file
square file
Philip Burley21/02/2019 20:34:05
152 forum posts
can anyone please recommend a supplier of a small tapered square file of decent quality ? I need to file a hole a bit less than 1/8 inch square
regards Phil
Michael Gilligan21/02/2019 20:47:22
14784 forum posts
635 photos
https://www.cooksongold.com/Jewellery-Tools/-Range=Files/-Size=0/-Type=0/-Brand=Vallorbe/-Font=0/&prdsearch=y&prdsearch=y&numperpage=25&pagenum=0&show=N&orderby=size&refurl=y
Last two items on the page.
Mike Crossfield21/02/2019 20:56:12
197 forum posts
17 photos
I’ve been very pleased with the Swiss pattern Tome Feteira needle files sold by Arc Euro Trade. Cheaper than Vallorbe, and good quality.
dcosta21/02/2019 23:04:42
478 forum posts
205 photos
Hello Mike,
If in your message you mean that the Tomé Feteira files are of Swiss manufacture, you are wrong.
They are, in fact, manufactured in Portugal.
Read, please, the text you can find ***HERE*** .
Best Regards
Dias Costa
HOWARDT21/02/2019 23:09:42
491 forum posts
14 photos
No he stated Swiss pattern not Swiss made, another option is USA pattern.
dcosta21/02/2019 23:24:09
478 forum posts
205 photos
Hello Howardt,
Thanks for the clarification.
I will have to review my (short) knowledge about files.
greetings
Dias Costa
Peter F22/02/2019 01:00:46
109 forum posts
23 photos
Have a look on amazon, Pferd is one of the brands they offer on Prime deals, there is currently one on there that I think is what you're looking for at £3.50 as an add on item meaning you need to spend £20 if you can find a few you want, you can get some at massively reduced prices, I've bought half a dozen pottance files for hardened material ranging from £2.70 to £10 these files retail at about £30 each. Best quality files I've ever used.
Philip Burley22/02/2019 08:28:03
152 forum posts
Thanks I will follow up some of those , Problem is the advertisers don't say what the sizes are ,
Philip Burley22/02/2019 08:34:08
152 forum posts
I have sent for the ARC one . see what that looks like
ega22/02/2019 11:45:12
1444 forum posts
118 photos
Peter F:
Thanks for introducing me to the "pottance file". This seems to be a type of Swiss or toolmaker's file with the cut designated by a number and, as you suggest, harder than standard.
In trying to chase this down I came across a reference to Peter Stubs' files being measured in French inches or "pouces" (longer than the English inch).
roy entwistle22/02/2019 14:55:53
1104 forum posts
Just a point but if I was filing a square hole I would use a three square file ( triangular ) not a square one
Roy
Peter F22/02/2019 15:00:09
109 forum posts
23 photos
Posted by ega on 22/02/2019 11:45:12:
Peter F:
Yes, they range 0 to 4, 4 being the finest, a #1 pottance is about the same as a normal fine file, and a #4 you can file your finger nails with its so fine.
Michael Gilligan22/02/2019 16:51:25
14784 forum posts
635 photos
Posted by roy entwistle on 22/02/2019 14:55:53:
Roy
Me too ... but that wasn't the question
Russell Eberhardt23/02/2019 10:57:22
2535 forum posts
85 photos
Posted by ega on 22/02/2019 11:45:12:French inches or "pouces" (longer than the English inch).
That used to be the case many years ago but now the French pouce (thumb) is defined as 2.54 mm, exactly the same as the Imperial inch.
Russell
ega23/02/2019 11:25:30
1444 forum posts
118 photos
Posted by Russell Eberhardt on 23/02/2019 10:57:22:
Russell
Thank you for pointing that out. My 1943 Machinery's Handbook gives the then metric equivalent of 25.4001 but, according to Wikipedia, " In 1930, the British Standards Institution adopted an inch of exactly 25.4 mm. "
I remember having a discussion some years ago with an elderly relative who was a qualified engineer and having some difficulty in persuading him of your point. The difference must have been regarded as very slight and I think the use of a 127 tooth gear for metric pitches pre-dated harmonisation.
Raymond Anderson23/02/2019 14:26:21
735 forum posts
140 photos
Agree with Peter F, Pferd are fantastic files. I have quite a few and some are years old and still cut very well even though they have seen a lot of use over the years. Top notch filesyes
Brian H23/02/2019 15:16:44
1396 forum posts
100 photos
Russell
Sorry to be a pedant but that should be 2.54 centimeters or 25.4 millimeters.
Russell Eberhardt23/02/2019 16:17:13
2535 forum posts
85 photos
Posted by Brian H on 23/02/2019 15:16:44:
Oops!
Russell
ega23/02/2019 16:33:31
1444 forum posts
118 photos
Posted by Russell Eberhardt on 23/02/2019 16:17:13:
Oops!
Russell
Oops all round. I shan't be pursuing a career in pharmacy!
