Determining the correct gear pitch for a given rack
Adam Harris07/05/2019 19:28:31
451 forum posts
19 photos
I understand how to determine the pitch of a gear by measuring the outside diameter and number of teeth, but how do I measure a rack to get the dimensions/pitch/other of a correctly meshing gear?
JasonB07/05/2019 19:40:31
17824 forum posts
1948 photos
For metric MOD pitches measure the pitch of the rack and divide by Pi (3.142....)
For DP divide Pi by the pitch in inches.
Best to measure the rack over say 10 teeth and then take the average rather than trying to measure just one tooth
Edited By JasonB on 07/05/2019 19:50:02
Bill Davies 207/05/2019 19:44:54
180 forum posts
10 photos
Adam, if you have some dowels or pins of a suitable and identical size to sit about halfway down in the tooth space, you can measure over the pins, over a distance of several teeth. Subtract the diameter of one pin, and divide by the number of teeth, less one (i.e., counting from zero).
By converting into appropriate units you can look up the pitch on a table of metric Module sizes, or diametral pitch (DP) for inch sizes.
Hopefully, this should get you started:
https://khkgears.net/new/gear_knowledge/abcs_of_gears-b/basic_gear_terminology_calculation.html
Bill
Bill Davies 207/05/2019 19:46:40
180 forum posts
10 photos
oops:
Link to gear calculations
Pete Rimmer07/05/2019 20:52:17
683 forum posts
49 photos
Set your digital caliper to 3.142 inches and offer it up to the rack teeth. If the jaws span a number of teeth exactly then count the teeth they span - that's the equivalent DP of the rack.
If the jaws don't span whole numbers of teeth then it's a module rack. Measure across ten teeth and divide the answer by 31.42.
Adam Harris07/05/2019 21:01:31
451 forum posts
19 photos
Pete, that is without doubt the most excellent response anyone could hope for! Many thanks, Adam
Michael Gilligan07/05/2019 21:23:15
15450 forum posts
668 photos
Posted by Pete Rimmer on 07/05/2019 20:52:17:
[...] If the jaws don't span whole numbers of teeth then it's a module rack.
Or perhaps, a 'circular pitch' Imperial rack ?
Pete Rimmer07/05/2019 21:40:45
683 forum posts
49 photos
Yeah it could be that Michael, good call.
Adam Harris07/05/2019 21:42:00
451 forum posts
19 photos
It is a metric machine (Schaublin 12) so indeed probably MOD
Adam Harris07/05/2019 21:48:57
451 forum posts
19 photos
Michael Gilligan07/05/2019 21:59:18
15450 forum posts
668 photos
Adam,
That looks like an ideal application for a circular pitch rack [be it Imperial of Metric]
... measure carefully
Edit: The first two PDFs from this page should help
http://www.davall.co.uk/dsg-power-transmission/catalogue/gears/
Edited By Michael Gilligan on 07/05/2019 22:02:39
Adam Harris07/05/2019 22:11:34
451 forum posts
19 photos
I will revert tomorrow in the daylight with measurements
Adam Harris07/05/2019 22:12:33
451 forum posts
19 photos
Michael thanks for that link
