Forum sponsored by Allendale Nov 29
45mm Narrow gauge locomotive drawings
Mike B21/03/2019 15:42:02
3 forum posts
Having been to the garden rail show at the weekend (16/17th March 2019) and seeing the beautiful Accucraft Bagnall 0-4-0 locomotive I'm rather keen on the idea of making something similar. Yes I could buy it and its lovely but I'm partial to the idea of making one.
So with this in mind does anybody know of drawings that are available (either download or purchase) for a 45mm Narrow gauge British outline model steam locomotive (preferably not the ALCO mountaineer as its frames are a mare) but it doesn't necessarily have to be 0-4-0 either.
Thank you in advance for any information
3404621/03/2019 16:00:25
350 forum posts
I have used Dave Watkins plans in 16mm ie 32mm gauge, and multiplied by 1.4 to bring them up to 45mm scale.
His loco's ie Wild Rose, Idris, etc , ie fully detailed drawings are downloadable on the net
May be worth a look.
Bill
Tomfilery21/03/2019 16:58:50
108 forum posts
4 photos
Mike,
In general, they are few and far between.
Wild Rose is a 2 foot gauge quarry Hunslet, which would run on 32mm track. If you built it to 7/8" scale (rather than 16mm) that would run on 45mm (as Bill suggests).
Otherwise, there is Keith Bucklitch's Brazil (now a very old design) and his Izubuntu (Isubuntu??) - which was meant to be built using no-longer available Roundhouse parts (for the cylinders and motion), so wasn't a "build it from scratch" job.
On the 16mm Association website, under resources are details of a couple more locos - but weird ones, rather than the general "British outline" you requested.
Good luck.
Regards Tom
3404621/03/2019 17:14:26
350 forum posts
I have just acquired a full set of Les Warnett build articles on the 3.5 inch scale Lynton and Barnstaple engine which if made at half his drawing size will give me a 45mm narrow gauge engine.
May be worth seeing what is about in 3.5 inch that you could scale down ?
Bill
Bazyle21/03/2019 17:34:21
4443 forum posts
184 photos
I think the Kerr Stuart Wren loco design in Engineering in Miniature from 1997 showed a version for 45mm or could be scaled to fit.
3404621/03/2019 17:50:07
350 forum posts
MJ engineering do a Bagnell in 7.25 inch scale
1/4 scale from a set of their drgs is another possibility perhaps ?
Bill
peter ravenscroft21/03/2019 18:09:48
82 forum posts
hi mike
get hold of a copy of steam trains in your garden available from camden books not cheap but the best book on building 16mm engines
laser cuts are available from model engineers laser
peter
Brian G21/03/2019 19:21:41
457 forum posts
9 photos
There are drawings available through the 16mm association, either on the website (2' gauge unless you scale up to 7/8" which is now a popular option) or by buying back numbers of 16mm today (which has a number of dual gauge designs).
OldMetaller22/03/2019 07:36:50
146 forum posts
14 photos
Mike, another option could be the Gauge 1 Association's publications- 'Gimra' is worth a look, I have the book and the engineering described is to a high standard. You could make their wheels, frames and valve gear, then make your own design of G scale body.
John.
Mike B23/03/2019 21:39:01
3 forum posts
Thank you all for your replies and suggestions, very much appreciated
TRANSWAVE Converters
