Bandsaw speed
How can I slow it down
Plasma01/05/2019 19:07:03
392 forum posts
45 photos
Hi all,
I have a small bandsaw which is direct drive from the motor, it's fine for cutting wood but I would like to use a metal blade in it for cutting brass.
I think it needs slowing down but have no idea how to achieve this by electrical means.
Does anyone have any suggestions as to how to go about making, fitting a speed controller or if it would be possible.
As an aside I have some 3/16th wide bandsaw coil 32 tpi wavy or rake set if anyone needs some.
Regards Mick
duncan webster01/05/2019 19:15:12
2549 forum posts
49 photos
From the motor plate I reckon that is a single phase capacitor start motor, so speed control is a non starter. Either ft a 3 phase motor, or arrange a counter-shaft to drop the speed (not all that easy I suspect).
Ian Parkin01/05/2019 19:15:55
765 forum posts
185 photos
Is it a Inca saw?
I use my Inca for cutting non ferrous materials with no adjustments
You cant really speed control that motor
replace motor with 3 phase or bring the motor off and use pulleys to slow it down if you think you need to
JasonB01/05/2019 19:37:59
17869 forum posts
1954 photos
I use my old Rexon for non ferrous at the standard wood speed, cuts ok if a bit noisy. Will go through 3" ali OK and have done 1" bronze.
Simon Williams 301/05/2019 19:39:14
499 forum posts
78 photos
Let's do a bit of arithmetic.
I've got a bandsaw I bought second hand recently, I've been musing on the same question. For my bandsaw a motor of approximately the same speed and power also drives the blade directly. For the sake of a worked example I'll use the dimensions I took from my saw.
Drive wheel is 1 foot in diameter, and runs at 985 RPM. So linear speed of blade is 1 x 3.14 x 985 ft/min = 3000 ft/min in round numbers.
Recommended speed to cut mild steel with high speed steel blade is approx. 100 ft/min. That's a speed turn down well beyond the range of any variable frequency drive three phase or otherwise. Not to mention the problems of keeping the motor cool.
I pretty sure (though I don't know how to quantify it) that the torque requirement to cut steel will go up from that needed to cut wood. So we're into some pretty significant gearing here. I've been musing on whether to make a planetary gear reduction along the lines of the Dore Westbury mill, but it's a lot of work and it's never going to happen.
Having said that, Stefan Gotteswinter says he cuts steel on an ordinary (vertical) bandsaw, but it's not clear what speed the blade is running at. Have a look at the YouTube video of his basement workshop walk-around.
An HSS blade is going to cost £20 or thereabouts a kick, my feeling is that the teeth will come straight off it as soon as you show it a piece of steel. Cutting ally or possibly brass will probably be OK, though the cutting speed is still far too high.
So I decided that a bandsaw designed for cutting wood wasn't a good place to start.
HTH Simon
edit - Jason (as ever) beat me too it.
Edited By Simon Williams 3 on 01/05/2019 19:40:51
Plasma01/05/2019 20:02:57
392 forum posts
45 photos
Yes it's an Inca saw. The 32 tpi blade cuts brass no problem but seems to load up when cutting aluminium.
May need a coarser blade I guess.
I have a pair of bandsaw wheels so could have a crack at making a steel cutting saw.
Mick
JasonB01/05/2019 20:10:29
17869 forum posts
1954 photos
Simon, not sure where you get your steel cutting speeds from but my Femi metal cutting bandsaw has two speeds - 60 or 80m/min which is a fair bit more than 100f/min
Martin of Wick01/05/2019 20:47:42
195 forum posts
4 photos
Depends on blade, teeth count, how robust and solid everything else is etc. My CY90 (budget class small horizontal band saw not that solidly build but performs well within its class) speeds are 20/30/50 m/min.
using 14tpi carbon steel blade at 20m/s it is quite comfortable with steels, but certainly not at 30m/s
Aluminium and brass fine at 30m/s, or lower, any higher it starts skipping and grabbing, so I have never use the high speed but expect it would be fine for plastics
Martin
martin perman01/05/2019 21:13:15
1813 forum posts
78 photos
Posted by Plasma on 01/05/2019 20:02:57:
Mick
Plasma,
Get your local saw doctor to make you a skip tooth blade, take your current one to him for the length and tell him what your trying to do and he should give you the correct tpi and skip tooth.
Martin P
Edited By martin perman on 01/05/2019 21:13:51
Plasma01/05/2019 21:26:16
392 forum posts
45 photos
As an add on, does anyone have any experience of brazing or silver soldering bandsaw blades rather than welding?
Just wondering if there is a preferred method of joining bandsaw coil without using a blade welder.
Martin not sure that I have a saw doctor, those kind of skills seem to have been lost.
Mick
ChrisB01/05/2019 21:44:05
476 forum posts
180 photos
I run a 1/2" 8/12 tpi vari-tooth blade on my Nebes tm101, is variable speed from 30 to 80m/min but most of the time it's set at 80m/min and I have cut both steel and aluminium without any issues. With higher tpi you'll get a better finish but it will take longer and probably load the blade with softer materials, I found the 8/12 vari-tooth works much better to the 14tpi the bandsaw came with.
As for welding a blade, I managed to weld one with a tig welder - acceptable, ie it didn't break again but I needed to grind a bit to remove excess material.
oldvelo01/05/2019 22:08:10
193 forum posts
48 photos
Hi Plasma
You will need to slow down the band speed with a counter shaft or gear box. May I suggest you use Poly Vee Belts 6 ribs will be more than adequate for the existing motor. Pulleys are easily fabricated and capable of quite large ratios.
Use an idler pulley on the back of the belt to give the small drive pulleys to give a better contact area.
More can be seen in my album Bandsaw 2.
Eric
pgk pgk01/05/2019 22:30:59
1729 forum posts
287 photos
Posted by Plasma on 01/05/2019 21:26:16:
Mick
If memory serves 'Tom's Techniques' did a youtube vid on silver soldering bandsaw blades
pgk
Bruce Newman01/05/2019 22:40:52
12 forum posts
Hello Plasma
To join a bandsaw blade, make blade about 3/4" longer than finished length, grind a chamfer about 3/8" long on each end so that when they overlap the blade is the right length.
Make a jig from a length of steel, 1" square will do, cut a recess across in the middle about 1" long x 1/2" deep. drill and tap a couple of screw holes each side of gap so that the blade can be clamped down by screws with washers.
Carefully line up blade ends across gap, chamfer to chamfer so the ends are in close contact, tighten screws, then flux and braze or silver solder. If joint ok clean up on grinder if needed to correct width so it runs smoothly.
Cheers
Bruce
Derek Lane01/05/2019 22:41:05
318 forum posts
73 photos
Mick
This GUY makes blades to suit many needs I use him for all my bandsaw blades.
IanT01/05/2019 23:27:46
1510 forum posts
142 photos
I use Tuffsaw too Derek - good quality, reasonable prices and great (e.g. fast) service.
I've purchased a range of bandsaw blades (various widths & tooth ratios) from him for my INCA bandsaw - but no way am I going to try cutting metal with it. It might well cut non-ferrous but so might SWMBO's bread knife given enough welly.
The INCA was designed to cut wood and it does so very well. I'm not about to risk 'naggering' one of my favourite wood working machines by trying to make it do something it was never intended for. If you want to cut metal Plasma - then get a saw designed to do so....there's quite a wide choice of them available.
IanT
JasonB02/05/2019 07:01:21
17869 forum posts
1954 photos
Posted by IanT on 01/05/2019 23:27:46:
This does raise the question of what sort of cutting Plasma wants to do.
There is a limited choice of vertical metal cutting bandsaws which are best for sheet where the deeper throat is the main advantage. If it is for cutting section to length then a horizontal will be better and you do have more choice at the lower price end of the market.
Now I have the Femi my old Rexon only gets used for the odd bit of sheet/plate that won't fit the Horizontal.
I also use 8-12 vari-pitch M42 in the Femi , the old woodworking saw uses up blades that are past their best for wood so mostly 10 or 12tpi for section, less for sheet/plate.
Edited By JasonB on 02/05/2019 07:01:53
Bruce Newman02/05/2019 08:10:23
12 forum posts
Whoops! I made an error on joining bandsaw blades, should say: make blade 3/8" longer and not 3/4". Schoolboy error.
Bruce
martin perman02/05/2019 08:22:40
1813 forum posts
78 photos
Here are a couple of pictures of a vertical bandsaw I recently moved on to a new home, the previous owner had modified it to slow it down. Sorry about the pictures, they are upright on my laptop.
Martin P
Mick Henshall02/05/2019 09:47:59
531 forum posts
31 photos
A floor polisher/ buffer has a output rpm of about 325 ( via two gears ) with 1 ft bandsaw wheel gives around 1020 ft per min, a 2" pulley on motor driving a 8" on countershaft gives 255 rpm, a countershaft pulley of 2" driving 4"on bandsaw gives about 127 rpm. My maths are suspect but 130 ft per min should be ok, find an old buffer. I used a buffer motor to drive a prototype home built shaper with success
Mick 🇬🇧
