8.5mm to MT1 with tang
Ian P | 22/05/2019 20:31:29 |
![]() 2578 forum posts 114 photos |
I dont have anything in my workshop that takes Morse 1 but I keep moving this item from drawer to drawer and every time wonder what it would be used for. An 8.50mm drill shank is a perfect fit but how would it be tightened up? Ian P
Ian McVickers | 22/05/2019 20:45:28 |
222 forum posts 110 photos | It's for holding straight shank drill in a taper socket. Does it not lock onto the drill when gently tapped into the MT socket? |
HOWARDT | 22/05/2019 21:26:59 |
900 forum posts 39 photos | It is a Morse taper split sleeve drill driver. The drill to suit the driver is parallel shank with a small pair of flats on the end. Used in production setups for small drills, cheaper to use with replaceable straight shank drill rather than morse taper. Used to use these quite a lot on multi spindle drill heads with smaller, sub 10mm drills. |
Ian P | 22/05/2019 21:35:40 |
![]() 2578 forum posts 114 photos | Ah, I understand now. I did not realise that the drill would have driving flats and could not see how the collet could be tightened other than by hitting the exposed edge which seems a bit crude. If anyone seeing this thread has a use for it and pays postage or collects they can have it. Ian P |
John Reese | 24/05/2019 00:48:59 |
![]() 1035 forum posts | A taper length drill in that drill driver is intended to have the same overall length as a taper shank drill. |
DC31k | 29/05/2019 21:20:04 |
654 forum posts 2 photos | What does the writing on it say? I have a few of these and they are all for letter-size drills. If you squint at the picture, it looks like an 'R' on it, which would be closest to 8.5mm (but could equally be an '8' |
Ian P | 29/05/2019 21:40:12 |
![]() 2578 forum posts 114 photos | No writing on this one, but it slips on an 8.5mm drill shank perfectly. Ian P |
Michael Gilligan | 29/05/2019 22:00:51 |
![]() 20055 forum posts 1040 photos |
MIchaelG. |
HOWARDT | 29/05/2019 22:15:09 |
900 forum posts 39 photos | A link to Google books for those who need to read further. |
Ian P | 29/05/2019 22:17:16 |
You've got better eyesight than me, or maybe used a microscope! I will examine it tomorrow to see why I missed it. Ian P
