mini turning
Roger Hulett11/04/2019 13:32:57
131 forum posts
9 photos
I have a 70mm x 5mm brass rod. I need to turn this down to 3mm. At one end there needs to be a 45degree angle to take the rod from the turned 3mm to the original 5mm. I have a 1939 South Bend 9" a small Pools horizontal mill. Rotary Table, Vertical slide. Pillar drill
Advice on the correct procedure to carry this out will be very much appreciated.
Former Member11/04/2019 13:47:57
mechman4811/04/2019 14:39:15
2631 forum posts
408 photos
+1 for drilling, solder then bend, easiest way as Bills method above.
George.
JasonB11/04/2019 14:43:55
17837 forum posts
1951 photos
1 articles
How long is the 3mm section?
If it is long do you have spare material for tailstock support?
Roger Hulett11/04/2019 14:57:42
131 forum posts
9 photos
Sorry, did not explain myself correctly. I should have said the 3mm diameter will TAPER
out to the 5mm diameter.
Former Member11/04/2019 16:09:27
Samsaranda11/04/2019 17:23:24
907 forum posts
5 photos
Sharp tool and required angular offset on the tool holder, with 5mm brass rod you wouldn’t need any support or steady, I have made fuel control needles in smaller diameter brass without problems, you need a sharp tool and shallow cuts.
Dave W
JasonB11/04/2019 18:17:41
17837 forum posts
1951 photos
1 articles
Posted by Samsaranda on 11/04/2019 17:23:24:
I would if the taper is over the full 70mm length, a question that has not yet been answered.
Edited By JasonB on 11/04/2019 18:17:57
Emgee11/04/2019 18:18:10
1445 forum posts
212 photos
Roger, if you only need a short length of 3mm diameter use a facing & turning tool which is ground to 45 deg angle to the lathe axis, either take 1 x 1mm DOC or a series of cuts to achieve the 3mm diameter, at the 1mm DOC you will have your 45 deg transition from 3-5mm.
Emgee
Former Member12/04/2019 17:44:29
Neil Wyatt12/04/2019 17:51:55
17714 forum posts
697 photos
77 articles
If the tape angle is 45 degrees as stated, then an angled tool will do the job.
Mount 5mm rod in the mill, set up a tool in the vertical slide attached to the table and do the job with a single cut.
duncan webster12/04/2019 18:01:06
2538 forum posts
49 photos
Posted by Neil Wyatt on 12/04/2019 17:51:55:
why use a milling machine when the OP has a lathe?
Roger Hulett13/04/2019 11:28:57
131 forum posts
9 photos
OK everyone,Thanks very much. Job done. 45degree tool did the job.
Former Member13/04/2019 11:52:53
Ian S C13/04/2019 13:01:17
7468 forum posts
230 photos
A rough sketch on a bit of paper with a pencil can be useful.
Ian S C
Roger Hulett24/04/2019 12:23:44
131 forum posts
9 photos
It's all I can do to work a lathe and type letters on a computer Asking me to take pictures or draw sketches and post them.......well. ..............Now ............... If my great grandson was here........ no prob.
Ausee.com.au
