Mitsubishi vfd
David Siddle 120/03/2019 14:02:25
12 forum posts
I'm needing a little help picking the correct drive. I've looked at the manual on line, but I'm still a bit confused Could anyone please tell me if the following model would be suitable for powering my 3ph fobco from domestic supply? Many thanks.
FR-D720S-042SC-EC
David
Michael Cottle20/03/2019 14:29:08
8 forum posts
Hi,
This is a 230v input single phase and 220v three phase ouput inverter. Rated at 0.75kw.
Your motor will need to support 220 / or 230v phree phase supply, often by connecting in Delta on a dual rated motor.
It will 'putting in a box' to protect it with room to be able to loose the heat generated.
Then with correct configuration it will then work!
If you not sure about the motor put up a photo of the motor rating plate.
Michael
Brian Hutchings20/03/2019 15:10:56
9 forum posts
Hello David, You could try giving Direct Drives a call, I found them to be very helpful recently.
Direct drives
