Presumably this is done using CNC... but even so its impressive
Ian P19/04/2019 21:45:58
2352 forum posts
98 photos
I saw this on Twitter and however its done its impressive engineering. The link below is to a short video.
Invisible Joints
Ian P
lfoggy19/04/2019 21:50:58
133 forum posts
16 photos
That is almost unbelievable. For the joints to be invisible to the naked eye the gap must be microns...
Mike Poole19/04/2019 23:41:46
2542 forum posts
60 photos
Probably an apprentice filing test piecewink
mike
Jeff Dayman20/04/2019 01:26:10
1789 forum posts
45 photos
It is microns and it is CNC. Lots of shops in China can do that level of matching particularly in moulds. However it is time consuming and expensive and of very little practical use except for very small parts.
One thing that mouldmakers do in China that has been a continuous annoyance to me in industry for many many years is the use of 4 locators between inserts, at the corners, as the test piece in the video shows. To restrict all the degrees of freedom of the inserts, only two locators, at diagonal corners, and a flat area on the parting line are needed. To make 2 totally unnecessary close fitted locators at the other two corners is a waste of money and in many cases leads to confusion and errors at final fit up and bluing-in of the mould. Several times I have seen a toolmaker miss his bearings and grind off the wrong locator causing a loose fitting mould insert, and unless it could be welded, could result in a $20,000 to $50,000 insert being scrapped. I gave up arguing with mouldmakers in China about this around 25 years ago. It is just a tradesman's bad habit that probably started very early on in the development of the trade in China. As great as some of these guys are, they keep doing the 4 locator thing over and over again despite frequent fit cockups and despite about 100,000 Western toolmaking / tool design guys like me asking them for 35 years PLEASE don't do it! I may as well talk to the wall.
When I first started programming CNC wire edm machines for mouldmaking I got a panicky call from a toolmaker in our company shop "the four insert sets we just cut don't fit the blocks. Your programs must have been rubbish". I went down ASAP, heart in mouth of course. Sure enough, they didn't fit. I did notice that he had blued them as we usually did when machining them conventionally. Bystanders were coming around for a look at the disaster. As a last hope of the off chance I'd get lucky, I said "can we try cleaning off the blue?" We did, and the inserts fit, dropping in by gravity with a light suction sound. Everybody on the toolmaking team was quite shocked. I resumed breathing, because I still had a job.
You may say oh there was a speck of dust the cleaning cleared out, or a tiny chip, but this was the same case on ALL FOUR sets of inserts and blocks...... I'm not blowing my own horn, but my programs were proved right. But just as important, if not more important, the wire edm operator was damn good and very careful about all parameters, and the guys at Japax that built that old wire edm machine in the early 1980's really knew their stuff.
With this team and that machine, that sort of ultra close fits in our tools became our shop standard - 30 odd years ago in Toronto Canada.
Donald Hill20/04/2019 02:26:19
16 forum posts
Take a look at this : www.youtube.com/watch?v=sFrVdoOhu1Q
Don Hill
not done it yet20/04/2019 02:56:36
4495 forum posts
16 photos
Guessing that uses of these would be injection moulding, diesel fuel injectors and clearly air bearings. Any examples of others?
Do they, I wonder, really need to fit piston rings to F1 engines these days! Although a minute temperature difference between parts might cause interference?
Plasma20/04/2019 08:10:45
391 forum posts
45 photos
Simply stunning level of accuracy and work.
I would love to see a video of the work being done but that would be like seeing how a magic trick was done and spoil the magic.
Michael Gilligan20/04/2019 14:02:14
15462 forum posts
668 photos
I find it rather frustrating that the initial posting on Twitter did not include a reference to the source of the video clip ... just the 'witty' comment: 17th qualification in passes plus 14th grade polishing.
Translation via DeepL **LINK**
... Such lack of simple courtesy seems to be the way of the world these days.
https://www.deepl.com/translate#ru/en/17-й%20квалитет%20по%20дпускам%20плюс%2014-й%20класс%20полировки.
Edited By Michael Gilligan on 20/04/2019 14:02:50
Barrie Lever20/04/2019 14:17:56
479 forum posts
44 photos
Posted by not done it yet on 20/04/2019 02:56:36:
NDIY
Not sure about the setup on F1 engines regarding piston rings, however high performance model two strokes do not benefit from piston rings in any way, in fact you cannot get the performance from a ringed engine that you can from a tapered bore (chrome plated) non ringed alloy piston engine.
Main benefits in this setup for model engines are a very superior seal at TDC, low friction away from TDC, an ability to run huge ports with no bridges because the ring is not constantly try to jump into the port and seizures being unheard of due to well matched expansion rates.
I know Aprillia tried the tapered bore ringless piston setup on a 125cc racing motorcycle engine but it was not successful.
B.
Mick B120/04/2019 15:00:45
1547 forum posts
83 photos
I know I have a suspicious mind, but I think the deployment of a bit of CGI to those sequences would be pretty easy, certainly at the resolution levels we're seeing there...
devil
Bill Phinn20/04/2019 19:57:33
310 forum posts
63 photos
Posted by Michael Gilligan on 20/04/2019 14:02:14:
I'm not quite sure what you mean by "source", Michael, but the four character company name cut into the side of the piece is 北京精雕 (Beijing Jingdiao), which just translates as "Beijing fine engraving". Their website is here, and they have an English version too.
Edited By Bill Phinn on 20/04/2019 19:57:54
Michael Gilligan20/04/2019 20:08:13
15462 forum posts
668 photos
Posted by Bill Phinn on 20/04/2019 19:57:33:
Thanks, Bill
By "source" I just meant the originator of the video
Thank you for the translation and the link yes
Neil Wyatt20/04/2019 20:14:21
17712 forum posts
697 photos
77 articles
Remarkable!
Don't leave them fitted together for too long!
martin perman20/04/2019 20:49:27
1810 forum posts
78 photos
In the sixteen years I worked for Lucas CAV diesel fuel injectors where not manufactured with this method, needles were manufactured using centerless grinders to a nominal dimension the nozzle body was internally ground to a nominal dimension and finished with honing of the bore.
using air gauges the diameter of the needle and nozzles were measured and matched to a very tight tolerance.
Martin P
jimmy b20/04/2019 21:26:05
622 forum posts
38 photos
Impressive!
Jim
Tony Pratt 122/04/2019 14:27:33
1099 forum posts
Nice bit of photography.
Tony
Neil Lickfold22/04/2019 22:54:56
591 forum posts
102 photos
If the gap is less than 4 um, and all the same height/geometry , you will not see the line on fitted parts. Like on silicon moulding tools, the ejector pins need to fit better than 5 micron on diameter clearance, or else the material will go down the sides of the ejector pin. Skim wire edm to my knowledge was the 1st to be able to achieve these sort of tolerances on shaped parts. Now with sub micron machining centres, this level of accuracy can be achieved with milling cutters even with hardened parts. The way it came about with more than one reference was from the introduction of cad cam, and the new generation of designers and machine tool users not being trained in the traditional methods of toolmaking. Now there is another generation that have almost no knowledge of making something from solid, and they only know about additive processes and EBM Electron beam Machining, and EBP Electron beam Polishing.
Nick Hulme23/04/2019 17:11:58
743 forum posts
37 photos
Even so?
That would be because you know what's involved in learning CAD/CAM/CNC and actually making precision parts and have achieved this, since it is obviously simpler than what you do?
dont know
