Temperature probe
Speedy Builder524/03/2019 07:14:56
2500 forum posts
196 photos
Can anyone tell me if there are low cost temperature probes with readouts about. I am looking to measure car cylinder head, carburettor and fuel temperature of my Austin 7 whilst driving under certain conditions. I have tried to get some "1 wire" temp sensors(18B20s) to work over the I2C bus of a BBC MicroBit micro computer, but fear it has defeated me, so looking for something which already exists. Temp range would be from -5 to 140 deg C and the distance from the probe to the readout about 1 metre.
Plenty of examples with the Arduino micro, but not for the Microbit ! - Perhaps I should change micro computers !
BobH
Paul Lousick24/03/2019 07:53:16
1901 forum posts
673 photos
Temperature probes are available for use with a multi-meter at reasonable prices. (electronic store, ebay, etc). I think they work by measuring the change in resistance of the sensor as temperature changes. Some multi-meters have a temperature setting on their display.
Another option is one of the hand held laser temperature guns. (Cheap as chips on ebay). Dis-assemble and use the internal parts with longer wires. Or operate it remotely with a lever or cable system. They have a hold feature that stores the temperature reading.
Paul.
Edited By Paul Lousick on 24/03/2019 07:57:02
John Paton 124/03/2019 08:11:31
317 forum posts
17 photos
Are you looking for two or three K type thermocouples and a data logger to run them simultaneously?
there are a number of cheap single channel meters that you can plug a thermocouple into but you might do better with a data logger if needing several channels.
Adam Mara24/03/2019 08:15:04
162 forum posts
Have a lok at 'JAGETRADE Garden Tools -50~110 °c DC 12v Digital LED Thermometer Car Temperature Monitor Panel Meter Blu' it may be the answer if you don't want to log results. I have a couple of similar Inkbird units that have proved very reliable.
Brian Oldford24/03/2019 08:24:15
686 forum posts
18 photos
This youtube video by Ralph Bacon may be helpful.
https://www.youtube.com/watch?v=dRGX_8P_98w
Welcome to the Arduino world.
Jeff Dayman24/03/2019 09:00:44
2199 forum posts
45 photos
Something like the units at link below might work. They list for $27 each on Digikey.ca . May be cheaper from Asia, probably made there.
https://data.kleintools.com/sites/all/product_assets/documents/brochures/klein/96505_ET05%20Digital%20Thermometer%20SellSheet_revB_%20pdf.pdf
Jeff Dayman24/03/2019 09:03:45
2199 forum posts
45 photos
accidental double post - sorry
Edited By Jeff Dayman on 24/03/2019 09:04:28
Nick Clarke 324/03/2019 09:22:45
1322 forum posts
53 photos
I bought one of these a couple of months ago - OWON B35T+ Datalogger true RMS Multimeter Temperature Tester Bluetooth 4.0 BT - eBay 223443667199 - 44GBP at present
As well as being a multimeter it comes with a temperature probe (thermocouple) but I also bought a K type thermocouple probe to use with liquids eBay 272654971464 - 3GBP
It will log a series of readings and store them internally or send them via Bluetooth to a computer, tablet or similar.
With many devices it will read out the reading as you take it - very useful if you are poking around in something - you don't need to look away. Works on my android phone and also on iPhone, if not others.
A satisfied customer!
Edited By Nick Clarke 3 on 24/03/2019 09:23:38
Former Member24/03/2019 10:21:28
SillyOldDuffer24/03/2019 10:32:51
7918 forum posts
1725 photos
Posted by Speedy Builder5 on 24/03/2019 07:14:56:
BobH
The Arduino is a better bet for this sort of project. In this case "better" than the Microbit because it's well established and loads of libraries & tutorials have been written for it - including the 18B20!
Installing and learning the Arduino IDE, and then a smattering of 'C' programming is a bit intimidating, but if you want to have a go I'm happy to provide support, and there are others on the forum.
Speedy Builder524/03/2019 11:10:21
2500 forum posts
196 photos
Wow, opened a hornets nest!! Thanks for all the replies. I have to admit that the Microbit areana leaves this sort of project a bit short, and may consider a change over to Arduino and in the short term go for three of the cheapo displays as well. Dave, Message sent and thanks - I may take you up if I go down the Arduino route.
BobH
I.M. OUTAHERE25/03/2019 04:00:20
1468 forum posts
Has the code and wiring to set up to 8 channels using the 18B20 sensor .
Edited By XD 351 on 25/03/2019 04:01:51
Joseph Noci 125/03/2019 06:19:17
1029 forum posts
1272 photos
Speedy,
If you just want to get the reading job done, and not hack about, there are a number of inexpensive options -
an example - 4 channel handheld readout device that does all you wish..click the link...
4 Chan Handheld
If you want to hack - first a simple device , Type K input device - AD8495 - with analogue out to, eg, a multimeter ( or anything, Microbit included, that has A to D inputs to read a voltage) - nicely mounted on a breakout board so easy to use..
Analogue Devices AD8495 from ADAFRUIT
Or if you want to hack even more...Some serial IO devices (SPI).
MAX31855 on breakout board - SPI interface
MAX6675 on breakout board - SPI interface
Joe
Sp fix..
Edited By Joseph Noci 1 on 25/03/2019 06:21:14
AJW25/03/2019 08:34:23
362 forum posts
137 photos
Used a type k thermocouple connected to suitable multimeter on my Vauxhall.
Held the sensor in position required with tyewrap and run wire into car via door aperture to meter.
Not high tech but worked fine!
Alan
JD Metals
MIDLNDS GARDEN RAIL Jan 2022
rapid Direct
