Nigel McBurney 1 | 21/05/2019 14:31:40 |
![]() 1004 forum posts 3 photos | The Meddings drill which I bought some time ago was in very good condition and was cheaper than a new motor and vfd for the Fobco,plus it will drive a one inch drill easily,down to 100 rpm if required. |
Peter Cork 1 | 29/05/2021 23:13:18 |
3 forum posts | Ian, Phil et al, I'm new here, just signed up having found this thread looking for FOBCO drill table clamping chat ... I have (just bought ) a 10 8, similarly to many of you chaps the table clamp need gorilla force to get it to hold. The play in the table boss when un-clamped isn't commensurate with FOBCO build quality and clearly arises from wear from decades of heavy use. I suspect the boss has worn clamp side (rear) at the top and table side (front) at the base from table overhang loading. I'm reluctant simply to add a long lever / bearing washer to generate enough clamping force ... I don't want to break the casting. On the off-chance - has anyone considered getting the bore of the table boss re-built with weld or braze followed by re-bore to a decent ('FOBCO original' My 10 8 is a 3 phase machine and I'm adding a VFD (Invertek) to drive it from single phase, I'll post progress as I get it all going. Peter |
Peter Cork 1 | 30/05/2021 09:28:36 |
3 forum posts | Further to my last, in consideration (in the thread above) of conversion of the 'split boss' clamp arrangement to 'internal two-part clamp', I meant to add a word of caution. The standard arrangement of bolt closing the slot tightens the collar onto the pillar, nicely under tension, all as intended. (OK, not brilliant if boss wear means you have to close the slot a long way to get grip &hellip
Peter Cork 1 | 30/05/2021 09:29:46 |
3 forum posts | .. sorry, finger trouble there, no sure how that emoticon got in .. |
Swarf, Mostly! | 30/05/2021 10:13:44 |
676 forum posts 78 photos | Posted by Peter Cork 1 on 30/05/2021 09:29:46:
.. sorry, finger trouble there, no sure how that emoticon got in .. Hi there, Peter, If you ALWAYS type a space before any closing bracket, the emoji imp will stay asleep! (This one not just for you) If you ALWAYS press the right arrow key a few times before typing your reply, the quote line will end where it should and not embrace your text too! Best regards, Swarf, Mostly! |
