Forum sponsored by Allendale Oct 22nd
Long drills
Speedy Builder501/04/2019 06:42:22
1833 forum posts
128 photos
I had an interesting problem the other day, Needed to drill a 1/16"hole down in a deep pocket. As per usual, I had the small drill mounted in a pin vice, but was still a few inches too short. racking my brain for a quick soloution, I mounted the pin vice into a Wood Bit Extender. Worked perfectly, perhaps a bit wobbly, but it did the job.
David George 101/04/2019 07:18:42
943 forum posts
310 photos
Hi nothing wrong with using a wood bit extender if you have one, very good. If you havn't you can always use a piece of silver steel drill the end for drill size and loctite the drill in the end. You can always do the same for taps to tap down deep holes.
David
Brian G01/04/2019 08:29:00
603 forum posts
25 photos
Posted by David George 1 on 01/04/2019 07:18:42:
..You can always do the same for taps to tap down deep holes.
David
Your advice is exactly a day too late for me David, Iast night I shortened a part to allow the tap to reach the threaded portion, this morning I would have done what you suggest
David George 101/04/2019 10:37:15
943 forum posts
310 photos
Here's a couple of long taps I made recently. And an Allen key although the hexagon is tapped in to a slightly smaller than across points on hexagon only.
4mm tap 5mm tap and 3mm hexagon key.
David
Ian P01/04/2019 15:30:54
2208 forum posts
90 photos
These are some of the extended drills I have accumulated. Most of the extension material I get from rails and guides in discarded ink jet printers and drills or cutter is retained by whatever is convenient at the time. I've used grub screws, press fit, deformed the tube wall into notch or flat.
Longest extension I have made was a 1.5m length of 1/2" diameter steel bar drilled to accept a 16mm wood flat-bit which I used to drill vertically downwards through the various noggins in a studded bedroom wall in order to run wiring to a new light switch without having to do any subsequent redecorating.
Ian P
Vic01/04/2019 16:00:34
2294 forum posts
11 photos
Nice job Ian, thanks for sharing. yes
Jeff Dayman01/04/2019 16:46:32
1643 forum posts
42 photos
Do you need an extra long screw after drilling with those long extension drills? smile d
Perko703/04/2019 02:55:39
281 forum posts
23 photos
Or maybe just an extra-long screwdriver?? laugh
Howard Lewis05/04/2019 19:17:45
2386 forum posts
Long screwdrivers are, or were, available. Can't remember where or when I got them, but two. One for cross head screws, the other for Pozidrive. Both are about 500mm long. Yes, they have been used, but not often.
Martin Cargill05/04/2019 20:30:50
107 forum posts
I have a cheap chuck type tap wrench that I use for hard to reach places. I modified it by making the sliding T handle removable and then filing a 13mm hex end on the wrench. The wrench still works as normal but for difficult and awkward holes I can use a 13mm socket (with as many socket extensions as required) or I can use it with a ratchet spanner. Obviously you need to be careful not to snap taps when using a single sided driver but with caution anything is possible.
Martin
TRANSWAVE Converters
cowbells
Meridienne; London MES
