Forum sponsored by Allendale May 23
WM180 Replacement Cross Slide
Andy Carruthers28/02/2019 14:08:32
221 forum posts
23 photos
I am considering replacing the Cross Slide on my WM180 in part to increase the lathe versatility but also to give myself a decent project
I've read Neil's foray and taken note though I have lost the link to his post, also seen these:
http://mikesworkshop.weebly.com/cross-slide-extended-travel.html
http://andysmachines.weebly.com/extended-cross-slide-travel.html
My question is whether T slots or Dovetails would be best for securing the Compound and other accessories ie Ball Turner, Rear Cut-off tool
SillyOldDuffer28/02/2019 14:46:07
4135 forum posts
833 photos
I wouldn't bother with dovetails in this application because they're a lot of fuss for no obvious advantage. T-slots and easy to make T-nuts are fine for clamping accessories to a table. You don't need the sliding precision of dovetailed parts for mounting ball-turners etc. on a cross-slide.
Simple is usually best. (But not too simple!)
JasonB28/02/2019 15:28:08
15183 forum posts
1548 photos
Tee slots.
Have you seen Ron's recent thread on the one he made for his mini-lathe?
Neil Wyatt28/02/2019 15:28:34
15830 forum posts
672 photos
73 articles
Voice of experience - I would use much smaller t-slots second time around.
I matched the slots to my mill, but they are well oversize those on the SC4 are rather smaller and better proportioned - 10mm for M8 screws, I think.
John Haine28/02/2019 17:51:09
2458 forum posts
132 photos
Dovetails would be a right pain. Tee slots and nuts are much more versatile, you don't want to have to cut a dovetail when you have to mount a new accessory. I don't think I've ever seen a dovetail used on a machine table other than for the sliding surfaces. Actually, it would also be much weaker than a tee slot.
Andy Carruthers01/03/2019 06:52:13
221 forum posts
23 photos
@Jason - I have just read Ron's thread, thanks for highlighting this
I appreciate the feedback, thanks to all, plenty to think on
Bernard Greatrix04/03/2019 16:20:36
22 forum posts
4 photos
Can someone give a link to "Ron's recent thread" - ditto "Neils Foray"
I also have a WM180 and would like to extend the cross feed travel. One of my sticking points is the left-hand thread. I haven't successfully managed it despite running in reverse with the lathe tool upside down.
regards
Bernard
JasonB04/03/2019 16:34:59
15183 forum posts
1548 photos
Neil's and Ron's
Frances IoM04/03/2019 16:39:06
581 forum posts
22 photos
you can't cut LH threads on a WM180 unless you can manage to squeeze an extra gear into the somewhat length restricted gear train. There is at least one description of adding a tumbler but the design of the WM180 was changed (cost reduced?) in later models and don't think it will fit new models.
Bernard Greatrix04/03/2019 17:01:37
22 forum posts
4 photos
Again thanks Jason - I'll read them when I've a little more time. SWMBO wants some jobs done before it gets dark
Frances - The WM180 manual says that left hand threads are not possible. That is certainly true for an unmodified lathe.
However I reasoned that if I used a lathe tool upside down and ran the lathe in reverse I might succeed - I didn't by the way - all I got for my troubles was a metallic version of a bottle brush as it didn't cut at all cleanly.
I shall have to investigate making a new banjo arm to add an extra gear. Then I can cut a new cross-slide screw. Then I can mount a VMS and I can mill the item I set out to make in the first place.
regards
Bernard
Frances IoM04/03/2019 17:15:59
581 forum posts
22 photos
Bernard even trying to cut in reverse can't give you a LH thread as you need to reverse the sense of the geared coupling between chuck and leadscrew
Bernard Greatrix04/03/2019 17:22:35
22 forum posts
4 photos
Yep - as I said I didn't succeed
Neil Lickfold04/03/2019 18:01:44
529 forum posts
99 photos
When I made my Myford 0.5mm pitch cross scre wand nut, I just used the normal RH tap , and screwcut the thread with a traveling steady rest.
It does need to turn the opposite , I it is no biggie. You just have to remember which way is feed out.
TRANSWAVE Converters
