Forum sponsored by Allendale Oct 22nd
3/16 bsw screws
Looking to source affordable screws
Mark Whelan27/02/2019 20:59:55
11 forum posts
Hey all,
I'm after shearing off two screws in the tailstock of my myford m type, which I think are 3/16 24 bsw
I've drilled them out and now I need to replace them.
There's a few sellers on eBay but the want between 10-20 pounds shipping to Ireland for 5 screws!
Anyone recommend somewhere more reasonable?
Speedy Builder527/02/2019 21:18:26
1819 forum posts
128 photos
Why not have a go at making them. You would feel great when you have done them. Not too difficult. Bobh
Barrie Lever27/02/2019 21:35:42
323 forum posts
Mark
10/24 UNC will screw straight in, just the thread angle is different 55 degrees for Whit 60 degrees for UNC.
Unfortunately I have to admit to doing this many times in the middle of the night in maintainance work when my back was to the wall !!
Barrie
peak427/02/2019 21:46:27
851 forum posts
71 photos
I can do you 1/2" and 3/4" mild steel roundheads (I think, I'll have to check up)
If they will fit, PM me your address
Bill
JohnF27/02/2019 23:12:25
864 forum posts
102 photos
Mark, they may well be 2BA but look at your PM's
Hopper27/02/2019 23:28:04
3712 forum posts
73 photos
I buy BSW screws, nuts and bolts from my local hardware store. Although Australia went metric 40 years ago, the building trade still seems to use the old imperial stuff for some reason. They are just labelled as 1/4" x 1" screw etc. No idea about Ireland though!
duncan webster28/02/2019 10:04:56
2232 forum posts
32 photos
3/16 bsf is nearly the same as 2BA, but 3/16 bsw is much coarser.
If you are sure you want bsw then try the trusty e-bay
f:1&frcectupt=true">https://www.ebay.co.uk/itm/1-8-3-16-1-4-BSW-Whitworth-High-Tensile-Cap-Head-Allen-Bolts-Socket-Screws/271903549676?hash=item3f4eb6e8ec:m:mQSWuri_vZQT8SoOxDhjDig:rk:1f:1&frcectupt=true
vintage engineer28/02/2019 10:07:18
179 forum posts
Meccano screws.
Adam Mara28/02/2019 10:43:51
74 forum posts
4 photos
Loads of BSW machine screws at work, at least 25 years old ex B&Q! PM me if don't have any luck, I will be going into work on Monday to collect the rent, and can pinch a few and post them to you!
Georgineer28/02/2019 11:50:49
260 forum posts
14 photos
Posted by vintage engineer on 28/02/2019 10:07:18:
Meccano screws.
That won't work. Meccano screws are 5/32" BSW.
George
Andrew Johnston28/02/2019 12:30:19
4855 forum posts
544 photos
I don't know what thread Myford used, but 3/16" BSW would be a poor choice. It's a small diameter rather coarse pitch thread, with the result that the slightest overtightening fractures the core. Been there, done that!
Mark Whelan28/02/2019 13:22:35
11 forum posts
Hi Guys,
Thanks for all the tips and for the PM's offering to help. The 10-24 is probably easiest to try first, as I should have some lying around in work, if that doesn't work I'll try the next few options. I'll also try to remember to report back with some news hopefully.
Mark
Howard Lewis28/02/2019 15:47:23
2337 forum posts
These sound like the screws retaining the plates for the Handwheel. On a ML2 or ML4 they are likely to be 3/16 BSW (or maybe 3/16 BSF ? ) roundhead.
Take up the kind offer already made a few posts ago; You only need two!
Howard.
Meridienne oct 2019
TRANSWAVE Converters
cowbells
