Forum sponsored by Allendale Nov 29
Scaling dimensions
ronan walsh25/03/2019 20:04:39
497 forum posts
32 photos
Is scaling a drawing up or down a simple matter of multiplying or dividing the given dimensions by a set figure, say 2x or 4x ?
Or is it as i suspect more involved than that ?
JasonB25/03/2019 20:07:00
15012 forum posts
1528 photos
That's all there is to it.
You may find you need to tweak some sizes to match available stock sizes
Mike Poole25/03/2019 20:35:00
1802 forum posts
44 photos
Scaling down can sometimes make thing overly flimsy so it may be worth having a think whether the part will have sufficient strength after scaling if it has to work at the reduced scale. I think the same occurs when scaling up thing can be overly chunky and stronger than required.
ronan walsh25/03/2019 21:18:00
497 forum posts
32 photos
Well it will be upscaling i will be doing most likely, i see a design for a simple steam engine, but its a bit small for my machines and i prefer larger models anyway.
Jim Nic25/03/2019 22:02:21
168 forum posts
87 photos
I scaled up this Mogens Kilde designed Double Diagonal engine by two by simply doubling the drawing dimensions and found that while most aspects looked OK at twice design size, the fasteners most definitely did not. Bigger - yes, but not twice as big. I actually used BA fastenings instead of the metric called for on the drawings and just chose sizes I thought would look right and took the view that for an air powered model whatever I chose would would be strong enough.
Jim
Edited By Jim Nic on 25/03/2019 22:04:23
Neil Wyatt26/03/2019 09:41:27
15687 forum posts
659 photos
73 articles
Posted by ronan walsh on 25/03/2019 20:04:39:
In principle, but you may find things start to look a bit chunky, especially fixings. Also as Jason says, convenient stock sizes may not be available.
Ausee.com.au
TRANSWAVE Converters
