Removing a sight glass
AdrianR06/05/2019 08:11:03
274 forum posts
20 photos
Before I start attacking the sight glass with force I thought I would ask here.
I have a leak from the head stock sight glass on my BH600. The Grizzly manual for the same type of lathe says to remove the sight glass to do an oil change.
The sight glass is completely round with no visible sign of o-ring or thread. I am sure it must be easy an easy trick to it. Any ideas?
Adrian
Edited By AdrianR on 06/05/2019 08:13:11
David George 106/05/2019 19:51:49
1054 forum posts
333 photos
Hi Adrian have you called Warco as no one seems to reply with your problem leak I don't know as I have never seen one of these lathes.
David
Martin Connelly06/05/2019 20:38:36
949 forum posts
114 photos
Hoses Direct sell these as push in polyamide items for tanks with wall thickness of 5mm minimum. Diameter 24mm or 30mm. Really cheap so I don't imagine the Chinese lathe manufacturers would use anything different. Try tapping out from inside the gearbox with a suitable sized socket as a drift.
Martin C.
