Weight of Excel Die Filer
Colin Heseltine28/02/2019 18:20:44
392 forum posts
96 photos
Does anyone happen to know the weight of an Excel Die Filer. Can it be lifted by one man.
Thanks,
Colin
Plasma28/02/2019 18:36:52
387 forum posts
45 photos
Hi colin. The bench top model is a hefty machine but quite easy to lift single handed. I sold mine a few months ago and it easily fitted in the back of my saloon car.
I have a floor mounted Brevettata model now that weighs a few hundred kilos. Its staying put as I cant shift it lol.
Colin Heseltine28/02/2019 19:43:47
392 forum posts
96 photos
It is the bench top model I was interested in. The fact it is a one man lift is the answer I wanted.
Thx.
T.B28/02/2019 22:26:28
24 forum posts
I just happen to have a bench top Excel die filer in bits awaiting some TLC
My bathroom scales say 53kg + 16kg for the motor.
Colin Heseltine01/03/2019 12:52:36
392 forum posts
96 photos
So 69Kg. Might be a bit of a struggle one man, but I guess that the top arm and the bed would remove quite easily to reduce weight to pick it up. (and motor if it came to it)
Colin
Bazyle02/03/2019 10:18:44
5125 forum posts
199 photos
Edit - my earlier post was rubbish. It is sitting just on 9 stone including motor and arm. So if you can lift your girlfriend you can lift this. The over arm and table come off quite easily, and perhaps the motor.
Trouble is I now weighed myself so no donut for elevensies.
Edited By Bazyle on 02/03/2019 10:46:45
blowlamp02/03/2019 11:41:03
1292 forum posts
83 photos
Posted by Bazyle on 02/03/2019 10:18:44:
Have you seen the size of girlfriends recently? devil
Edited By blowlamp on 02/03/2019 11:41:48
Chris Evans 602/03/2019 17:22:01
1625 forum posts
Colin, if you need a lift I am only just up the road to you. Chris.
Colin Heseltine24/03/2019 15:58:02
392 forum posts
96 photos
Its definitely not light. Two of us picked it up and got it into my van.
It has he overarm for use with saw blades and currently has a thin file clamped in the saw clamp. Runs nice and quietly.
Looks as though I need to make the Roller Arm support bracket. Has anyone got a photograph of the same and or some dimensions.
Need to fit On/Off/NVR switch as currently just has a 13amp plug fitted on motor.
Need to find.make some files.
Colin
Colin Heseltine14/04/2019 16:37:22
392 forum posts
96 photos
Does anyone have photographs of the file clamp mechanism in a dismantled state. I would like to see how it works before dismantling it.
Thanks,
Colin
