Pivoting bolt
Roger Hulett24/04/2019 17:33:36
131 forum posts
9 photos
I have a bolt which,after the nut has been threaded on a certain distance,pivots downwards,effectively stopping the nut from running off the bolt. I wonder if anyone knows the name of this type of bolt and,indeed,if they are currently available. I do not relish the idea of making some. It is from a 1920 motorbike.
David Standing 124/04/2019 17:52:20
1296 forum posts
50 photos
A photograph, as ever in these situations, would help! smiley
Hopper25/04/2019 10:59:45
5505 forum posts
137 photos
I think it was an idea that did not catch on. Never seen or heard of such bolts in half a century of messing with machinery, including 1920s motorbikes. But also sure would like to see a photo or drawing of such.
I'd say your choices are make your own -- could be an interesting exercise but can't quite visualize it -- or use holes and split pins like most other bikes of the era.
What sort of bike is it from, and what part does it secure?
JasonB25/04/2019 11:28:44
21467 forum posts
2455 photos
Sounds like a threaded version of a clevis pin like this one with an end that pivots to lock in place.
Sandgrounder25/04/2019 11:56:37
230 forum posts
6 photos
I've not seen a threaded version before, but If you Google 'drop nose pin' and select images you'll see plenty of variations.
Roger Hulett27/05/2019 16:16:21
131 forum posts
9 photos
Sorry I haven't replied to these posts but have been having a bit of resection,I think that's what it's called. Anyway up, completely my fault,I didn't derust and clean up the pin. It was a pin after all.. So the above information was correct and very useful.Thankyou all very much. New post coming up about brass soldering,(again)
Roger Hulett30/05/2019 12:25:58
131 forum posts
9 photos
Apparently they go by many names. Hinged Pin,Drop Nose Pin,Link Pin,Dead Link Hinge Pin. The only problem is no-one seems to make them in the size that I want. They are mostly for marine applications and are either too small or too large...... I will keep searching as I don't think I can make one!
Trevorh30/05/2019 12:36:04
303 forum posts
87 photos
Have you tried the chandlery or dinghy spare part outlets such as Force4 or Harkin we use those pins from 3mm dia by 10mm long up to 20mm dia by 100mm long for the yachts
try searching for Clevis Pin
regards
Trevor
Edited By Trevorh on 30/05/2019 12:37:30
Harry Crowther30/05/2019 14:01:49
18 forum posts
Perhaps try a castle nut and split pin such as these: **LINK** or maybe you could use a different type of locking nut ?
HOWARDT30/05/2019 16:21:26
780 forum posts
28 photos
See if something here will do.
Goodhand
walker midge
JD Metals
rapid Direct
