Forum sponsored by Allendale July 23rd
ZAY7045FG/1
Quill removal
Gianfranco Ronchin22/04/2019 13:39:37
1 forum posts
I have used this ZAY7045FG/1 for some good work and it has become noisy.
I believe it is in the spindle bearings.
They may need replacement or better just adjustment , tighten them as they are conical.
I need some information on how to remove the quill so I can inspect those bearings.
The company support is limited to how to use it.
Thank you
Gianfranco
JohnF23/04/2019 10:55:30
842 forum posts
95 photos
Hi Gianfranco, a little more info on your machine and a few photos may yield some information if anyone recognised it as a brand sold in the U.K. or USA
Put some phots in an album I’m sure it will be helpful
cheers John
mgnbuk23/04/2019 13:43:39
507 forum posts
10 photos
This machine looks similar to the Grizzly G0761, for which a manual & parts list can be downloaded here
To remove the quill it looks (from the parts list exploded diagram) that you remove the feed pinion assembly, return spring & depth stop and the quill should drop out from the bottom of the head. It may also be possible to access the preload locknut from above with the quill in place by removing the gearbox top cover.
The quill design seems similar to my RF30 mill/drill.
HTH
Nigel B
TRANSWAVE Converters
Meridienne Sept 2019
Advertise With Us
