aching ribs - posture
mick H16/05/2019 17:35:09
730 forum posts
21 photos
For some time I have had a dull ache in my ribs when working in the workshop. Serious causes have been eliminated and it appears to be caused by poor posture. I am naturally a bit round shouldered and standing fettling small items accentuates this stance and brings on, at times, considerable discomfort.. No other activities bring it on. Does anyone else get this and if so what remedies are successful?
Mick
Brian Wood16/05/2019 18:49:26
2272 forum posts
37 photos
Hello Mick,
I don't know how tall you are, but would putting the lathe onto raising blocks give you a more upright posture in use?
Plasma16/05/2019 19:15:03
443 forum posts
Hi mick.
I have some aches and pains, I found a good book on my kindle called The trigger point massage therapy work book"
It gives simple self massage techniques to ease the knots in muscles that can cause all kinds of pain. Nothing more complex than a tennis ball or massage cane and you can ease all kinds of niggles.
Well worth reading and giving a go after a hard day in the shop.
Best regards Mick
Samsaranda16/05/2019 19:29:35
968 forum posts
5 photos
You need to eliminate or reduce the cause of your discomfort which is almost certainly caused by bending over your lathe or workbench. I suffered greatly until I moved my (bench) lathe onto a substantial, much higher bench and also raised my two workbenches to a much more comfortable height. I now suffer only if I spend prolonged hours in the workshop but that is probably age related more than poor posture while working.
Dave W
Jeff Dayman16/05/2019 20:45:23
1896 forum posts
45 photos
Suggestion - Sit down in a chair or stool with a back support for bench work type fettling.
No more running hand stands or cartwheels in the shop, either! wink
Iain Downs16/05/2019 20:46:32
688 forum posts
622 photos
I've just come back from the Chiropracter to remedy just such pains. Actually, I've saved up ankle, back and arm problems for better value.
Hopefully a few sessions will fix me (until the next time) and the advice for stance and the like will put off future problems.
Iain
duncan webster16/05/2019 21:53:02
2804 forum posts
41 photos
I have a small vice bolted to a steel plate which I grip in the normal vice for fiddly fettling jobs. It has smooth jaws so no need for soft jaws and is a lot higher up than the normal recommended elbow height, so no stooping. Just remember not to slacken the wrong handle to get the job out of the little vice, or you finish up with sore toes.
Most lathes are mounted too low for me as well, I find that cross slide handwheel at navel height s about right
2804 forum posts
41 photos
Hopper17/05/2019 02:00:09
4823 forum posts
105 photos
I had the same trouble working on a newly acquired old lathe some years ago. Raised the bench it came on by four inches: problem vanished instantly. Rule of thumb: set height so the cross slide feed handle is at your bent elbow height.
All my workbenches are likewise a bit higher than standard at 40 inches for the same reason. I'm 6'1" tall so you might want to tailor to your own height. The Myford bench is now 40 inches high and the ML7 sits on 2" riser blocks on top of that. Nice.
I also have a bar stool in the workshop that I sit on if working on small fiddly stuff for long periods.
Edited By Hopper on 17/05/2019 02:02:10
mick H17/05/2019 06:52:41
730 forum posts
21 photos
Thank you for your replies gents. Although in no way wishing this discomfort on anyone else, it is good to know that I am not the only one experiencing it. I have raised the lathe so that the mandrel is at about 40 inches and this is useful. The idea of a raised vice (together with the caveats) is also something I will put into use as I seem to spend a lot of time filing etc. Perhaps some specific exercises will also assist.
Mick
not done it yet17/05/2019 07:25:30
5041 forum posts
20 photos
One specific exercise could be filing metal - at the proper height for your stature.smiley
Mark Rand17/05/2019 09:43:57
924 forum posts
6 photos
The simple solution is to be short-arsed, like myself. laugh
Ron Laden17/05/2019 09:57:57
2010 forum posts
401 photos
I am 6ft and my bench tops are at 41 inches, benches at kitchen worktop height which is 4-5 inches less are too low for me.
Ron
Bazyle17/05/2019 09:59:21
5492 forum posts
207 photos
Don't forget that as we get older it takes more time to recover. So you may eliminate the actual problem but still get symptoms for days of even weeks afterwards leading you to think it is some other cause. You may have to do small changes and wait for effect rather than flit around.
Simon Collier17/05/2019 10:25:34
368 forum posts
56 photos
I dragged my large copper sheet out from behind the lathe a couple of weeks ago to cut some off. I have since paid half as much on chiropractors as the 3 mm full sheet cost! I often feel pain in the ribs that is referred from the spine.
Andrew Tinsley17/05/2019 10:48:05
1182 forum posts
I renovated a 9x20 lathe for an disabled and impecunious friend of mine. It came on a ridiculously high stand. Lathe centreline was 14" higher than my Myford on maker's stand.
Do you know what, it was a joy to use, because I did not have to bend!! I now think that most lathe stands are much too low.
Andrew.
ega17/05/2019 10:53:49
1814 forum posts
154 photos
Posted by Plasma on 16/05/2019 19:15:03:
Hi mick.
Best regards Mick
Sounds like a good tip; can you confirm that it is the book by Claire Davies that you recommend, please?
(There are a number of titles with similar names).
Neil Wyatt17/05/2019 11:49:44
18250 forum posts
714 photos
77 articles
I have stools of different heights in my workshop. Unfortunately they are usually being used for storage... but I have a cleanup scheduled for Saturday
Hopper17/05/2019 11:55:21
4823 forum posts
105 photos
Posted by mick H on 17/05/2019 06:52:41:
That is still about 8 to 10 inches lower than mine, which sits on top of a 40 inch bench, plus two-inch risers. But if you are 5'2" tall it should work.
mick H17/05/2019 16:30:25
730 forum posts
21 photos
It was a rotten guestimate of mine Hopper. It is my bench that is 40 inches and the lathe mandrel at 50 inches so about the same as yours. I was out and about today in the garden doing allsorts including lifting and some ladderwork without a hint of discomfort. I have an hypothesis forming......I am becoming allergic to model engineering.
Mick
EngineDIY
