Myford ML10 lives again
Dave Springate12/04/2019 07:31:06
56 forum posts
121 photos
Well at long last it's finished and running again. I'm really pleased with it and have enjoyed the strip and clean up. I had a problem with the electrics but thanks to the help and advice from a forum member David (AKA Myford boy) I got it sorted. Thanks again David !
https://youtu.be/FpisXN4anGQ
Dave Springate12/04/2019 19:30:45
56 forum posts
121 photos
not done it yet12/04/2019 21:00:32
4503 forum posts
16 photos
You will only need the reverse for running off-load - unless you have some means of preventing the chuck from unscrewing!smiley
Mick B112/04/2019 22:52:14
1552 forum posts
83 photos
Posted by not done it yet on 12/04/2019 21:00:32:
If the chuck's done up tight, you need quite considerable resistance to make it unscrew. I used to sand and polish wood quite heavily in reverse as well as forward on the Speed 10 I had, without ever having that happen. It's also sometimes easier to get a knife tool at an angle to the the far side of a workpiece and chamfer the face in reverse.
Probably not heavy screwcutting, though... laugh
Emgee12/04/2019 22:52:33
1448 forum posts
212 photos
Hi Dave, nice job you did there.
Couldn't see any remote Stop in case you get caught up in the chuck or belt, perhaps it's at knee height ?
Emgee
Barrie Lever12/04/2019 23:37:30
483 forum posts
44 photos
Posted by Dave Springate on 12/04/2019 07:31:06:
That is a really nice restoration, that will do you some nice work.
Barrie
Dave Springate13/04/2019 09:54:08
56 forum posts
121 photos
Posted by Emgee on 12/04/2019 22:52:33:
Emgee
Hi Emgee, Yes a bit of an oversight on my part, I have no tooling for the lathe yet and would like a quick change toolpost so while I save some pennies for these items I have ordered an emergency stop button and will fix to the front of the bench before I start to use the Lathe.
