Please help machining
Help
Jo Ford31/03/2019 21:22:03
11 forum posts
Hi everyone model engineering is not my hobby but I do love some of the stuff you guys create, I’m really struggling to find someone to machine a part, its for a 1920s printing machine I have one but need 10 more everyone I’ve contacted seems to think it’s impossible to make but they managed it 100 years ago so surely it must be I think they are just not interested, could I post up some photos and see if you guys think it’s doable thanks in advance
Plasma01/04/2019 08:35:54
350 forum posts
43 photos
Hi Jo.
Certainly post some pics in an album and attach to this post so we can see the part to be copied.
Is it turned or milled? Or maybe cast if it's a complex shape.
Most things can be done but its usually a question of cost. A company would have to charge to make one off or short run pieces so it's easier to say it cant be done. A bit like a builder not wanting to bother with a simple repair, it's not worth their while.
But a home machinist may tackle it if it's not a complex casting job.
Best regards Mick
Paul Lousick01/04/2019 09:45:59
1283 forum posts
512 photos
Hi Jo,
A drawing or photo with a few dimensions would help. You also need to tell us where you live. There are members all over the world. I am in Australia.
Paul.
David George 101/04/2019 14:09:29
1054 forum posts
333 photos
Hi Jo If you click on the Forums tab on the black band on the top of the page and then click the website FAQ there is information on how to put pictures on here etc I hope it helps.
David
vintage engineer01/04/2019 17:29:35
217 forum posts
Anything can be made. It's only dictated by time and money.
Jo Ford01/04/2019 17:35:14
11 forum posts
Hi guys thanks for the help I’ll sort some photos and see what you think, maybe I’ve been going to the wrong places like you say small run not worth the effort cheers
Maurice01/04/2019 17:39:20
451 forum posts
50 photos
Where in the world are you Jo?
Maurice
Jo Ford01/04/2019 17:43:38
11 forum posts
Hi I’m in uk Norfolk, thanks I’ve uploaded some images to an album but they are not appearing yet, not sure if they have to be approved first thanks
Neil Wyatt01/04/2019 18:13:42
17070 forum posts
690 photos
76 articles
Hello Jo,
Something has gone wrong - make sure you are uploading JPG files.
Jo Ford01/04/2019 18:19:40
11 forum posts
Hi yes I’m trying to do it from my phone they are jpg I’m bloody useless at this stuff haha
Jo Ford01/04/2019 18:53:14
11 forum posts
Hi here it is it’s hard to see but it’s about 4mm diameter it’s basically cylindrical for the first 1/3 then it has 3 grooves running down each side so it then turns almost triangular and finished with a point, made of metal hope that makes sense thanks guys
29858432-724c-4ed9-a13a-0cc85fc265b3.jpeg71da7aab-0a96-4266-9ab6-1a7082224cc9.jpegc1d004ae-e369-46ae-bbce-2f2b69f8aa28.jpeg05098ee6-979d-49fe-ba15-ec664ed384ab.jpeg
Edited By Jo Ford on 01/04/2019 18:56:42
Martin Connelly01/04/2019 19:19:15
951 forum posts
114 photos
Looks straightforward. If someone said impossible it must have been followed by a modifying comment such as "for no cost" or "at a price you will pay" . Were these professional machine shops?
Martin C
Jo Ford01/04/2019 19:22:05
11 forum posts
Hi yes all proper companies they seem to think cutting the grooves is the hard bit but I just think they had no interest probably more interested in large runs for big companies cheers
Martin Connelly01/04/2019 19:33:09
951 forum posts
114 photos
You can cut the grooves with a suitable radius ball nose cutter and the work piece supported along its length. Turning the part through 120 degrees can be done in numerous ways. You probably need a hardenable steel but that is also not a problem.
Martin C
Jo Ford01/04/2019 19:57:40
11 forum posts
Hi Martin thanks you make it sound so easy haha, so would they just use a rod of hardened steel and cut into pieces then shape the grooves thanks guys
Jo Ford01/04/2019 20:00:17
11 forum posts
If anyone knows of anyone/company that could do it I’d love to hear many thanks
Emgee01/04/2019 20:20:12
1347 forum posts
212 photos
Looks like a job for a tool post mounted grinder, cutting something that small with a ball nose cutter sounds unlikely to me.
Emgee
vintage engineer01/04/2019 22:47:17
217 forum posts
I suspect they would have been forged originally.
John McNamara01/04/2019 23:19:05
1311 forum posts
113 photos
Hi
You may find a sewing machine needle that can be adapted to your machine, maybe you could get a longer needle and remove the thread eye and make a blunt point most will already have a groove. The material will be high quality hardened steel so the result will be durable. It can be ground easily but not turned.
Locally industrial sewing machine suppliers will have needles.
The link below may assist also, Schmetz are a leading manufacturer of needles.
Send them the dimensions of your needle
Plasma02/04/2019 07:40:42
350 forum posts
43 photos
Private message sent Jo.
