Forum sponsored by Allendale July 23rd
" 4TPI lead screw nut
simon Hewitt 123/05/2019 15:28:32
42 forum posts
6 photos
Does anyone know where I could get a ¾" 4TPI lead screw nut? Outside dimensions not important, its to fit an old pillar drill, the table lift is by lead screw and it has stripped out the thread in the table carrier. Thanks
Simon
John Reese24/05/2019 00:42:21
772 forum posts
It is possible to single point a 3/4-4 thread. I used either a 5/8" or 1/2" boring bar with a very short tool bit. There was not sufficient clearance to withdraw the tool from the hole. I had to back off the cross slide a few thou and wind the tool out of work. I did it on a 13" lathe and it took many, many spring passes to finish the thread. I am not sure how well a smaller, less rigid lathe would handle the job.
Chris Evans 624/05/2019 07:23:04
1451 forum posts
Have you looked at the prices from the lead screw suppliers? It may be quicker and cost effective to buy a length of lead screw and a nut, for rise and fall does the pitch matter ? I did my lathe cross slide for sub £50 and have enough screw for three replacements. Consider going trapezoidal/metric it can be cheaper.
simon Hewitt 124/05/2019 20:27:53
42 forum posts
6 photos
Thanks Chris Evans - I think I will go this route. The screw is almost exactly 1 M long, and as you say, pitch is not critical, it just has two bevel gears and a winding handle. I am tempted to go for a ball screw and lead, and an electric motor, with an up/down switch, just for fun. Also I am not certain it is an Acme thread, looks like a square thread, but its difficult to see clearly until I pull it out. And it weighs a lot!, must be > 150kg.
Michael Gilligan31/05/2019 06:49:24
13827 forum posts
603 photos
Posted by simon Hewitt 1 on 24/05/2019 20:27:53:
Presumably this is the drill pictured in your Album, and nicely illustrated here: **LINK**
http://lathes.co.uk/denbigh-drills-page2/
... If so, I am sure you are thinking along the right lines yes
simon Hewitt 131/05/2019 08:42:51
42 forum posts
6 photos
What a great illustration. Mine is newer than that with the motor behind the column and modern style multi-sized V pulley, but the main column and the table adjust are exactly the same.
Chinese balls screws are remarkably cheap and I have a windscreen washer motor that will probably do, I will post a photo when complete.
simon Hewitt 131/05/2019 08:45:33
42 forum posts
6 photos
In fact, looking at the lathes site, mine is the K.1.A series 2 on page 2 here
Meridienne oct 2019
TRANSWAVE Converters
Advertise With Us
Ausee.com.au
