soldering brass
Roger Hulett27/05/2019 16:41:45
131 forum posts
9 photos
I am beginning to assemble my brass,home made carburettor. I have faithfully copied the original. It is necessary to solder the parts together. However, some parts have to be soldered to other parts that have already been soldered. Is there a technique for keeping the old parts cool whilst heating up adjacent parts for soldering. The parts can not be soldered simultaneously.
Ian P27/05/2019 17:05:34
2380 forum posts
100 photos
Usual method is to use two or more solders with different melting temperatures, (use the higher temp one first)
Ian P
Jeff Dayman27/05/2019 17:16:43
1818 forum posts
45 photos
You can use the old trick of wrapping the end you want to keep cool in a wet rag, or embed it in a cold raw potato.
Sometimes just clamping on a hemostat or attaching a piece of copper sheet with an alligator clip will do.
Good luck!
Edited By Jeff Dayman on 27/05/2019 17:17:38
Roger Hulett30/05/2019 15:46:12
131 forum posts
9 photos
Further to this topic, adjacent to the item being soldered there is a threaded section. Obviously I don't want to let the solder run into this area. Is there an anti flux,something that prevents the solder running into the threads..... Vaseline,grinding paste,butter, 3 in i oil ?
Former Member30/05/2019 16:07:06
BCPROF30/05/2019 16:25:57
131 forum posts
If its silver solder I use either "lead" from a pencil of Tippex correction fluid . Never tried it for soft solder
Brian C
John Billard 130/05/2019 18:01:53
72 forum posts
Tippex works for soft solder.
John B
