Forum sponsored by Allendale May 23
Upside down reverse threading
Circlip14/05/2019 12:13:00
939 forum posts
Whats the problem with that?
Is it because its not a drill or a D bit or any other kind. "
Try milling with it. Once you've seen one rattle and exit the chuck, you won't do it again.
Regards Ian.
Edited By Circlip on 14/05/2019 12:14:19
Baz14/05/2019 12:37:01
189 forum posts
Ian, totally agree with you, clue is in the name Drill Chuck. Seems that people don’t want to believe lathe chucks unscrew when run in reverse and drill chucks aren’t to be used for milling, only way for them to discover these basic truths is to have an accident and either scrap the job or Injure themselves.
JasonB14/05/2019 13:07:18
15393 forum posts
1586 photos
1 articles
If you do think your chuck may screw off then the upside down and reverse method can still be used if the tailstock ctr is brought up for support as the chuck won't unscrew against that. Good idea anyway if threading slender items.
A more useful comment than "don't do it on a screwed chuck machine" , would have been to say take precautions to stop the chuck coming off if doing it on a threaded spindle machine.
Now just need to go and remake that Minnie of mine where all the milling was done with the cutters in a drill or 3-jaw chuckdevil
Edited By JasonB on 14/05/2019 13:10:35
Jon14/05/2019 22:11:10
988 forum posts
46 photos
Posted by Circlip on 14/05/2019 12:13:00:
Absolute garbage been doing and not diy for 28 years, not once has anything worked loose except using ER collets
Jon14/05/2019 22:29:24
988 forum posts
46 photos
I know its impossible using a drill chuck to mill - taken about 15 years ago done about 600 patterned out to leave 0.8mm wall x 6.5mm thick with milling cutter in keyed chinese drill chuck. Drill holes to go on pcd.
How do you honestly think these can be done by hand as one offs and beat cnc in china on price. Again drill chuck done well in excess of 1900 in 26 years, no cutters drop or chuck dropping out, materials 18mm thick.
Must not do it again blah blah blah
Nick Hulme18/05/2019 08:23:31
682 forum posts
37 photos
Posted by SillyOldDuffer on 13/05/2019 20:41:45:
Perhaps your chuck is jammed, it's a well known Myford problem... devil
Incorrect guess, guess again, it's what you're good at
Nick Hulme18/05/2019 08:26:58
682 forum posts
37 photos
Posted by Jon on 14/05/2019 22:29:24:
Nice job!
I'm interested on the "Beat China on Price" bit though, what hourly rate did you base that calculation on?
jacques maurel18/05/2019 15:37:29
63 forum posts
16 photos
look at my video:
JM
ChrisB18/05/2019 18:03:23
285 forum posts
121 photos
Regarding holding an endmill in a drill chuck, I think it can be done ( thats what I had to do before I got direct collets) but, it depends on what chuck you use. I was using an old keyed chuck with a threaded arbor. I would be a bit concerned using a keyless chuck with just a jacobs taper to the arbor. Sideloads may knock the chuck off the arbor I think.
SillyOldDuffer18/05/2019 18:21:00
4318 forum posts
944 photos
Posted by Jon on 14/05/2019 22:11:10:
Seems unlikely given the way drill chucks are made: three jaws pushed together down a cone by a disk. Drills occasionally spin in mine due to their relatively poor grip and vibrating milling cutters come loose rather quickly.
My key type chucks are obviously inferior to ER32 for milling. Perhaps Jon is using a different type of drill chuck than the ordinary 3-jaw type, or has a better technique, or a stiffer machine than average? Can you tell us more Jon? Intriguing to know how you manage whilst others avoid milling with drill chucks due to poor results.
I must admit my keyless drill chuck grips rather better than the ordinary Jacobs key type. Perhaps it's OK for milling - I've never tried it.
Nick Hulme23/05/2019 13:15:47
682 forum posts
37 photos
Drill bit shanks are left soft specifically to give drill chucks reasonable purchase, milling cutters have hard shanks with a good surface finish, ideal for slipping in an inadequate holder and for encouraging the unwary to apply far too much tightening torque to said inadequate holder in an attempt to make it hold
As an aside, if tools are slipping in your ER Collets you are not following the correct procedures for using them :D
TRANSWAVE Converters
Ausee.com.au
