Forum sponsored by Allendale Nov 29
combined BOB with drivers or seperate?
fizzy13/03/2019 19:51:03
1563 forum posts
104 photos
Looking for a USB breakout board to run Mach3 and see that we can buy a control board with integrated driver. Anyone tried the new integrated boards? Something tells me to stick to separate parts.
fizzy14/03/2019 09:39:34
1563 forum posts
104 photos
bump
David Jupp14/03/2019 09:53:49
651 forum posts
16 photos
Integrated board will be smaller and cheaper than using separate driver modules, but if you manage to blow a driver you can't just swap it out as easily as with separate units. Less wiring to do with an integrated board. Less choice of driver current ratings etc. with an integrated board, you get what the board maker gives you.
I've used integrated parallel breakout boards in the past without problems, but I wasn't pushing the drivers hard.
John Haine14/03/2019 10:58:20
2455 forum posts
132 photos
If you mean one of this sort of thing the general recommendation on other forums is to avoid them for the reason that David gives.
What do you mean by a "USB breakout board for Mach 3"? You can't use a USB - parallel port for Mach 3, has to be a motion controller with a USB input such as this. It looks like a standard parallel port plug with a USB socket on the back, but contains all the electronics to generate stepper drive pulses. This then plugs in to a standard BoB designed for a parallel port interface, of which there are many around.
John Haine14/03/2019 11:57:42
2455 forum posts
132 photos
And to add that apparently there a number of clones available from China which are NOT recommended - the one from CNCDrive is reasonably priced and people seem to recommend them. You need to have a Mach 3 plug-in to support them, which is not likely to support the Chinese ones so well.
JasonB14/03/2019 12:00:17
15171 forum posts
1548 photos
My Mach3 works with a USB and no adaptor from USB to Parallel.smiley USB socket is direct to the board. that silver box is the USB socket
Edited By JasonB on 14/03/2019 12:04:42
fizzy14/03/2019 20:01:43
1563 forum posts
104 photos
Thanks all - Jason, thats similar to what I had in mind but the board has the drivers built in. I think direct USB is quite a new thing. Ive also looked at ethernet connected boards but im way out of my comfort zone with those. Im also wondering if the new boards will run with windows 7 64bit. The simulator has no problems with it.
Ausee.com.au
Allendale May 19
TRANSWAVE Converters
