T nut slot channel
Chris12307/05/2019 20:34:09
121 forum posts
Evening,
I’m looking for a supplier of t channel that will take a t nut.
Length needs to be at least 2 meters, although we will need almost 10 meters so machining it ourselves will be a pain!
The aluminium profile such as Rexroth won’t really be strong enough.
I’m unable to find anything, thanks.
Bizibilder07/05/2019 20:39:11
68 forum posts
7 photos
Try Unistrut channel - they do various sizes and you may find what you need.
Chris12307/05/2019 20:42:46
121 forum posts
I’ve been told not to use unistrut as it was my first idea!
Thanks.
Emgee07/05/2019 20:58:42
1450 forum posts
217 photos
Chris, I find it difficult to understand why anyone would object to the use of a product designed for the intended purpose.
Emgee
Michael Gilligan07/05/2019 21:34:55
15484 forum posts
668 photos
Posted by Emgee on 07/05/2019 20:58:42:
Emgee
Not knowing the use that Chris proposes, it's difficult to judge ... but [to the best of my knowledge] all unistrut is formed from sheet ... The dimensional tolerances may not be good enough, and it may not take sufficient localised loading.
http://www.unistrut.co.uk/index.php?part=p1000
Edited By Michael Gilligan on 07/05/2019 21:37:54
Mike Poole07/05/2019 21:42:23
2545 forum posts
60 photos
Aluminium sections are available up to at least 100mm square with T slots. A bit more info on what it is for may get a more focused response.
Nigel Graham 207/05/2019 22:05:33
586 forum posts
Unistrut is really an architectural / electrical-installation material, is folded or rolled from sheet as Michael says; and the applications I have seen rely on simple plain square nuts rather than T-nuts. Perfectly good for its intended purposes and could be used elsewhere if suitable, but it's not intended for precision-engineering or holding very heavy concentrated loads.
Regarding point-loading, it might be possible to overcome that by using long nut-strips, but this starts to get messy. (I have used this principle for the T-slots on my EW 2.5" lathe's boring-table and vertical slide, making not separate T-nuts but T-strips the lengths of the slots, to spread the load.)
Aluminium- alloy T-slotted channel is made, as Mike Poole says. To help search for possible suppliers, it is for such purposes as electronics cabinet assemblies and among what are sometimes called collectively, "transport sections" (for vehicle bodywork). However, Chris123 seems to need it to take quite heavy loads so these might not suit.
If all else fails, whatever this is for, the profile might have to be fabricated.
One wonders if a fresh look at the design is called for!
Jeff Dayman07/05/2019 22:13:12
1793 forum posts
45 photos
For steel guides carrying heavy loads you may need to consider something like one of the products at the link below. Not cheap though.
T nuts are not really intended to hold heavy loads in suspension in any case.
Hopper07/05/2019 23:39:30
4414 forum posts
94 photos
More info on the application would be helpful if Unistrut wont do the job.
Nathan Sharpe07/05/2019 23:52:08
146 forum posts
It looks like the link provided by MichaelG is for end supported loads given that they show a deflection. In practice, Unistrut provides support for much greater weights, given that you fix to horizontal substrate (ceiling) or vertical substrate (wall), at the correct fixing spacing. In a concrete building (modern Hospital) , I'm happy for suspension of 200mm/8" heating main to be suspended from Unistrut at 1Mtr centre. In reply to postings as to the nut fixing, it is not a tee nut, it is a Cam nut which aligns two slots/grooves to the rail therefore applying both inward and downward pressure as the fixing screw is tightened. Nathan.
Dave Halford07/05/2019 23:55:33
702 forum posts
6 photos
When you don't know the design how can you possibly 2nd guess the solution....
Perhaps whoever said not unistrut has only just seen the slotted version
AdrianR08/05/2019 08:58:52
442 forum posts
23 photos
You can hang heavy loads on unistrut. I used to fit X-Ray machines. It was normal to bolt the slide rails to the unistrut.
Mike Poole08/05/2019 09:58:38
2545 forum posts
60 photos
Unistrut is big boys Meccano, a modern car factory uses miles of the stuff in bringing all the services to the machines, double sections are available for heavier applications. The Bosch Rexroth aluminium extrusion system is used by the ton. All sorts of jigs, conveyors, handover stations and guarding are made from it, available up to 160mm x 300mm sections apparently.
Chris12308/05/2019 21:54:27
121 forum posts
Hi, thanks for the replies.
Must for use in plastic extrusion, for holding a jig into a table. It needs to be quite strongly fixed down so it doesn’t move. Location accuracy doesn’t matter as the table is moved my motors.
We have loads of unistrut, but don’t want to use it. Other machines use this t slot channel but we don’t know where to buy it!
Thanks.
Michael Gilligan08/05/2019 22:22:37
15484 forum posts
668 photos
Aahh ... Is this the sort of thing you are looking for, Chris: **LINK**
www.ebay.co.uk/itm/Aluminium-600mm-24-Inch-T-Slot-T-Track-Miter-Track-Woodworking-Tools-Alloy-Tool/123284142941
Chris12308/05/2019 22:33:02
121 forum posts
Sort of, but much much stronger.
Imagine an aluminium bar 80mm x 80mm x several meters long, with a slot to take a M12 t nut.
Nathan Sharpe08/05/2019 22:58:16
146 forum posts
I suggest you go to the "8020inc" store on ebay to find your extrusion and then look closer to home. Nathan.
Ian P08/05/2019 23:04:20
2352 forum posts
98 photos
I am imagining a long length of aluminium bar 80mm square but if the T slot is in one face only it must be an unusual product or custom made.
Ian P
Pete.08/05/2019 23:25:26
217 forum posts
36 photos
Posted by Chris123 on 08/05/2019 21:54:27:
Thanks.
So you know what you want exists, you have some, maybe a photo would help people know exactly what you want?
Chris Gunn09/05/2019 10:48:14
319 forum posts
22 photos
Chris, in my working life I used "Halfen" steel channel, this is about 50mm wide, 30mm high and will take tee nuts up to 12mm thread. this is much stronger than the rolled steel channels. I believe other sizes are available.
Chris Gunn
