Soba rotary table
Neil Lawton09/03/2019 11:40:20
2 forum posts
I recently received a Soba HV6 rotary table and found the following:
(i) With the worm gear disengaged, I can push/pull the table laterally (orthogonal to the axis of rotation) by about .05mm. Tightening the axial preload collar on the base of the unit has no effect on this 'slop'.
(ii) The worm ring gear appears to be slightly offset from the axis because cranking the handwheel stiffens for one half of the rotation and loosens for the other half. This means that I can set backlash to 2' on the tight half but it goes out to 8' on the loose half.
This is my first rotary table so I have nothing to compare it with. Would the group consider this acceptable or is it enough to return.
Thanks.
Michael Gilligan09/03/2019 19:51:51
20182 forum posts
1053 photos
Well, Neil ... I wouldn't want it.
But: How was it advertised ? [i.e. is there a specification that you can challenge ?]
As the late John Stevenson used to say: Such things are often "fit for purse" and their "fitness for purpose" needs to assessed in that context.
Note: Very good Rotary Tables can be very expensive.
John Haine09/03/2019 20:47:44
4673 forum posts
273 photos
Clearly crap. Send it back.
JasonB09/03/2019 20:54:05
22747 forum posts
2653 photos
Having had first hand experience of using one of these Soba rotary tables for about the last eight years I can't say I have ever felt the need to take that measurement until I read this post. I have not noticed an issue with mine and it does what I would expect and I have made models using it that have taken medals and highly commended awards so to me it's certainly fit for the purpose of making models, others may have other purposes that require more.
I have about 10' backlash on the handwheel which is a nice round number when you need to compensate for it.
J
Chris Trice09/03/2019 22:34:23
1375 forum posts
10 photos
I have both a Vertex 4" and Vertex 6" Rotary table and although the 6" tightens slightly as you turn the handle for half a turn, it remains smooth and there's no appreciable slop in the mechanism and I like them both. Based on this, I bought (the company paid for it) a (cheaper) Soba 6" rotary table for use at work which, because it looked identical to the Vertex, I mistakenly assumed was made on the same production line and simply rebadged. By comparison and based on expectation, the Soba was disappointing being rougher finished and not as well made. However it worked sufficiently well for the stuff we were chonking out. It made me cautious about buying another though having been spoilt by the Vertex, so unless you're on a tight budget, I personally would say pay the extra if you want to be sure.
Neil Wyatt10/03/2019 12:28:15
19033 forum posts
734 photos
80 articles
The actual backlash is less important than the angular accuracy, so I'd test that rather than the backlash.
The spindle should be somewhere around a slide fit, which means some movement. Assuming the spindle is about 1 1/2" diameter that would be somewhere around 0.025mm, tighter than that would be a push fit and it would be likely to jam or pickup when rotated being a plain bearing.
It might be worth checking that the spindle is well greased, this may help the 'feel'.
Michael Gilligan10/03/2019 14:18:38
20182 forum posts
1053 photos
Posted by Neil Wyatt on 10/03/2019 12:28:15:
Let's assume that Neil Lawton does not have access to optical polygons etc.
How does a hobbyist test angular accuracy ?
I offer a suggestion that I have made before, and invite others to improve upon it:
  1. Make two plates, each with a central hole to closely fit a central spigot in the table
  2. Mount them [pinned together, with a sacrificial plate below] securely on the table.
  3. Using the table to the best of your ability, drill and ream [or use a slot-drill] seven holes on a pitch circle
  4. Remove and separate the plates
  5. Insert closely fitting pins through all eight test holes [central, plus seven]
  6. Remove all but the central pin, and step one plate around by one hole
  7. Re-fit the seven pins [if you can]
  8. Repeat 5,6,7 until all seven positions have been checked
  9. Invert one plate and repeat 5,6,7,8
If all this works to your satisfaction, the angular accuracy is 'good enough'
If it proves impossible to insert any pin through both plates, then test with smaller pins to quantify the error.
Neil Wyatt10/03/2019 15:46:04
19033 forum posts
734 photos
80 articles
Or stick a laser pointer on the table and aim it perpendicular to a far wall.
Requires a bit of trig and care in setting up....
Paul Kemp10/03/2019 16:10:46
712 forum posts
27 photos
Or... Just accept it for what it is, a cheaply made bit of kit to provide an economical solution to the masses with a standard of accuracy commensurate with its cost. OP didn't state why he had bought it and what it's intended use is. If it's for the usual back yard engineering jobs like steam engines then bolt it on your machine and get using it. If it's for instrument making which requires extreme precision and formal calibration of the final product make sure your shop is kept at 20 degrees at all times, your measurement tools are only of the highest quality properly calibrated and buy a decent one. What else can be said? Seem to be a lot of people here chasing elusive microns where a couple of thou or in some cases 1/64" is perfectly adequate. Life and hence time allotted to us is finite so spend it getting on with the project and not chasing accuracy you don't really need! If you do need it don't buy your kit from purveyors of leisure grade equipment.
Paul.
Michael Gilligan10/03/2019 16:11:02
20182 forum posts
1053 photos
Posted by Neil Wyatt on 10/03/2019 15:46:04:
Do you propose a straight wall, suitably 'trammed'
or a truly circular wall, concentric with the table's axis of rotation ?
MichaelG. angel
Michael Gilligan10/03/2019 16:13:36
20182 forum posts
1053 photos
Posted by Paul Kemp on 10/03/2019 16:10:46:
dont know
Pretty much what I said in my first response.
Kevin D12/03/2019 11:42:55
16 forum posts
86 photos
I purchased 6" soba table some years ago from a well known UK supplier. It failed and needed a new worm wheel. I was advised that part HVRT-03 was not available. A supplier here in Australia had a table that looked the same and could get a gear for $98 AU. Now the good news. They had a sale on the next week and a 6" vertex was $180. The soba dividing plates and tail stock will fit it.smiley
The reason for the failure was having too much or any back lash while milling 16mm cooling channels in a 300dia Al plate. The worm gear is soft cast iron spur gear cut at about 1.5 degree helix angle (not a worm wheel). It had teeth missing in more than one place around it. Now the fix. A small amount of grinding with a burr to clean up any high spots in the table body and a spacer to go between the table top and the gear. The gear now hangs lower just clearing the inside and the worm bears higher up on an undamaged part of the gear. It now work fine.
Any heavy load on these gears will cause damage.
Dave Halford12/03/2019 11:49:18
2050 forum posts
23 photos
So these are tables that you don't use for milling curves
Hopper12/03/2019 12:21:49
6393 forum posts
334 photos
Posted by Kevin D on 12/03/2019 11:42:55:
...The worm gear is soft cast iron spur gear cut at about 1.5 degree helix angle (not a worm wheel). ...
There-in lies the rub. As such there will be point contact only between worm and gear. Suitable For Positioning Only and not driving under load. Pity they don't mention this in the instructions as there have been quite a few others posting similar experiences. If you know, you can drill holes around the periphery of the table and use a tommy bar to provide rotary motion during machining by "hand feed". Stops clamped around the periphery provide control over total angle machined. Just like the simple wormless rotary tables designed years ago by GH Thomas and Harold Hall.
JasonB12/03/2019 12:24:52
22747 forum posts
2653 photos
Posted by Dave Halford on 12/03/2019 11:49:18:
Perfectly suitable for curves, it's just overloaded with work that is probably too big for them or take excessive cuts they will fail, much the same for any tooling.
Neil Wyatt12/03/2019 13:15:29
19033 forum posts
734 photos
80 articles
Posted by Michael Gilligan on 10/03/2019 16:11:02:
MichaelG. angel
A straight wall and a little care will be fine - but you already know that
SillyOldDuffer12/03/2019 14:23:49
8684 forum posts
1967 photos
Posted by JasonB on 12/03/2019 12:24:52:
For heavy curve cutting a £150 6" rotary table might be considered disposable. You can pay three or four times more dosh for a better version of the same table, but it's still lightly built for hacking out curves, and much more painful if you destroy one!
It's like the mitre saw I bought for a one-off woodworking job. Much cheaper than a professional saw and slightly cheaper than hiring a professional machine. It cut the 40 odd joints I needed and it's still working. For what I needed it was fit for purpose and value for money. When the saw breaks I shall replace it. John Maynard Keynes famous last words were 'I should have drunk more champagne'. In that spirit, I'm not keen on spending a fortune on tools that will be in perfect condition when I'm in a graveyard...
Michael Gilligan12/03/2019 14:31:27
20182 forum posts
1053 photos
Posted by Neil Wyatt on 12/03/2019 13:15:29:
Quite a lot of care [and some deviousness] if you want to test the full rotation.
John Hinkley12/03/2019 14:58:38
1332 forum posts
426 photos
Not Soba, but an interesting watch if you have 90 minutes to spare.... Stefan Gotteswinter strips and reworks a Vertex rotary table to move accurately and smoothly to correct similar problems to those experienced by the OP, at :
Improving a Vertex HV6 rotary table
Vic12/03/2019 15:51:30
3074 forum posts
8 photos
As a matter of interest, Vertex are based in Taiwan and rightly or wrongly Taiwanese stuff is reckoned by some to be superior to Chinese products. Vertex do though have a good reputation. Soba (Shoba) are I believe made in India.
Rapid RC
Dreweatts
