Forum sponsored by Allendale May 23
Drill bits
Grotto25/05/2019 10:02:00
87 forum posts
42 photos
I recently bought a bunch of drill bits and when sorting through them found a few are left hand.
I'll be able to use them in my mill, but wondered why they are made. I guess there’s a good reason, just can’t think of it. Anyone know why?
Michael Gilligan25/05/2019 10:05:11
13104 forum posts
570 photos
One good use is for drilling-out broken right hand threaded screws.
Simon Williams 325/05/2019 10:07:42
385 forum posts
65 photos
Hoard them carefully, and wait for the day you need to drill out a broken off bolt in something completely irreplaceable. They are absolutely brilliant at catching the remnant bolt, at which point it unscrews itself out of the blind hole like magic. Better than an easi-out any day.
Don't use them in a keyless chuck - many such won't hold in reverse. A keyed chuck (generally) will.
Rgds Simon
Edit - MichaelG types faster than I.
Edited By Simon Williams 3 on 25/05/2019 10:08:40
Circlip25/05/2019 10:30:38
939 forum posts
They may have come from a flat pack furniture manufacturer. On multi drilling heads, some of the drill "chucks" rotate in reverse due to the centre spacing.
Regards Ian.
Mark P.25/05/2019 10:32:47
597 forum posts
6 photos
Loads on ebay.
Mark P.
Andrew Johnston25/05/2019 11:03:55
4649 forum posts
522 photos
Some production lathes normally run in reverse, like my Britan, so left hand drills are standard.
roy entwistle25/05/2019 11:11:20
971 forum posts
Drilling left handed holes obviously
Roy
JohnF25/05/2019 11:48:26
809 forum posts
88 photos
Boley made a capstan lathe similar I guess to Andrews Britan, also ran in reverse with the toolbox/holder at the rear thus LH drills we needed
larry phelan 125/05/2019 17:36:27
421 forum posts
11 photos
Never thought about drilling left hand holes !!!
True,you learn something new every day.
Keep them coming.
V8Eng25/05/2019 17:44:26
1274 forum posts
27 photos
Don’t forget to use left hand threaded taps with them.wink
duncan webster25/05/2019 23:57:10
2083 forum posts
32 photos
Then you'll need a left handed spanner to wind the bolts in
Jeff Dayman26/05/2019 00:49:12
1508 forum posts
37 photos
As mentioned on an earlier thread, left handed drills are very handy for working on the port engines of twin screw ships, and also LHD cars as used in North America. By the way Duncan, most mechanics' toolboxes in the North America are fully stocked with left handed wrenches of various types, a few of which can be used on right handed fasteners also.....not sure about toolboxes in the UK......
Simon Williams 326/05/2019 07:35:59
385 forum posts
65 photos
If you want to drill two holes which are truly independent of each other, drill one left hand and the other right hand.
Because the left hand never knows what the right hand is doing
roy entwistle26/05/2019 09:24:13
971 forum posts
Left handed spanners are easy to recognize, left handed screwdrivers are not as easy especially cross point ones
Roy
Mike Poole26/05/2019 10:31:34
1927 forum posts
46 photos
Can you fill a hole with left handed drill? Could be useful for a hole drilled in the wrong place.wink
roy entwistle26/05/2019 14:16:32
971 forum posts
Mike Now you're just being silly
Roy laugh
Jeff Dayman28/05/2019 00:59:43
1508 forum posts
37 photos
Hold on Roy, Mike is on to something. I'm pretty sure if I put a 1/8" dia left hand drill in the electrode holder of my old Lincoln 225 arc welder I can fill a hole ..... as long as the ground lead and clamp are in place on the plate with the hole! smile
roy entwistle28/05/2019 09:22:42
971 forum posts
Jeff OK I'll hold my hands up
Roy
Mike Poole28/05/2019 09:33:10
1927 forum posts
46 photos
Posted by roy entwistle on 26/05/2019 14:16:32:
Roy laugh
Guilty I’m afraid.
Hollowpoint28/05/2019 09:48:59
175 forum posts
27 photos
Maybe they are Australian? To counter that they are upside down and spinning the wrong way? 😄
TRANSWAVE Converters
Ausee.com.au
