Gear cutting
Garry Coles10/04/2019 15:24:17
55 forum posts
Hello,
I’m currently building the 2 in Durham & North Yorkshire traction engine. Blackgates Engineering have supplied me with the various gears, but can no longer supply the set of 5 compensating gears as the supplier has retired. Can anyone point me in the direction of a supplier of finished gears.
Many thanks
Garry
Garry.coles762@gmail.com
john fletcher 110/04/2019 17:25:29
572 forum posts
I've no idea on the size of the gears you need but HPC at Chesterfield have a large selection and their catalogue has a lot of useful information 01246 268080 also, what about DAVAL I haven't their current number but was 0707 2722722. John
Gray10/04/2019 18:24:45
1023 forum posts
13 photos
Give MJ Engineering a call, Alan can cut gears for most engines although the DNY is not on his list he may be able to help.
JasonB10/04/2019 18:26:08
17257 forum posts
1858 photos
I doubt anyone will have the finished bevel gears for the diff off the shelf, you would either have to cut them yourself but they would not be true bevels or maybe get them 3D printed and cast, should be able to run cast on cast if they are done well, final option would be to find a friend with CNC and a 4th axis.
Not sure if MJ can do them and Malcom who used to do them does not do so much now and they don't have the machines for true bevel gears.
Edited By JasonB on 10/04/2019 18:28:16
Jim C10/04/2019 18:42:30
61 forum posts
4 photos
Try Brunell engineering. They support both 2 an d 4 inch Durham’s.
Boiler Bri10/04/2019 21:14:01
815 forum posts
287 photos
Before approaching Brunel I would look up posts on this forum as to the reliability of supply from them.
duncan webster10/04/2019 21:18:44
2412 forum posts
39 photos
could try Reliance gears, I've found them cheaper than HPC
reliance
DMB10/04/2019 22:44:15
968 forum posts
Way back in the 60's(?) a gear manufacturer by the name of Muffett, Tunbridge Wells, used to regularly advertise in ME. I had some very nice small gears from them in more recent times - very satisfied customer.
DMB10/04/2019 22:50:47
968 forum posts
www.muffettgears.co.uk
Garry Coles11/04/2019 07:38:06
55 forum posts
Well, thank you everybody for all the tips. That know gives me a chance to contact these people and find out if they can make the gears for me.
Garry
Norman Rogers11/04/2019 09:18:16
17 forum posts
It's a thumbs down from me for Brunell ...
