Rivets
Peter Maloney24/04/2019 20:08:16
32 forum posts
12 photos
A BIG MISTAKE PERHAPS?
Some time ago I made my Pansy footplates complete with holes for dummy rivets to be glued into place. I then sprayed them with grey car primer to prevent rust. I now want to glue the rivets in place. I can easily remove the paint from the flat surface but how on earth do I remove it from inside the holes? Any suggestions guys?
Peter
Brian Sweeting24/04/2019 20:15:52
419 forum posts
Suitable sized drill bit hand turned?
Johnboy2524/04/2019 20:18:29
259 forum posts
Hi Peter. I would suggest using a hand reamer of the same size of the original hole. This will only take out the paint and not enlarge the hole for the rivets.
duncan webster24/04/2019 22:01:26
2591 forum posts
34 photos
If the paint is stuck to the footplates, which I suppose it is, and the glue sticks to the paint, where is the problem?
Jeff Dayman24/04/2019 22:57:45
1818 forum posts
45 photos
Do the rivets fit with the paint in? If so glue 'em in, paint and all, per Duncan's suggestion.
Nick Clarke 325/04/2019 09:00:11
764 forum posts
26 photos
At the school model railway club a long time ago we had a visit from a prize winning locomotive model maker who, before the advent of super glue, used to use a tiny blob of paint to hold details like lamp irons onto 00 gauge loco models - until he sent one to be professionally painted and the first thing they did was to degrease it by dumping it in a bath of solvent - when all of the super details promptly fell off!
Paul Lousick25/04/2019 09:36:40
1414 forum posts
541 photos
The horn plates and tender on my model traction engine have lots of false rivets. The holes on the back of the plates were countersunk. The rivets shank cut slightly thicker than the plate and then bashed with a ball peen hammer to fill the countersink. Then painted everything.
Paul.
Peter Maloney25/04/2019 20:01:44
32 forum posts
12 photos
Hi Duncan/Jeff
My thoughts were leaning towards 'glue 'em in paint and all. Will try a few and see what happens. Nothing to loose after all.
Thanks Guys
