Forum sponsored by Allendale May 23
M type lathe tumbler reverse
David George 120/03/2019 09:47:38
758 forum posts
269 photos
I acquired some castings for tumbler reverse so started machining first casting.
Held in 3 jaw chuck skimmed machining boss and centred to hold square and machined outside to size.
Skimmed inside face to help hold whilst cutting radial slot etc.
Turned round to face boss to length and bore to size for spindle.
David
Hopper20/03/2019 09:50:24
3532 forum posts
68 photos
Good work for an 80-year-old "hobby" machine. thumbs up
geoff walker 120/03/2019 11:12:44
281 forum posts
120 photos
Excellent work, nice castings!!!!!
Geoff
David George 123/03/2019 06:47:14
758 forum posts
269 photos
Next set up on rotary table for milling.
David
David George 123/03/2019 09:33:31
758 forum posts
269 photos
Finished machining radial work on main casting.
David
Michael Gilligan23/03/2019 13:26:56
12943 forum posts
555 photos
That's looking good, David yes
This thread should make a useful 'masterclass' reference for some tricky-looking jobs.
David George 123/03/2019 17:41:57
758 forum posts
269 photos
Now to turn the boss to length. Hacksawed the boss waste off and made a expanding shaft jig to hold the part. Piece of size material, centre drill with large drill to make 60 deg cone and tap M8 for screw. Turn 60 deg on back of head on cap screw. Hacksaw two slits to allow diameter to expand. Debur and screw in screw check amount of expansion, loosen and put on part tighten to grip part and check that it won't slip, OK.
Put in lathe chuck turn to length and the main casting bar drilling for pin on assembly us done.
David
Edited By David George 1 on 23/03/2019 17:43:39
David George 126/03/2019 21:15:04
758 forum posts
269 photos
Started work on quadrant casting.
Fly cut the casting to thickness and then clamp down to bore the holes for gears.
Finally bore the shaft hole for support shaft.
David
David George 127/03/2019 13:55:02
758 forum posts
269 photos
Started to drill the quadrant casting edge holes. As the hole for the location plunger has to be at 112.5 degrees to gear holes I used a sine bar to set the angle. The hole has to be in relationship to shaft hole so bolted a short length of shaft to angle plate and centred mill on shaft. Put casting on to shaft, rotated to suit the sine bar and clamped problem solved.
David
geoff walker 127/03/2019 19:38:34
281 forum posts
120 photos
Nice work David,
I admire your methods and attention to detail.
I suspect this will be the most accurate T.R. ever made!!!
atb Geoff
Howard Lewis27/03/2019 21:50:02
1884 forum posts
Looking good! Very well done!
David George 103/04/2019 08:02:09
758 forum posts
269 photos
Done a bit more on tumbler reverse, made the turned parts and started drilling and milling them to get them to work and the small gears have arrived so I can try to fit it and set it up for drilling for taper pin to fix it rotationally. I drilled and tapped the main casting for a grub screw to help with holding it whilst setting it up.
David
Nicholas Farr03/04/2019 08:47:42
1812 forum posts
900 photos
Hi David, really is looking a very nice job.
Regards Nick.
Brian H03/04/2019 10:09:07
1073 forum posts
84 photos
Thanks for sharing that David, I'm sure it will help one or two of us the consider what looks at first sight, rather tricky jobs and your workmanship is excellent.
David George 103/04/2019 19:51:54
758 forum posts
269 photos
Made a new top cover for gear casing.
David
Edited By David George 1 on 03/04/2019 19:53:10
David George 104/04/2019 12:58:39
758 forum posts
269 photos
Pinned the casting to the shaft.
David
geoff walker 104/04/2019 16:05:05
281 forum posts
120 photos
Looks finished now David, except for the painting.
Assume the gears are ok, whole job very professional.
I used the grub screw method to hold it together while fitting the taper pin, GMTA?
Completed mine about 9 years ago, same patterns used for the castings as yours.
Here is an archive picture.
Geoff
David George 106/04/2019 15:42:59
758 forum posts
269 photos
Finished and painted Tumbler reverse. It works very well but need to play around with gearing for fine feed.
David
TRANSWAVE Converters
