect the gearbox. Delrin I have heard of but I can't find the exact one I want but there are lots selling Hostaform and Nylon 6. Any advice on which material is best would be appreciated.
Thanks, William.
David Jupp28/05/2019 19:05:49
724 forum posts
17 photos
This article might be a useful starter.
William Chitham28/05/2019 19:12:54
28 forum posts
7 photos
Thanks David, I saw that one and it seems to suggest that Delrin is the strongest but maybe someone has tried the Hostaform in a similar application and can tell me wether it is up to the job. Or else maybe someone could recommend a suppplier for Delrin gears. I need a 30 toothe Mod 1,5. Needs to end up 10mm thick plus a 3mm boss, 10mm bore and a 4mm keyway but I suppose I can machine to all those dims on the lathe if it starts oversize.
William.
Neil Wyatt28/05/2019 19:33:25
17729 forum posts
697 photos
77 articles
Folks who wonder if nylon gears in mini-mill and mini-lathe headstock might be interested to know this is a feature shared with the Denford Synchro.
Paul Kemp28/05/2019 19:34:22
433 forum posts
18 photos
William,
If you look at Arc Eurotrade web site you might just find a picture of a mill very similar to yours and if you look at the parts list you may well find they have exactly what you need sat on their shelf which for less time and probably less money they could send you, over you making your own.
Paul.
David Jupp28/05/2019 19:44:46
724 forum posts
17 photos
Delrin & Hostaform are brand names for FAMILIES of resin. Within each there may be many different grades with tailored properties.
The article compares homopolymer actetal, vs copolymer acetal (without details of composition) vs Nylon 6. Plastics rapidly become fiendishly complex, even within a family. Don't expect a simple answer.
Pete Rimmer28/05/2019 19:47:06
684 forum posts
49 photos
Posted by Neil Wyatt on 28/05/2019 19:33:25:
The original Denford gears were made form a material called Technyl A90, whatever that is, probably a nylon as the name suggests. I have made quite a few replacements from Delrin.
Pete Rimmer28/05/2019 19:51:35
684 forum posts
49 photos
I found that the original gear was rather mis-shapen on my lathe and it used to bind after it was worked hard and the heat caused it to swell. The delrin replacement never suffered any of this.
Samsaranda28/05/2019 20:53:52
909 forum posts
5 photos
William, I have an Axminster MiniMill and when I bust my gear, easy done, I bought a replacement from ArcEurotrade, can’t remember how cheap it was but they are brilliant at responding to orders, I think it was here the day after I ordered. If you go on Arc’s website they have a comprehensive parts list for the minimill and ordering couldn’t be simpler. At least you can get running again until you decide what or which material you will replace it with.
Dave W
William Chitham29/05/2019 10:49:17
28 forum posts
7 photos
Thanks Dave, found it., ordered it. I noticed they also do steel replacements for the high low gearbox gears, have you fitted those? I wasn't planning to make a replacement for this although ironically I bought the mill with a view to making metric-imperial conversion gears for my lathe.
William.
Ketan Swali29/05/2019 11:05:49
1252 forum posts
105 photos
Posted by William Chitham on 29/05/2019 10:49:17:
William.
William,
Unless you really need want them, it is better to stick with the nylon gears - which act at a fail safe. Also, the high/low gears are cast iron. They will make your lathe more noisy. There are users who still want them, so we sell them for the old geared C2/C3 metalworker mini-lathes. If you still want them, consider the bigger one to be metal and the smaller one to be nylon which may still build in a small amount of fail safe.... although I am aware that this combination suggestion is questionable with certain people.... but it also works.
Ketan at ARC.
colin hawes29/05/2019 14:26:49
504 forum posts
18 photos
I have always reckoned that gears should be unbreakable not fail safe and that plastic of any sort for this job is used because it is far cheaper to injection mould a plastic gear than to machine a steel one. A sheer pin device would be used if protection was considered necessary but I have known a Tufnol gear to be used in a gear train to reduce noise. If my minimill gears ever strip I shall replace them with steel/cast iron ones and grease them well. Colin.
Ketan Swali29/05/2019 14:40:51
1252 forum posts
105 photos
Posted by colin hawes on 29/05/2019 14:26:49:
I understand Colin,... in which case... probability of electronics - board giving up the smoke can increase, and we are happy to sell more expensive components such as control boards... angel
Ketan at ARC.
Samsaranda29/05/2019 14:53:37
909 forum posts
5 photos
William, I stuck with plastic gears for the reason that Ketan illustrated, better to replace a sheared plastic gear than an expensive burnt out electrical board. I don’t use my minimill that frequently because I now have a Champion V20 mill which I have fitted with DRO’s and other mods, giving me much more machining capacity. Glad I was able to help solve your issue.
Dave W
colin hawes29/05/2019 14:59:56
504 forum posts
18 photos
Does the control board have no overcurrent / overload protection then? Just a question . Colin
Ketan Swali29/05/2019 15:10:52
1252 forum posts
105 photos
Posted by colin hawes on 29/05/2019 14:59:56:
Depends on the machine. The lowest spec. mini-lathes don't have. Also, on such mini-lathes, and even on high/low geared mini-lathes which have an overload protection, there is a 'user' element to be taken into consideration. If a new user, then failure - damage is related to how the stoppage occurred - heavy handed due to incorrect/improper/inexperience use?... in which case, probability of gear breakage (nylon) or board failure or both, could be equal. If metal gears + entry level electronics + new inexperienced user, then board failure event probabilities increase. There is no clear reason. Just probabilities related to user.
Ketan at ARC.
colin hawes29/05/2019 15:33:14
504 forum posts
18 photos
Thank you Ketan for that information. Colin
